Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 21st June 2012, 14:51   #1
dynomite's Avatar
Thanked: 78 Times
Default My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!
Hey - everyone - some of you may have seen the first couple of upgrades I did (primarily, 17-inch wheels and tyres, Type R spoiler) - here's a link to that post if anyone's interested - http://www.team-bhp.com/forum/tyre-a...ml#post2733369
But now, I thought I'd create a thread with all the mods I've just done, list out the accessories, ICE etc - rather than posting piece-meal to various different threads
First up - DIY automatic shift knob replacement.
I picked up one of these from ebay US
My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!-alpena-glide-shift-knob.jpg
UNIVERSAL AUTOMATIC PUSH BUTTON GEAR SHIFT KNOB BLUE | eBay
Cost me a total of Rs 920 (including shipping charges) - reached me fine, no customs, in good packaging.
This is a universal shift knob - fits most if not all automatic cars.
Here's how I installed it:
Step 1 - remove the silver sheath from the gear knob - this take a bit of work. I pried it off using a couple of screwdrivers
My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!-shift-knob-step-1.jpg
Step 2 - With the sheath removed, you'll see the two philips screws (shown by the red arrow, one on either side). Remove the screws and the gearknob will easily slide off.
Name:  Shift knob step 2.jpg
Step 3 - The shift stick now looks like this. The white stuff is grease, easily comes off with a dry cloth. The white plastic bit on top is what the button presses down on - to shift in/out of Park or into S mode.
My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!-shift-knob-step-3.jpg
Step 4 - The replacement shift knob slides on and has three tiny allen bolts - an allen key is also supplied.
Name:  Shift knob step 4.jpg
Step 5 - Place the knob and tighten the bolts, each one a little bit at a time to ensure that the knob stays straight. Test that it works.
My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!-shift-knob-step-5.jpg
Step 6 - Place the screws and sheath back on the original knob - this way, nothing gets lost and you can use it again if you want.
Name:  Shift knob step 6.jpg
Next up - replaced the Civic's stock license plate lights with single SMD LEDs
Name:  Rear license plate.jpg
Quite simple to do - just remove the screw-on tacks holding the lining in place.
You will see the holders for the bulbs - which is a standard T10 (wedge type) bulb.
Bought a pair of SMD LED T10 lights from ebay India for a ridiculously low sum.
Replace the bulbs with the LEDs, check that they work, replace lining and tacks - that's it.
Next - bought a pair of 25 LED (again T10, wedge type) bulbs for the parking light.
Name:  LED parking day.jpg
Cost me about Rs 400 from ebay India. The Civic parking bulbs are in the high beam reflector,
and there is enough space to allow these long bulbs to stick out, hence the choice.
Just twist out the holder for the old bulbs, replace with the new LEDs - and voila - super bright parking/DRL.
My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!-head-shot.jpg
here's a close up shot of the LED parking bulb lit up at night. In case anyone is wondering, those are MTEC bulbs - 4750K.
Name:  Lit LED parking.jpg
Attachments are limited, so Kiwi and ICE details follow.
dynomite is offline   (2) Thanks Reply With Quote
Old 21st June 2012, 15:05   #2
dynomite's Avatar
Thanked: 78 Times
Default Re: My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = awesomeness!
Now, about the PLX Kiwi Wifi OBD interface
Picked this one up from the US - Kiwi Wifi - PLX Devices Inc - USA - for $150. Basically, it plugs into the ODB port on any vehicle (except German cars) manufactured after 1996. Then it pulls data from all of the car's sensors & computers - to display on your iPad, iPhone or iPod, using one of the supported apps like Rev and DashCommand.
My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!-kiwi_wifi_retail_box.jpg
This is the location of the OBD port in the Civic - it's closer to central console.
Name:  OBD port location.jpg
Here's a close up of the device. It's small, really simple to use - plug it in, slide the power switch on and it creates its own WiFi network. From your iOS device, connect to the Wi-Fi and start the app - that's it.
Name:  PLX Kiwi closeup.jpg
Following are some photographs of the DashCommand app on my iPad.
Name:  20120620 17.52.05.jpg
I can get all sorts of data on it as you can see
Name:  20120620 17.53.29.jpg
With DashCommand, you can change skins - from within the app, you can download various skins - this is one that mimics the Nissan GT-R.
Name:  20120620 17.53.51.jpg
Note that as I press down on the accelerator pedal, the 'Accel Pedal' reading increases from 7 to 9% and the RPMs increase accordingly.
