Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 13th February 2013, 16:35   #301
9thsphinx's Avatar
Thanked: 468 Times
Default Re: DIY - Removing Sunfilm + what not to do
Got those nice 3M films off my Jazz yesterday. My driver took the initiative and the entire removal was done using a blade, a credit card, some clear no-smell spirit and a damp cloth. Process took about an hour but cleaning the glass post the spirit and damp cloth application was a headache. Specially the rear quarter glass is obstructed with those seatbelts and cleaning them was not easy. However, it's all done and the Jazz is now ready to embrace the oncoming summer with open arms
9thsphinx is offline   Reply With Quote
Old 13th February 2013, 18:48   #302
StrangeWizard's Avatar
Thanked: 229 Times
Got caught twice for the sunfilms. Once the RC Card was confiscated, so I went to the chowky 30 mins later and paid the fine without actually removing the sunfilms
Then last week I was stopped near my college and the cop said he'll either take my license and I'll have to go to the chowky, or we can settle it here. I said I don't have change and nor do I have the time to go to the chowky (in a polite tone), he let me go
I have Garware films and I tried removing it from the left rear window first. I just peeled it with one hand and it came out pretty easily in 2 pieces. There seems to be some glue residue so that I'll try removing with water whenever I get time and also get rid of the film from the other glasses.
StrangeWizard is offline   Reply With Quote
Old 18th February 2013, 13:23   #303
Thanked: 12 Times
Dude, why not spend odd Rs 300 and get it removed by professionals ??
BTW my kid cousin in Delhi Univ just told me that Girls out there are readying for "Brick the Tinted" Glasses they see in the campus area. With Strict SC order and a bunch of girls doing in Mob, I think even Police wont help the victims (???)
ujjwaana is offline   Reply With Quote
Old 18th April 2013, 09:47   #304
mayankk's Avatar
Thanked: 3,559 Times
Seems to be an exercise in futility now, with these kind of cars roaming.
Hell, my film was allowing at least a view inside the car, albeit a little tinted.
How can this be legal?
mayankk is offline   Reply With Quote
Old 12th May 2013, 05:58   #305
Thanked: 461 Times
Just wanted to share my experience: I asked the service center to remove the film and they flatly refused saying there are no people with them who deal with sun films and advised to get it done from outside. So it was done to DIY.
As pointed by all, removing the film was matter of minutes, hardly 5 minutes per window. It was the glue which was the problem. I tried Thinner, Colin etc.
Finally, what worked was applying "hot water" and scrubbing using scotch brite stainless steel scrubber. There were no scratches and glue came off easily. Each window took around 10 minutes.
One more thing which I noticed in my case was that the power windows failed to slide properly (were getting stuck) once the film was removed. The glue was preventing the windows from sliding properly. Once the glue is removed, windows worked normally.
Simhi is offline   (1) Thanks Reply With Quote
Old 13th May 2013, 19:06   #306
Thanked: 420 Times
I did DIY removal eons ago but glue remained and I was too lazy to clean it.
Finally cleaned the glue yesterday by following method.
1. Sprayed a bit of WD40 on the glass.
2. Rubbed a little with a cloth with very little 3M rubbing compound
Actually I did not apply 3M compound explicetly but the cloth was used previously for body rubbing and it worked
amitk26 is offline   Reply With Quote
Old 12th July 2013, 22:25   #307
junaid12345678's Avatar
Thanked: 81 Times
I removed my Lumar tints yesterday, yes almost an year after the ban was imposed. All the job took approximately ten minutes. I used a blade to lift off the edge and peeled by hand. All the film came off in just one piece but surprisingly with no gum residues. I think the glue remains on the glass only applies to cheap films like Garware. Lumar, 3M, vkool don't have such problems, just peel if off. No heating, no mess.
junaid12345678 is offline   Reply With Quote
Old 13th July 2013, 09:05   #308
Thanked: 420 Times
Mine were 3M and costlier ones but glue traces remained and I had to clean by method described below.
