Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 16th May 2012, 14:43   #136
deehunk's Avatar
Thanked: 1,015 Times
Default Re: DIY - Removing Sunfilm + what not to do
Ask for thinner in Hardware shop, it will have a nice smell compared to normal turpentine, this will remove all traces of glue easily. A small knife is useful to remove the sunfilm at edges than a blade.
deehunk is offline   Reply With Quote
Old 16th May 2012, 15:30   #137
Vid6639's Avatar
Thanked: 21,086 Times
Yes apart from removing the glue from the glass it will also remove the paint from your car if you spill a few drops and probably ruin all plastic door pads.
Paint thinner should not be used what so ever.
Old 16th May 2012, 15:33   #138
Tushargohil's Avatar
Thanked: 71 Times
hey guys... is that true that removing sun film is on hold??? can someone check bangalore FB page?
its time to get something like this ? :-) back to 10 years from now.... full privacy and easy to maintain too
http://www.qualir.com/images/car_curtains.jpg
http://www.aliexpress.com/product-fm...olesalers.html
Tushargohil is offline   Reply With Quote
Old 16th May 2012, 15:58   #139
rajshenoy's Avatar
Thanked: 763 Times
Wholesale Via car curtain car Toyota Puri Special factory outlets
I checked BTP FB page, there is no such update. How did you get to know such rumor ? did you not check FB page yourself ?
rajshenoy is offline   Reply With Quote
Old 16th May 2012, 16:03   #140
HighOctane's Avatar
Thanked: 178 Times
Just now visited BTP on FB, no such hold is there. Just to wait and see, I will no remove sunfilm now and will go to office in 2 wheeler from monday onwards and in case, if I really need car, I will roll down all the windows and drive. It wont be that easy for cops to spot me.
HighOctane is offline   (1) Thanks Reply With Quote
Old 16th May 2012, 16:12   #141
aa_asif's Avatar
Thanked: 42 Times
SIMPLE & STRAIGHT STORY
2 Steps:
1. Bake the car under the Sun for 2-3 hours.
2. Once baked properly, Peel of the film with both the hands slowly and steadily giving no jerks. Its comes out like a banana skin leaving absolutely no marks behind.
Note: This also worked amazingly on my rear windscreen with defogger on it.
After peeling off the film, no washing or cleaning was required as I couldn't find any glue marks with my naked eye.
Asif
aa_asif is offline   Reply With Quote
Old 16th May 2012, 17:43   #142
mpksuhas's Avatar
Thanked: 4,130 Times
Guys, even if the glue after removal of film is not visible much just wipe the glass with any glass cleaner once. Had once removed film from our car couple of years back and left the glass untouched since no much glue was visible. However once it started raining and moisture started forming on inner surface of glass it was becoming bit translucent. Like windshield will be if not properly cleaned.
mpksuhas is offline   Reply With Quote
Old 16th May 2012, 18:55   #143
Ricky_63's Avatar
Thanked: 394 Times
I had the film (a very light one) removed at the car accessory store, they were removing film from atleast 20 cars a day if not more ! The 4 windows were a 5 minute job. The rear defogger thingy also was fast but removing the residual glue took about an hour & half a litre of petrol !!
Old 16th May 2012, 19:06   #144
rahul4640's Avatar
Thanked: 309 Times
Gentlemen,
I had installed sunfilm in my car at least four years ago. Is there any special step needed to remove old sunfilms? Or the simple DIY instructions I get to see here will be sufficient to remove it? Please advice.
rahul4640 is offline   Reply With Quote
Old 16th May 2012, 19:31   #145
condor's Avatar
Thanked: 4,907 Times
hi Rahul, nothing special required. Just follow the way it has been described here. I just removed 6.5 yr old film from my Sumo, without any problems.
Old 16th May 2012, 19:56   #146
funkykar's Avatar
Thanked: 1,743 Times
Ok you DIY guys.. Here is a tricky one. I'm trying to remove the sun film of my 30 year old FIAT. The windshield is off the car as the FIAT is being restored.
I tried all the methods mentioned in this thread. But partially successful.
The sunfilm is just badly stuck to the glass. It's coming off in bits when tried with a blade. Used colin, hot water etc.
What do I do now?
funkykar is online now   Reply With Quote
Old 16th May 2012, 19:58   #147
condor's Avatar
Karthik, can you soak the glass in water ?
condor is offline   (1) Thanks Reply With Quote
Old 16th May 2012, 20:01   #148
funkykar's Avatar
It's the rear windshield. I can try soaking it in the bath tub now with hot water! Let me try!
Edit: Oops, forgot that on the other side of the windshield, there is a very nostalgic sticker. I don't want that to get screwed in hot water!
Old 16th May 2012, 20:23   #149
thoma's Avatar
Thanked: 1,112 Times
Normal water should do. Handling the glass after dipping in hot water might develop stress cracks. Just keep a towel dipped in water at the side of the film. Keep on watering it when it dries. I think the film sticks to the glass with age and gets brittle too.
thoma is offline   (1) Thanks Reply With Quote
Old 16th May 2012, 20:38   #150
mayankk's Avatar
Thanked: 3,559 Times
Did you do the soaked newspaper thing?
15-20 minutes should get it off, I would think.
mayankk is offline   Reply With Quote
Front windscreen sunfilm? Samurai Modifications & Accessories 2240 28th May 2018 15:35
VW Polo DIY: Removing / upgrading the instrument cluster Gannu_1 DIY - Do it yourself 29 21st March 2018 17:36
Windows vibrating & making noise after removing Sunfilm amolbh Technical Stuff 9 20th January 2014 22:59
My DIY : Cheap Magnetic Light. A not-so-unique solution to a not-so-unique problem torquecurve DIY - Do it yourself 32 17th May 2011 13:22
Settings gone after removing HU and removing key achopraa In-Car Entertainment 14 15th December 2007 22:18