It's all happening real-time - with very little lag. I thought this was amazing, since there is no physical connection between the iPad and the OBD tool.
And of course, since Dash Command is compatible with 'select' Pioneer head units with Advanced App Mode, I can have the same interface on my new Pioneer AVH-P8490BT head unit (more follows in the next reply, where I detail the ICE upgrade.)
dynomite is offline   (3) Thanks Reply With Quote
Old 21st June 2012, 15:15   #3
dynomite's Avatar
Thanked: 78 Times
Now, on to the ICE Upgrade
This is a shot of the stock speakers in the Civic. The car came with the same speakers on the rear deck and front door.
Name:  Pathetic stock speaker.jpg
Quite a sad set - even the speaker cage is plastic, the cones feel like paper plates, magnets are the size of a stack of 10 rupee coins.
Name:  Stock speaker and insulation.jpg
I got a pair of Pioneer Component speakers (6.5-inch, A-Series, cost Rs 5600) - placed it into the stock front door location, but after some damping on the doors. The tweeters from the set went into the stock tweeter location in the corner of the dashboard
Name:  Damping front doors.jpg
Another couple of shots of the damping material - brand is Melly Mat. Costs Rs 1200 per roll, I used three rolls for the front doors and rear deck.
My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!-damping-sheet-1.jpg
Name:  Damping sheet 2.jpg
I got 6.5-inch, 4-way Pioneer coaxials in the rear (60W RMS, cost about Rs 3800 for the pair). Here you can see the speakers placed after the damping has been done. I wanted a completely stock look, so the installation was done accordingly.
Name:  Parcel tray damping.jpg
Here's the 4-channel amp - to send power to the four speakers - It's the Focal Solid 4, great amp. Looks good, compact, Rs 12,000.
Name:  Focal Solid 4.jpg
The head unit - from Pioneer's 2012 lineup, the latest AVH-P8490BT - high-res display, detachable face, DVD/CD, dual USB, SD slot, iPod/iPhone support, Bluetooth, camera input, Advanced App Mode (apps from your iOS device on the display). Rs 29,000.
Name:  Pride n Joy.jpg
Here's a shot of the rear speakers and amp installed in the boot. Clean install, note the size difference compared to the stock speakers, even though the diameter stays the same.
Name:  New rear speakers.jpg
Here's what it looks like when it's all put back together. The sound is about 400% of what it used to be. Much louder, cleaner, punchier bass. I really don't feel the need for a subwoofer right now. I also got a Pioneer steering wheel remote since my Civic doesn't have steering mounted controls. Note the Plx Kiwi Wifi OBD II interface near the gearshift. It is currently plugged into the OBD port - but I intend to hide the cable away.
Name:  Final product.jpg
Here's what the head unit looks - the blue colour of the theme nicely matches the Civic's default blue. Apart from the background image, the button colours on the head unit can be changed to any of hundreds of colours too.
Name:  8490 in action.jpg
Final pic - a quick shot of the Honda Logo, modified into a TBhp logo. A quick DIY again - the Red Honda logo that I bought got damaged, so I took it apart, stuck the black base back on the car, cut out one of the TBhp stickers and voila! Also note the tiny dome camera right under the Tbhp logo, above the license plate
Name:  Camera  Logo Mod.jpg
Next up - Brembo style caliper covers (already procured)
Mugen Badges for the bootlid (already procured)
K&N 69 Series Typhoon air intake kit
FFE (Fellow BHPians - am looking for recommendations here - options, prices, where to go etc)
Mugen style rain guards (again, need advice on price, where to buy)
dynomite is offline   (7) Thanks Reply With Quote
Old 21st June 2012, 15:59   #4
shuvc's Avatar
Thanked: 287 Times
Wonderful. Thank you for the details.
What is the price of the dash kit/adaptor for the HU ?
Old 21st June 2012, 16:01   #5
scorpian's Avatar
Thanked: 235 Times
Infractions: 0/1 (5)
Nice mods!
However i would strongly urge to reconsider your FFE,maybe a end can is all you need if your looking for the sound.
A close friend of mine had his civic FFe'd and had to go through hell of a time.Vibrations to the car which could not be sorted,and even a fall in power,the only thing he gained was noise which eventually he detested coz his civic was no longer smooth and refined.
Many would say that this was a one off case,nope the exhaust was removed and another complete assembly installed from another guy,same issues,finally we got the answer that FFE will have vibration and that stock exhaust is good enough for the car as its a honda.
In the end we ended up having two FFE which were just scrapped,the orignal exhaust refitted and now its bak to what it was.
