Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Delhi NCR
Old 4th August 2015, 20:25   #16
tanwaramit's Avatar
Thanked: 388 Times
Default Re: Description of Services
Originally Posted by joybhowmik View Post
I would suggest checking the belt tension, idler pulley, and compressor clutch before putting money down on a new compressor.
Would need a mechanic to check all that. Hence went to Shanoo, he however asked me to start the car and switch on the AC. He was seeing the coldness of the AC pipe to see the amount of cooling and said that the compressor isn't able to cool properly and hence the car isn't cooling in traffic too.
I gave him your reference and he immediately recollected and was talking about team-bhp and how lots of other people had come to him thanks to your this post.
Originally Posted by fighterace View Post
No point in putting a new comp as the car will be "dead" after three years.
True to that, not sure how long will I keep the car, also now the summers are almost gone from NCR.
Does the compressor clutch disengage or the refrigerant flow is insufficient?
I feel that the compressor clutch disengages as I can see the compressor stops working during bumper to bumper traffic. It just blows air like a fan in this condition.
tanwaramit is offline   Reply With Quote
Old 4th August 2015, 21:32   #17
joybhowmik's Avatar
Thanked: 1,928 Times
tanwaramit
That he was checking the coldness of the AC pipe to see if the compressor is working is by itself not unreasonable - many do this as a sanity check.
Do note my OP mentioned:
1. Will try and subtly upsell you. Be aware.
Hence the 'suggestion' to get him to take things step by step. Putting a new high capacity condensor - will mask the smaller reasons - of why the older configuration was not cooling much.
There is an outside chance - however slim, that fixing minor issues, may achieve a decent level of cooling -though perhaps not an igloo effect.
The worst case - you get to spend maybe 100-200 in labor charges for the trouble. That's 1.3% of a brand new Sanden compressor + clutch which can cost 15K.
So in the best case, if you avoid an expense of 15K - why not?
joybhowmik is offline   (2) Thanks Reply With Quote
Old 5th August 2015, 01:22   #18
Thanked: 130 Times
Default Re: Friendly Neighbourhood Garage - Shanoo & Irfan, Unique Automobiles (Delhi)
Clutch disengagement can be felt by
  1. An audible click of the compressor cutting off.
  2. Sudden increase in available power, as if suddenly the handbrake has been released.
My Zen acts cranky in stop-go situations with the AC on in the peak summers. I believe it has to do with the condenser not cooling the gas well which trips the AC and does all sorts of mischief. I have learnt to live with that.
A worn compressor however will simply be unable to do anything at low RPMs. At high RPMs the cooling will increase. In stop-go traffic once cooling declines, try revving the engine (while slipping the clutch if needed). A weak compressor should respond to this. Alternatively, hook up an AC gas recharge line and check the high and low end pressure difference. That will give you some concrete information to act on.
Pay a visit to Quick Car AC in Lajpat Nagar. They too are experts and a well established business with a long history. Let's hear their verdict and then decide.
Mr. Bhowmik, Sanden compressors are available for much less. I got my 800 airconditioned for 16k a couple of years back with a brand new Sanden kit. That said, a compressor replacement is warranted only after a complete diagnosis is done.
fighterace is offline   Reply With Quote
Old 5th August 2015, 10:54   #19
joybhowmik's Avatar
Shanoo/Irfan are one of the authorized outlets (if one were to believe them). Having said that the price can and indeed does change from one dealer to another.
So, it's important to do a price check before buying from a vendor.
100% agree. This is an expensive part - and complete diagnosis to isolate the cause is essential.
I think the V belt turns the compressor pulley anyway. Just revving the engine in neutral should be adequate to test the hypothesis. The power to the drivetrain is a different thing altogether. So I don't see any reason to slip the clutch.
Old 5th August 2015, 11:12   #20
Thanked: 35 Times
tanwaramit- A friend got the entire a/c system of his fabia replaced with a brand new one, from them. (he chose them after a lot of research). I too got the gas recharged for my car along with the usual cleaning of the related parts.
One can visit them for a second opinion.
sinhead is offline   Reply With Quote
Old 5th August 2015, 17:09   #21
tanwaramit's Avatar
Thanked: 388 Times
Thanks BHPians for your inputs.
I will goto Quick Cool days, Lajpat Nagar sometime later.
The NCR weather has been pleasing, with heavy rains just a few mins back, the AC issue can be lived with for the time being.
Friendly Neighbourhood Garage - World of Service (Sector 63, Noida) dhondusaxena Delhi NCR 147 10th August 2018 23:06
Friendly Neighbourhood Painter - Ramesh (New Delhi) joybhowmik Shifting gears 8 9th October 2017 22:08
Friendly neighbourhood kid on the block kryptik83 Introduce yourself 4 23rd December 2007 14:53
