Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 21st January 2014, 11:57   #316
Thanked: 11,055 Times
Default Re: DIY - Removing Sunfilm + what not to do
Originally Posted by keyank View Post
No my colleague's was a red swift, he had a very light sun film. still was challaned
I had light sun film, I was waiting to see whether there would be a change in the court verdict. In past month, I got warned once and challaned over the weekend. I was passing that way after getting the film removed
Old 17th May 2014, 08:06   #317
Chris_Xtreme's Avatar
Thanked: 27 Times
Thanks for this thread. I removed my Garware Classic sunfilm reluctantly. Took almost 45 minutes to get it done for my Waggy which has a defogger.
Chris_Xtreme is offline   Reply With Quote
Old 17th May 2014, 10:21   #318
IronH4WK's Avatar
Thanked: 3,725 Times
even the CR-70 won't survive this onslaught of the sun film brigade? i was thinking of putting the CR-70 for the front and back windscreens as when i drive to work, i face the sun most of the time. the heat renders the A/C useless unless i crank it up, higher than usual.
IronH4WK is offline   Reply With Quote
Old 20th May 2014, 18:58   #319
nileshch's Avatar
Thanked: 377 Times
I have CR-70 on the front and back and it has helped a lot in reducing the heat in the cabin. In addition, I've gone for the edge to edge sunshades for the sides and they've helped too. Been through 3 states since the installation and it's been fine. Much to my surprise, I still see a lot of SUVs in Maharashtra with opaque films (<20% visibility)!
nileshch is offline   (1) Thanks Reply With Quote
Old 23rd May 2014, 19:08   #320
JLS
JLS's Avatar
Thanked: 111 Times
Actually, you have to ensure that following is taken care while doing installation:
1. On the windows, no area without film ( i.e. no glass border without film should be visible, when windows are rolled down)
2. On the rear screen, installation without cuts - i.e. single piece installation
3. No bubbles or cuts all around - neat and clean installation
While choosing the films take care of the following:
1. Avoid films which has a visible tint - some films even with high degree of transparency have light blue or light tint, which will stand out. I think gray is better
2. Avoid films which are reflective
If you take care of the above, I believe nobody will be able to make out that you have a film applied on glasses.
Last week, I have put Garware Ice cool shield on my wind screen and some other Garware film (with 70% transparency and 35% heat rejection) on windows and rear glass. My experience is that unless told, and even after that it is very difficult to notice that there is a film on the glass.
So, in nut shell, if you go for CR70 type film, and ensure good installation, I believe police on road would not be able to detect that.
Hope this helps.
JLS
JLS is online now   (1) Thanks Reply With Quote
Old 9th June 2014, 13:22   #321
Thanked: 99 Times
Had legal films fixed on my Gypsy King 2011 5-door, and was procrastinating on removing them after the Supreme Court's total ban. Reasons being a) Calcutta/WB police are still ignoring light films, and b) they normally do not touch a white Gypsy even for other small violations. But when another ruling party MLA went on a rampage in his dark-tinted SUV, I braced myself as such incidents backfire on the common people.
Sure enough, on Saturday 7th June, a Govt. of India stickered Indigo CS (yellow number plate- contract car) just in front of me at a red light was stopped for its light-tinted, previously legal film l. I was thinking that if it had a "Govt. of WB" sticker, cops would not have dared! But they still ignored me !
Deciding not to push my luck any further, I resolved to remove the sunfilms myself on Sunday, but was not sure how. When it struck me to search TBHP fora for a solution, I was rewarded with volumes of experiences and opinions.
But scared with the options of 'reverse engineering', wet newsprint, ethyl alcohol, petrol, diesel, kerosene, WD40, Colinspray, solar heating etc. I decided to push my luck again !
Simply scratched a corner of each window with thumbnail, pulled evenly & firmly and the more than 3-yr old Garware films all came out within an hour (including rest stops)! There was no gum residue either, probably because I did not use any water!
Now I shall have to explore the expensive option of fitting transparent film all around -- if no tint is visible, the cops surely will not bother!