Old 14th July 2013, 23:05   #309
Thanked: 81 Times
Don't know what happens actually. Mine were two years old and came off easily with zero gum residue. But a fellow bhpian shared that his Lumar tints left lot of messy glue. But another one tells his 3M came off with zero gum residue. It may also happen that the dealers are taking us for a ride by sticking cheap films instead of premium ones. It is also possible that the quality of glue may be different/cheap.
Old 18th July 2013, 20:15   #310
ghpk's Avatar
Thanked: 193 Times
Thanks for this thread.
After reading it last week I decided to remove the sunfilm on OWN.
Mine was not the branded ones, and not the darkest ones.
Today it was quite sunny, so parked the car outside garage
left there for around 4 hours.
Once it was very hot inside, Used the Paper Cutter to take out a corner and then hold and pull off the film.
It took me 10 minutes to remove all sun-films. Mostly in one piece.
Only the driver side window has some portions of GUM remaining, will be cleaning it tomorrow.
Old 29th July 2013, 16:24   #311
funkyp's Avatar
Thanked: 97 Times
looks like the drive for sunfilm removal has intensified in Mumbai. I was stopped by a cop (not a traffic cop) yesterday next to inorbit mall malad for the tints on my glass. i tried to get away saying these were within the prescribed limit but the cop clearly quoted the supreme court order.
They wanted to confiscate the license, which i would have to collect from the office in worli after showing the tint free car to the officer there and paying any fine applicable. I managed to get away by paying a fine (200 bucks). The cop asked me to ensure the tints are off or i risk getting caught again.
have other also faced similar checks in Mumbai? if the drive continues i will get the tints removed :(
funkyp is offline   Reply With Quote
Old 2nd October 2013, 12:27   #312
Siddy's Avatar
Thanked: 93 Times
Did a clean removal today!!
Things i needed:
1. Dishwash liquid
2. Cloth
3. Steel scruber
4. Blade
Procedure:
1. Removed all films very very slowly. Lifted corners of the film with the blade and the trick here is to pull the film very slowly which leaves very less residue
2. Sprayed the dishwash liquid and scrubbed with the steel scrubber
3. Sprayed some more and cleaned with cloth
Ta da!! All done.. No heating and no money spent.. May be i burned a few calories in the process!
Siddy is offline   Reply With Quote
Old 20th January 2014, 18:50   #313
Bangalore cops have started imposing the fine. A colleague of mine while I was with him this afternoon was stopped near Hosur Road Cemetery junction and paid Rs.100.
Also saw cops near Trinity circle stopping four wheelers with sun film.
keyank is offline   Reply With Quote
Old 20th January 2014, 21:34   #314
Thanked: 11,076 Times
Originally Posted by keyank View Post
Bangalore cops have started imposing the fine. A colleague of mine while I was with him this afternoon was stopped near Hosur Road Cemetery junction and paid Rs.100. Also saw cops near Trinity circle stopping four wheelers with sun film.
Was this a dark grey Fortuner? I passed by and saw this stopped. They were checking at the traffics light outside UB city yesterday
Old 21st January 2014, 11:34   #315
No my colleague's was a red swift, he had a very light sun film. still was challaned
Front windscreen sunfilm? Samurai Modifications & Accessories 2240 28th May 2018 15:35
VW Polo DIY: Removing / upgrading the instrument cluster Gannu_1 DIY - Do it yourself 29 21st March 2018 17:36
Windows vibrating & making noise after removing Sunfilm amolbh Technical Stuff 9 20th January 2014 22:59
My DIY : Cheap Magnetic Light. A not-so-unique solution to a not-so-unique problem torquecurve DIY - Do it yourself 32 17th May 2011 13:22
Settings gone after removing HU and removing key achopraa In-Car Entertainment 14 15th December 2007 22:18
