Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 16th May 2012, 20:45   #151
IQBAL VEERJI's Avatar
Thanked: 291 Times
Default Re: DIY - Removing Sunfilm + what not to do
I just read in the face book ,our Mr.Pavan ji, has shown his SUV with the Sun film removed and someone said that Sun control film makers have taken a stay order on the rule by supreme court, not knowing the truth.Others pls correct me if I am wrong.
IQBAL VEERJI is offline   Reply With Quote
Old 16th May 2012, 21:01   #152
funkykar's Avatar
Thanked: 1,743 Times
Did you do the soaked newspaper thing?
15-20 minutes should get it off, I would think.
Just did that and also poured boiling hot water. Now its better as longer pieces are coming out. But still it's tough going. The film isn't coming off from a putty blade, hence using a blade. So its taking lots of time.
funkykar is online now   Reply With Quote
Old 16th May 2012, 21:32   #153
condor's Avatar
Thanked: 4,907 Times
Karthik, pls try the old style shaving blades. Those are much thinner than the folding blades / paper cutters we get in the stationery shops
condor is offline   (1) Thanks Reply With Quote
Old 17th May 2012, 09:22   #154
rajshenoy's Avatar
Thanked: 763 Times
Yesterday night, i tried DIY on my rear quarter glass. It took me about 20 mins to clean just one quarter glass. Just used Mr Muscle,Water and finger nails.
After first glass, i had learnt enough lessons.
Key is to make sure that the film does not leave pieces. It should come off in one piece. If it partially comes out, then it is a struggle to then remove the remaining pieces
Quarter glass sun-films is one of the toughest to remove, because there are no edges exposed(side windows should be easier)
So i applied this logic on second quarter glass, and the whole film came out fully in couple of minutes. In 5 mins the glass was clean.
For Todays Agenda i have the rear window(and rear side windows if i get time) and finish it off on Friday.
rajshenoy is offline   Reply With Quote
Old 17th May 2012, 10:03   #155
Thanks to all for such detailed discussion on various approaches.
Today morning, I removed the Sunfilm from my Safari. With a paper-cutter and a shampoo solution, it was quite easy. It took close to 2 hours for the cleaning up all the windows.
Getting the film out of all the glasses was quite easy. The hard part was removing the gum. Initially, I tried using the putty blade, but was not so successful in removing the gum.
Then, a car wash guy approached me and showed me how to use the paper cutter. It seems he works in a Car accessory shop and they have been doing the same all day from past week. He also gave the tip that Clinic Plus shampoo works the best (though I have not tried).
anilrs is offline   Reply With Quote
Old 17th May 2012, 13:06   #156
intoxicangel's Avatar
Had the gum on the windows for 3 days now... Finally tried something that is even simpler and easier to use
- Dab cotton waste (or anything else) with a little petrol
- Rub the material in small portions over the gum
- Use a soft scrub pad
- Gum comes off with ease
Tried it with the rear windshield, in less then 5 mins had all the gum off
Next, use Cif or any other liquid soap to clean the petrol off and get rid of the petrol smell as well...
intoxicangel is offline   (1) Thanks Reply With Quote
Old 17th May 2012, 20:22   #157
rajshenoy's Avatar
Thanked: 763 Times
OK, I finally got the sun films removed from all the windows. My Swift now feels roomier(had these sunfilms from day one)
Only sad part is .. every bit of interior is now visible(i could spot the tiny paper cutter that i left behind inside the car in no time)
Here is what i did.
1. Took a bowl of boiling water(pour little by little from a flask, so that it stays boiling hot for 30-40 mins)
2.Dip a cloth in this hot water and keep applying this over the edges of the sunfilm.
3. Peel the sunfilm edge using fingertips(if required, give a small cut from the blade)
4. once you get hold of the small bit of sun-film, just keep pulling it further and applying hot water at the same time.(do this real slow)
5. Whole film will come off in minutes without even breaking(and leaves very little residue as well)
6. For cleaning the glass residue, i used scotchbrite(and a bit of glass cleaner), wiped the glass clean with hot water again and started rubbing it with scotchbite.
Cleaning the residue is bit time consuming, but if the sunfilm is removed by applying hot water, it does not leave much residue thereby reducing your effort
rajshenoy is offline   (1) Thanks Reply With Quote
Old 17th May 2012, 22:12   #158
I tried my hand on the new Brio. Here is what I did
1. Used the facial steamer to peel off the film
2. Used petrol to remove the gum. (Petrol made life easy, after I tried soap with hot water, thinner etc)
The dealer was kind enough to provide the sunfilm without my request :-(
omatunto is offline   Reply With Quote
Old 18th May 2012, 09:07   #159
I removed the film on my Baleno yesterday. I had a Garware film on the side windows and back screen. The film as put when I had purchased the car 5 1/2 years back.
