Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 19th April 2012, 20:44   #31
Blow Horn Ok's Avatar
Thanked: 371 Times
Default Re: Exhaustive DIY: Cabin AC Filter cleaning of the Ford Figo
As gemini said, his car's AC filter was replaced at the F.A.S.S in just few minutes. So I guess there may be some other short-cut to access the filter (known to mechanics). But as a DIY,I am sure that the way I accessed the filter was the only way to get it done.
The filter is behind the gear lever console, and that console is a single piece. So it had to be taken apart. Also the filter is not flexible so that it could be bent and removed without any interference with the fuse box. Due to this the fuse box was required to be dismantled.
Blow Horn Ok is offline   Reply With Quote
Old 21st April 2012, 01:08   #32
Thanked: 172 Times
Amazingly documented, Very well explained. but i will like to mentioned that there is no need to remove the center console for the procedure, when i cleaned the AC filter all that i remeved was the Glove box removed the Fuse box and then was able to remove the AC filter,
desideep is offline   (1) Thanks Reply With Quote
Old 21st April 2012, 08:34   #33
Thanked: 371 Times
The filter cover, which is fixed by 6 screws is half behind the console. ie, almost 3 screws are behind the center console plastic shroud. How did you unscrewed them without removing the console?
Blow Horn Ok is offline   (1) Thanks Reply With Quote
Old 28th April 2012, 12:08   #34
Optimus7's Avatar
Thanked: 12 Times
Originally Posted by Optimus7 View Post
Great DIY BHO.
Can someone tell me if the procedure is the same for the Fiesta classic? My air-con is getting a bit smelly if the AC is switched off.
Any fiesta owners can you please comment on this?
Optimus7 is offline   Reply With Quote
Old 29th April 2012, 18:05   #35
Thanked: 371 Times
Optimus7: I am sure the fiesta's filter must be at the same place as of the figo. Check it out.
Old 2nd May 2012, 09:55   #36
mmxylorider's Avatar
Thanked: 184 Times
Default Re: DIY: Cabin AC Filter cleaning of the Mahindra Xylo E8.
Originally Posted by IndigoXLGrandDi View Post
1) First remove the covers which hide the screws inside the glove-box.
Use a screw-driver to remove the same--
Fantastic detailed instructions . I cleaned my Xylo's filter yesterday and it took just 10 minutes to get to the filter using these directions. For a running of about 30K, there was considerable dust and leaves/twigs on the filter. Cleaning was easy using soap and low pressure water. I was done in under 20 minutes. There is now a noticeable improvement in the AC performance/volume of air entering the cabin.
Note: I have a E4 and it does not come with the damper as is the case of E8.
mmxylorider is offline   Reply With Quote
Old 15th June 2012, 17:29   #37
Thanked: 36 Times
I did this in my Fiesta S too. This was done after 30000km.
The first impressions after this cleaning procedure were-
1. Slight Improvement in AC performance (cooler air)
2. No more slight foul smell that I had before
abhipuru16 is offline   Reply With Quote
Old 15th June 2012, 17:36   #38
Thanked: 371 Times
You removed the center console to access the filter? What about the fuse box?
Old 15th June 2012, 18:07   #39
Thanked: 36 Times
Just the LHS panel. It is held on by a plastic screw and two clips. You just have to remove the screw (requires quite some fiddling) and then pull the panel near the gear lever side to pull out the two clips.
And yes, the fuse box needs to be removed. Don't worry, just remove the two bolts that you can see and remove by pushing upwards and then towards yourself. You will NOT break it, it is pretty solidly built. Just to be on the safe side, remove the negative from the battery.
After that, its very easy to take out the filter and clean it.
It does make a difference as I told you before.
Old 15th June 2012, 18:28   #40
Thanked: 110 Times
Nice thread. Does anyone know how to access the pollen filter on a Skoda Fabia 1.6?
mb_jg is offline   Reply With Quote
Old 15th June 2012, 19:07   #41
Thanked: 371 Times
I guess fiesta's center panel has removable side shrouds.. In the figo it is a single piece unit. Therefore the entire console has to be taken out.
Old 31st May 2014, 14:14   #42
Thanked: 704 Times
If the AC is used with the recirculation mode always, should the cowl filter still need to be replaced periodically?
ramzsys is offline   (1) Thanks Reply With Quote
Old 1st May 2016, 16:17   #43
dhinchak's Avatar
Thanked: 16 Times
I cleaned the AC wire mesh filter of my Figo today. I did not have to remove the complete centre console. Just removing the left side screws and renoving the fuse box did the trick for me. The panel is soft plastic and bends easily, making it easy to pull out the filter.
Strangely, the filter was not that dirty, having been driven in Delhi's pollution for 85k km
dhinchak is offline   Reply With Quote
Old 21st September 2016, 08:42   #44
Catalyst_delhi's Avatar
Thanked: 148 Times
Same here - Drive around in Delhi and Noida but filter was relatively clean. Maybe since I never use outside air it is clean. I wanted to know if there is another filter that has to be cleaned near the wipers?
Catalyst_delhi is offline   (1) Thanks Reply With Quote
Old 19th January 2017, 23:59   #45
revvenant's Avatar
Thanked: 33 Times
Has anyone tried cleaning the air filter on the new Ford Figo? Is the procedure the same as described in this thread or is there any difference? My 1 yr old Ford Figo Titanium Tdci is almost 16k and I do feel a reduction in the cooling efficiency as well as some odour when the Climate Control is turned on.
revvenant is offline   Reply With Quote
Ford Figo 1.2 petrol LXi 2011 - An exhaustive summary DevilsCry Test-Drives & Initial Ownership Reports 45 20th January 2017 18:17
Mitsubishi Cedia DIY - Cabin Air Filter Installation Captain Slow DIY - Do it yourself 1 27th May 2013 10:14
Cabin Filter for Swift : Want to do DIY manjubp DIY - Do it yourself 38 20th June 2012 19:53
