Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 20th June 2012, 22:23   #16
racerdabba's Avatar
Thanked: 121 Times
Default re: DIY: The Short Shifter
Originally Posted by risham View Post
As i understand this you have shifted the fulcrum of the lever ( ball joint) towards the top end to achieve a short throw. So this should act sideways also. Is it so?
Theoretically it should, and does too, but somehow i feel the difference isn't noticeable. Just an illusion maybe.
racerdabba is offline   Reply With Quote
Old 18th November 2015, 19:36   #17
Thanked: 235 Times
Default Short Shifter for Bolero NGT 520 Gearbox
Has anybody done a Short Shifter mod on a Bolero NGT 520 Gearbox?
Is it possible? Is there any ready-made kit available? I basically want to bring up the lever a bit and reduce the throw.
I did come across this thread. http://www.team-bhp.com/forum/modifi...t-shifter.html
Thanks in advance.
-- Torqy
Torqy is offline   Reply With Quote
Old 29th November 2015, 13:32   #18
racerdabba's Avatar
Thanked: 121 Times
Default Re: Short Shifter for Bolero NGT 520 Gearbox
Originally Posted by Torqy View Post
Thanks in advance.
-- Torqy
If you can get me some pictures of the shifter assembly and linkages, i might be able to help. But then, the power needed for the Bolero NGT 520 gearbox is quite a bit even with the huge long shifter it has. It might be worse after the mod.
racerdabba is offline   (1) Thanks Reply With Quote
Old 12th December 2015, 19:41   #19
Thanked: 235 Times
I figured the shifter does not go "straight" into the box. It goes to the left side of the box with two L bends before reaching the fulcrum....making it pretty complicated. I'll just live with it.
-- Torqy
Indy-cator shifter knob? maven Modifications & Accessories 24 30th August 2013 12:05
short shifter for my corolla diven_b Modifications & Accessories 8 12th August 2011 16:36
Lancer Short-shifter? whatcanthisbe Modifications & Accessories 85 22nd July 2007 16:24