Started at 10 a.m.
- Made a small slit using a paper knife in the top middle part of the window.
- Pulled the film slowly. Was very careful near the corners. Do not use force at the corner, instead apply force about 3-4 inches from the corners.
- Took about 5-10 mins per window.
- There was a lot of gum left over. Most of them were not visible but when you pull the window down, you can hear the rubber at the corners crying.
- I used Mr. Muscle Window and Glass cleaner to remove the left over gum. It was not easy. Used a rough cotton cloth to rub the gum out. This took about 1 hour.
Completed all Windows and Back screen by 12:15 p.m. Take care of your palms after the job as Mr. Muscle will have a bad effect on your palms.
Lucky, the car had come with a green tint glass already.
sharat_m is offline   Reply With Quote
Old 18th May 2012, 09:44   #160
deepakr82's Avatar
Thanked: 15 Times
Originally Posted by Tushargohil View Post
hey guys... is that true that removing sun film is on hold??? can someone check bangalore FB page?
its time to get something like this ? :-) back to 10 years from now.... full privacy and easy to maintain too
http://www.qualir.com/images/car_curtains.jpg
Wholesale Via car curtain car Toyota Puri Special factory outlets
Check this link, these curtains are easy to use and remote operated. Need to enquire the cost. Amritras India | Offers high quality car window curtains to ensure privacy and comfort in your ride.
deepakr82 is offline   (1) Thanks Reply With Quote
Old 18th May 2012, 11:46   #161
speedmiester's Avatar
Thanked: 932 Times
I removed the sun films from my zen today morning, took me 30 minutes and a small pocket blade. Did not use any solution or anything, the film did not leave any glue on the glass as well.
Car feels roomy and naked at the same time. :(
speedmiester is online now   Reply With Quote
Old 18th May 2012, 12:01   #162
Jaggu's Avatar
Thanked: 8,693 Times
Guys few things to keep in mind.
1) You cant predict if the film is going to leave residue or not, depends on the age and quality of the film.
2) Though if you are careful and do the removal slowly, then chances are less/minimal.
3) For cleaning gum never use a blade or scotch bite directly. Ensure you spray some solvent, shampoo/glass cleaner/petrol etc and then use the blade etc to remove.
4) If you see gum on glass, leave the film hanging from the bottom edge, this will keep the gum away from seeping into the weather strip and falling over the door pad etc.
Hope this helps.
Jaggu is offline   (7) Thanks Reply With Quote
Old 18th May 2012, 13:39   #163
Thanked: 846 Times
Read this news about extension in deadline for Sunfilm Removal till June 5th in Bangalore.
The Hindu : Cities / Bangalore : Sun film removal deadline extended till June 5
Not sure about other cities.
-Ravi
ravib is offline   Reply With Quote
Old 18th May 2012, 17:17   #164
Sweet Chariot's Avatar
-Ravi
I am glad they extended the deadline in bangalore to june 5th 2012, how i wish the year was also extended.
there was an article in deccan hearald too:
http://www.deccanherald.com/content/...-extended.html
strangely they have incresed the penalty amount from 100 for the first offence to Rs 300 now.and repaters will have to cough up Rs 500 for committing the offence a second time. If the act is repeated for the third time, the police will seize the vehicle.
Last edited by Jaggu : 18th May 2012 at 17:34. Reason: Removing [Font] tags, please avoid Copy paste from external font editors, also do a Preview before Submitting posts. Thanks
Sweet Chariot is offline   Reply With Quote
Old 18th May 2012, 19:08   #165
Lukeskywalker's Avatar
Thanked: 1,170 Times
Very true, I used scotch brite on a small portion of the quarter glass, it leaves scratches, I used Amway grease cleaner solution and a small piece of steel wool, all residue comes off easily once soaked in a soapy solution, glass wool leaves no scratches, just don't rub too hard.
Lukeskywalker is offline   Reply With Quote
Front windscreen sunfilm? Samurai Modifications & Accessories 2240 28th May 2018 15:35
VW Polo DIY: Removing / upgrading the instrument cluster Gannu_1 DIY - Do it yourself 29 21st March 2018 17:36
Windows vibrating & making noise after removing Sunfilm amolbh Technical Stuff 9 20th January 2014 22:59
My DIY : Cheap Magnetic Light. A not-so-unique solution to a not-so-unique problem torquecurve DIY - Do it yourself 32 17th May 2011 13:22
Settings gone after removing HU and removing key achopraa In-Car Entertainment 14 15th December 2007 22:18
