Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 7th September 2012, 17:55   #16
Default Re: DIY: Cleaning the Floor carpet & washing the seat covers
Originally Posted by Subrat Seet View Post
My santro is alomost 9 years old. Now water is coming inside (front passenger side). What could be the reason and therefore, it started smelling. Also, i wanted to do a thorough cleaning. Who does this kind of carpet and inside DIY cleaning in Mumbai. Help please.
Subrat
Water entering could be due to a damaged door beading / gasket on the bottom part of the door OR the drain plugs on the floor of the car. These plastic / rubber parts deteriorate with age and may break or tear. The drain plugs are the more likely cause.
The carpet may seem dry on top, but water will remain in the grooves and ridges on the metal floor causing bacterial buildup on the carpet and hence the smell.
The drain plugs are found on the floor, under the carpet. Get the service center to check the drain plugs and get them replaced if needed.
And as for 'who does DIY cleaning', the answer is you. DIY=Do It Yourself right?
Ayson is offline   (1) Thanks Reply With Quote
Old 7th September 2012, 23:02   #17
Thanked: 137 Times
Default Re: DIY: Cleaning Floor carpet & washing seat covers
Originally Posted by carbookie View Post
Images of
1. Car with front seats removed. If you notice the floor, you can see the place where the seat is held to the floor by nuts.
2. Nut placement for back seat.
3. How the seat covers were held in place.
4. Car with all seats gone. The carpet has been vacuumed, but I would subsequently go on to use brush.
I always had one doubt.
Some people say that when you wash the car carpet it simply means that its dirt has been rearranged within the carpet.
That is so because the dirty water can not be squeezed or wrung out from a fixed carpet.
I was pleasantly surprised to see your photos in which the carpet appeared reasonably clean.
Any suggestions?
skdking is offline   Reply With Quote
Old 8th September 2012, 00:19   #18
airfoil's Avatar
Thanked: 67 Times
Nice DIY.
Anyone have tips for cleaning the ceiling trim?
airfoil is online now   Reply With Quote
Old 10th September 2012, 20:27   #19
Subrat Seet's Avatar
Thanked: 346 Times
And as for 'who does DIY cleaning', the answer is you. DIY=Do It Yourself right?[/quote]
The bottom of the door has a hole due to rust, may be that is the cause.
Thanks for full form, i did not know the meaning. Thanks.
Subrat Seet is offline   Reply With Quote
Old 9th June 2016, 00:19   #20
GrammarNazi's Avatar
Thanked: 1,670 Times
Guys, couldn't find any specific thread but needed to know :
My clients toddler had a small incident in school & got a few blood stains on his white clothes.
He's going to try WD40, but I've tried that a while back for my white shirt & it didn't completely remove the stain.
White Vinegar worked wonders at another instance, but that time the stain & was fresh. Although then I guess regular use of strong washing powders made the cloth feel old.
Many people use a white towel on their seats. Would they have any idea what's a good way to clean a dried blood stain ?
Thanks!
GrammarNazi is online now   Reply With Quote
Old 10th June 2016, 17:18   #21
sidzz's Avatar
Thanked: 101 Times
Subrat
Refer to this thread: Here (Water Seepage Issue).
Summed up by GTO as below:
The most common causes of water seepage:
1. Windscreen sealing : Front & Rear.
2. Air-con piping, tray etc.
3. Clogged drain pipes (exterior). Due to leaves, dirt and so on.
4. Floor drain plugs.
5. Door beading, window seals etc.
sidzz is online now   Reply With Quote
Seat Covers: Choice Seat Zone, Royapettah pras.oct25 Chennai 40 28th October 2017 11:57
Slip on Seat Covers Vs Factory Fit seat covers Kärlsson Modifications & Accessories 18 29th June 2016 22:19
Renault Duster: Water leakage on the floor carpet. EDIT, now Solved! woodcrawler Technical Stuff 176 3rd June 2015 16:40
Valparai - The green carpet with great flora & fauna subbarp Travelogues 20 27th August 2012 15:07
Car washing and upholstery cleaning in koramangala ~~VinZ~~ Modifications & Accessories 41 7th May 2010 14:49
