Go Back   Team-BHP > Under the Hood > Team-BHP Directory > Delhi NCR
Old 29th November 2014, 19:48   #1
SS-Traveller's Avatar
Thanked: 11,630 Times
Default Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed1.jpg
Speciality / USP:
Here is a talented specialist who fixes automotive parts that are generally replaced (usually at quite a high cost). Complete meter consoles, motorized ORVMs and front axles are very expensive for most cars, though things rarely go wrong with any of these. But when things DO go wrong, the only advice one hears is to throw away the old unit and buy a new one. Here's where these people can help.
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed3.jpg
Javed has been in the business of repairing automotive meters since 1992, and before that, his father Sharief (popularly known as Mian-ji by locals) had been in the trade for many years. They have also diversified into repairing front axle CV joints.
New Delhi Meter Shop, as his establishment is called, is located at the Sukhdev Market opposite Defence Colony, at the far end of Kotla Mubarakpur (see map below).
Work handled:
  • Repair of all types of automotive meters, both mechanical and electronic, including speedometers, odometers, fuel and temperature meters, RPM meters etc.
  • Repair of front axle CV joints
  • Repair of shock absorber struts and hydraulic damper units
  • Repair of motors of motorized ORVMs
  • Repair / low cost replacement of broken tail lamps & headlamps with used units
What I like:
  • Quick, confident and efficient work
  • Short-term warranty for work done
What I don't like:
  • Located in a very crowded place where parking is a headache - but then Javed has his understanding with other repairers, and they make space for each other.
Pricing:
  • Feels a little steep, but worth it considering your other option is to spend a whole lot more to replace a complete meter unit / axle unit / ORVM.
What I have used his services for:
  • My ageing Swift (8 years, 90,000 km) had its speedometer needle stop working a couple of days ago. Everything else was working fine. A new speedo console was recommended, and the price is over Rs.6000. Seems Swifts of this model do have this problem in many of the cars. Javed opened up the console and replaced the motor that drives the needle, reloaded the software in the chip inside, and we were back to a normally working meter in 1 hour flat! The cost: Rs.1600. Time taken: 1 hour.
  • The Swift's left ORVM was not adjusting properly (an internal cable was broken) - Javed replaced the unit with a second-hand one for Rs.500.
Contact information:
Name of the contact person: Javed
Phone numbers: 8826266458 (Javed); 7838672830 (Javed's father, Sharief); 9818370812 (Javed's brother, Sajid).
Postal address: A-162 Sukhdev Market, Kotla Mubarakpur, opposite Defence Colony, New Delhi 110003.
Working hours: 10 AM to 6 PM, closed on Mondays.
Google map:
https://goo.gl/maps/Yy4WT
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-map.jpg
Photos
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed2.jpg
Javed's father Mian-ji Sharief minds the front office nowadays
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed4.jpg
Javed in action
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed5.jpg
He's taken off the meter console in less than 10 minutes
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed6.jpg
Javed's workbench for repairing meters
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed6.5.jpg
The white units attached to the PCB are the motors for the RPM, fuel, temp and speedo needles
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed7.jpg
Meter console dismantled and being repaired
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed8.jpg
Testing the repaired unit
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed9.jpg
The customary *chai*
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed10.jpg
Collection of old CV joints
Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)-javed11.jpg
Collection of dampers in various stages of repair
SS-Traveller is offline   (4) Thanks Reply With Quote
Old 29th November 2014, 20:27   #2
fine69's Avatar
Thanked: 883 Times
Default re: Repair of Automotive Meters, Axles, Dampers & ORVMs - Javed (New Delhi)
Does he stock OEM meter consoles? I'm interested to know if guys like him can get me a Vdi console in my Ldi at a cheaper rate.
fine69 is offline   Reply With Quote
Old 29th November 2014, 23:32   #3
^^^ I would think he can do a swap like that. Why don't you call and ask him?
Body Repair & Painting, Glass Repair, Detailing etc. - Trend Automobiles (Bangalore) decode Bangalore 291 16th June 2018 10:59
Indian Diff-Lock for the Dana44 19 & 30 Spline Axles ex670c 4x4 Technical 32 29th October 2016 12:20
Fiat Uno dampers gpkmahe Technical Stuff 11 10th March 2009 21:33
Renault's Mass Dampers Declared Illegal jraj Int'l Motorsport 1 24th August 2006 12:45
Fire in Meerut and BraveHeart Javed !! man23ish Shifting gears 1 15th April 2006 22:02