SnakemanJohny is offline   Reply With Quote
Old 12th June 2014, 18:46   #322
Thanked: 99 Times
Seems to be an exercise in futility now, with these kind of cars roaming.
Hell, my film was allowing at least a view inside the car, albeit a little tinted.
How can this be legal?
This may be legal only in a parked car, e.g. one left standing all day outdoors. But if this one was on the move, policemen still may not stop it unless there is a compounding offence, such as having disobeyed a red light, which brings attention to the screens.
Old 28th July 2014, 16:19   #323
Thanked: 187 Times
Was stopped last saturday on Indiranagar 80 feet road/Old Madras road junction for having sunfilm. Was let off without any fine and a warning to 'remove it quickly'.
Need to find time to do this soon.
WindRide is offline   Reply With Quote
Old 3rd August 2014, 13:42   #324
Thanked: 99 Times
Strangely enough, cops in Calcutta as well in rest of WB are not doing anything to get sunfilm removed wholesale -- only in case the vehicle in question commits some other violation !
As a result new cars are still installing the film, sometimes quite dark to have been disqualified even earlier. Feel so foolish to have removed Rs.1200/- worth of ordinary Garware. Am now getting quotations of 8500/- to 9500/- for Garware Icecool Elite, for a Gypsy 5-ddor (all panes except windscreen) !
Old 2nd February 2015, 09:38   #325
Thanked: 31 Times
Originally Posted by arvindmanju View Post
I removed the garware tint of my 11 year old car, i was able to remove the tint in one go, but not able to get the glue off. I tried my hands with colin no use, then used NC thinner to remove the glue of no use. Now the car looks even more dirty.
All efforts with colins, mr muscle, turpentine, thinner, kerosene, petrol, wd-40, etc will be waste of time. Use nail polish remover (or Acetone) and the residual gum will be dissolved in seconds and the glass will get spotless. This is a tried and tested thing.
arun_112 is offline   (1) Thanks Reply With Quote
Old 25th February 2015, 18:56   #326
Thanked: 99 Times
Last summer was horrible, with the weak A/C fitted in my Gypsy King by Calcutta's best (Daga Autolek) struggling to cope without assistance from any film, particularly in traffic jams.
Decided to go in for Garware Icecool , but had to wait till November for the rainy/cloudy days to be over, as everyone advised against installing sunfilm without strong sunlight, before and after !
But when the time came, I was dismayed to find that they do not have have the really transparent ones in stock, as nobody fits them ! As opposed to Icecool Elite, they advised, almost forced me to go in for 'Classic Lite', for half the price ( 4000/-). But I still have a tint, which may pass for tinted glasses provided by nearly all manufacturers since the total ban, except for the telltale strips on the rear ! And they refused to fit edge to edge on other windows too, saying it will peel quicker !
So I will pass every 'surprise sunfilm checkpoint' with heart palpitations, hoping that the 'White Gypsy Syndrome' will work (that it is a Govt. vehicle) before they look at the windows ! Police and VIP vehicles still use dark films here in Calcutta/WB.
If ever caught and fined/forced to remove film, I will have to really get the transparent ones, even if it means pushing the dealers to get it specially for me. For, like actress Vidya Balan, I cannot do without it. I read once that she keeps paying the fine but refuses to have the film removed ! But even she must have got a new car with light-tint glasses by now. Almost every car comes with shaded glass these days, except the Gypsy and Omni and Eeco !
Front windscreen sunfilm? Samurai Modifications & Accessories 2240 28th May 2018 15:35
VW Polo DIY: Removing / upgrading the instrument cluster Gannu_1 DIY - Do it yourself 29 21st March 2018 17:36
Windows vibrating & making noise after removing Sunfilm amolbh Technical Stuff 9 20th January 2014 22:59
My DIY : Cheap Magnetic Light. A not-so-unique solution to a not-so-unique problem torquecurve DIY - Do it yourself 32 17th May 2011 13:22
Settings gone after removing HU and removing key achopraa In-Car Entertainment 14 15th December 2007 22:18
