Go Back   Team-BHP > BHP India > Commercial Vehicles
Old 15th December 2010, 21:32   #1
jeepster's Avatar
Thanked: 1,036 Times
Default Help regarding a vehicle for Mobile Soil Testing Lab
hi guys
we have a NGO which works mainly in rural & agricultural development.
we want to start a MOBILE SOIL TESTING LAB under the scheme of Government of India.
the minimum requirements are as follows. (budget is 16L including Generator)
so the question is what vehicle to use?
& from where the body/lab should be fabricated/made?
rgds,
Nikhil
jeepster is offline   Reply With Quote
Old 15th December 2010, 21:49   #2
absynthguzzler's Avatar
Thanked: 224 Times
Default Re: Help regarding a vehicle for Mobile Soil Testing Lab
I think the Tata Winger - Cargo fits the bill as the base vehicle. I'm not aware of any other options ( new vehicles) to this either.
absynthguzzler is offline   Reply With Quote
Old 15th December 2010, 22:07   #3
condor's Avatar
Thanked: 4,907 Times
Default Winger is not 6-7 tonnes
Is there such a model at all ?
The Winger is nowhere near the 6-7 ton capacity specified. Rated Payload of most MUV's is less than 1 ton - more like 600- 700 kg's
Old 15th December 2010, 22:17   #4
Thanked: 224 Times
Default Re: Winger is not 6-7 tonnes
The vehicle is manufactured, but you may be right about payload limit. Also another factor working against it is the sleeper section in driver cabin.Apologies, the search continues......
Old 15th December 2010, 22:17   #5
turbo1787's Avatar
Thanked: 23 Times
Hey Nikhil, take a look at the undermentioned link:
A.C. Soil Testing Lab Vehicle Exporter,Pune,Maharashtra,India
As per my observations mostly the mobile soil testing labs are based on full size 6 tyred trucks ( Respective models of Tata/AL/Eicher/Swaraj Mazda etc.). Further no van would have the tonnage capacity of 6-7 tonnes.
Large infrastructure companies and State Fertiliser companies/PSUs use these vehicles hence do try and take a look at some of them (if possible).
turbo1787 is offline   Reply With Quote
Old 15th December 2010, 22:40   #6
jeepster's Avatar
as Condor corrected not possible.
right.
thanks for the link. (have seen it already)
there is another one in pune.
about the tonnage who can argue with the government.
Old 16th December 2010, 09:15   #7
sandeepmdas's Avatar
Thanked: 713 Times
@Jeepster, I am not sure you can meet the specifications with the given budget, my thoughts:
- you need a bus and not a truck IMO. You could look at the Eicher 11.10 chasis or built-up bus perhaps. The 11.10 is based on their 7-ton truck chasis:
Product Range
- there is a slight typo in your specs ref. genset which I assume 7.5 KVA. You can save a lot of money if you can go for a Honda eu65is PETROL genset which is 5.5 KVA. This genset is silent, portable and requires no special generator "room". However, it is "only" 5.5KVA and you need to carry petrol also..
Honda Gensets, Water Pump, Engines, Lawn Mowers & Brush Cutters
- I think such a bus can be cooled with a 1-ton A/c. You may want to check with our thread "which ac to buy?".
- Please double-check with the RTO etc before you equip the vehicle with LPG burners etc. AFAIK, there are several regulations concerned with this.
sandeepmdas is offline   Reply With Quote
Old 16th December 2010, 23:19   #8
Thanked: 154 Times
You may need to get in touch with Special Vehicles Division of Antony Motors, Mumbai.
:: ANTONY ::
Portable Cabin,Transit Mixers,Aviation Refuelers,Mini Tipper,India
teamveevee is offline   Reply With Quote
Old 17th December 2010, 07:42   #9
Thanked: 532 Times
You will definitely require a bus chassis so as to provide for a sleeper bunk, as all the truck chassis will come with full cabs without bunks. This I think will limit your choice quite a bit as I think only Eicher and Swaraj provide bus chassis in the load range your are looking.
Also what I think is that you better look for a pretty powerful engine, as the total weight with all the equipment will be quite high.
julupani is offline   Reply With Quote
Old 17th December 2010, 09:14   #10
jeepster's Avatar
the above requirement is from a GR (Government Resolution) so we have to follow it.
:: ANTONY ::
thanks.
Originally Posted by julupani View Post
You will definitely require a bus chassis.
yes a bus platform is the answer.
here is a example.
source: Mobile Soil Testing Laboratory. | mi(sual).com
Old 17th December 2010, 09:42   #11
Thanked: 36 Times
A canter can fit the bill but will require a lot of fabrication around to make it look comfy for a lab.
zaks is offline   Reply With Quote
Old 17th December 2010, 22:41   #12
Thanked: 660 Times
OT!
it looks hideous.
I think this one is made in Gujarat. Check the temp. registration plate.
can inquire about this!
BTW what about Force traveler.?
Old 17th December 2010, 23:15   #13
jeepster's Avatar
yes,
traveller (20+driver) is qupted t 8.64 L ex showroom.
looking at mahindra tourister, tata starbus, eicher skyline too.
also looking at bare chassis option.
Old 18th December 2010, 07:40   #14
Thanked: 532 Times
I think your best option is the Eicher 10.75 bus chassis. No point buying a FB bus and then having to rebuild the body completely over, because you will end up losing a lot of the value of the bus.
The one that is pictured is truly hideous and the body build quality is not very good either. Also I think, looking at the size and the lights, that is is built on a 410 SFC chassis, which I dont think meets the govt regulations in the first place.
Old 18th December 2010, 20:37   #15
jeepster's Avatar
the ashok leyland E comet 1212 series is quoted at 8.25 for chassis with cabin.
add the cost of
  • body.
  • internal furnishing.
  • air-conditioning only.
  • internal height of 1.65m & width of 2m.
  • gen-set room of 1x2 m.
  • interior wood work as per lab standard top cover furnishing with acid proof sun mica wood flooring.
  • suitable slab & cupboards for glassware & chemicals & allied items.
  • electric wiring, lighting, extra power points, safety for short circuiting, fire safety.
  • air condition 1.5 ton.
  • water tank 200L.
  • stainless still sink.
it will exceed the 15L mark.
so thinking about fully built bus costing 9L, then only seats will be removed & the cabinets, AC, gen-set, other stuff will be added.
hopefully it will remain within 15L mark.
Autosure - The car test lab. Checking, testing & analysis of your car Tushar Technical Stuff 5 7th September 2015 14:38
BMW Guggenheim's grand new gesture - after art cars its a mobile lab! prateekpsingh The International Automotive Scene 1 4th August 2011 11:41
Spied – 2010 Mercedes Benz C250 CGI on Indian soil. EDIT : Maybe not after all Sudan_NFS The Indian Car Scene 10 14th May 2010 20:47
Will Mahindra Bolero be the best off roader ever on Indian soil??? The Wolf 4x4 Vehicles 127 21st August 2009 01:52
REST in PEACE DUKE..Welcome baby Lab !! khaadu75 Shifting gears 60 20th July 2007 17:26