Am not discouraging you just that want you to have that extra bit of info before you venture ahead.
All the best.
scorpian is offline   Reply With Quote
Old 21st June 2012, 16:13   #6
dynomite's Avatar
Thanked: 78 Times
Originally Posted by scorpian View Post
Nice mods!
All the best.
Hmm - ok, thanks for the input. Haven't heard that before. I was essentially looking at the FFE as a stage 1 mod - improving performance in conjunction with the Typhoon. Will look into it, and as you said, an end can might be more appropriate. Any suggestions for an end can? I would prefer a dual exhaust type, one that sort of matches the stock one.
Sure thing - whole Civic dash kit with all adapters set me back Rs 4000, I inspected it before it was place in, noticed the brand name Baolong Car Audio Company inside. It's obviously not OEM quality, but it's decent, looks good, matches the colour. If needed (and if it fades, cracks after a year or so, can be easily replaced).
dynomite is offline   (1) Thanks Reply With Quote
Old 21st June 2012, 18:53   #7
vinair's Avatar
Thanked: 976 Times
To be honest, the gearshift stick looks rather out of place mate, doesn't really gel with the overall interior color scheme.. try something in black/dark brown and chrome (just a little bit of it), that should complement to the rest of the interiors.
Also the engine and speed info gizmo, that really robs the thrill out of pure driving in my opinion!
vinair is offline   Reply With Quote
Old 21st June 2012, 19:06   #8
suhaas307's Avatar
Thanked: 6,953 Times
Nice mods!
All the best.
A free-flow exhaust, if fabricated by a reputed tuner, can actually improve the cars performance. Don't expect massive gains though. But as a stage-1 mod, it's a good way to start.
However, do ensure that the FFE is done well and installed correctly. A badly fabricated FFE can do more harm than good to your car's engine.
I had heard that the Civic's manifold/header cannot be replaced. Is this true?
Anyway, if it's sound you are after, an end-can should suffice. But if you want quality, you will have to spend a little more than you thought.
Remus makes good end-cans for the Civic in particular. You could also try Magnaflo exhausts. Read up about Automech, I've heard that they're pretty good too.
Buy I urge you to do as much research as you can before touching the internals of your car. Be as meticulous as you can. You should know what you're subjecting your car to. slap-on modifications may not give you the desired effect. Go about it meticulously.
Why don't you contact reputed tuners like Red-Rooster-Performance or Racetech. They are quite professional and should help you with your car and ensure that they get the best out of it too.
All the best!
suhaas307 is offline   (2) Thanks Reply With Quote
Old 22nd June 2012, 09:22   #9
mayankjha1806's Avatar
Thanked: 821 Times
Default Re: My Civic Mods + cool DIYs + Kiwi OBD tool + ICE upgrade = Awesomeness!
RRP does have good stuff for Civic, i paid them a visit to do something about the Baleno but they recommended modding the Civic instead. I am currently in no mood to do anything to Civic, until first four years. Once the warranty is over might thing about giving them a try.
There are a host of things that can be done, depending on budget and what is it that you are looking for from the mods. Paying them a visit is the best thing so as you get to understand the whole set of options and then choose ones that fit your need/budget.
Liked the set of mods that you did, especially the iPad app, looks lovely.
mayankjha1806 is offline   (1) Thanks Reply With Quote
Old 22nd June 2012, 10:12   #10
Vid6639's Avatar
Thanked: 21,086 Times
You can get a good exhaust made but not headers. The R18 engine has it's exhaust headers integrated into the block itself. There's only a single outlet of the block instead of 4 since the headers are integrated into the block.
Vid6639 is offline   (1) Thanks Reply With Quote
Old 22nd June 2012, 10:22   #11
m4ugr8's Avatar
Thanked: 123 Times
SpeedSport did the FFE on my car before I got the car turbo charged. SpeedSport prepared my car for the Redline drags with a custom FFE and NOS shot and the car ran beautifully, no vibrations or anything. The exhaust mounts are important when fabricating a new FFE, SpeedSport does a lot of full systems on daily basis, so I am sure they are well experienced.
SpeedSport are authorized dealers for RRP in Delhi so they source RRP products for you as well.
Where did you get this Head unit from ?? I have been searching the market for this model but can't find it. All of the mods are HOT, loved the iPad and OBDII integration.
m4ugr8 is offline   (1) Thanks Reply With Quote
Old 22nd June 2012, 11:10   #12
dynomite's Avatar
Thanked: 78 Times
Thanks Mayank - once you download the app, you can have it on an iPhone, iPod Touch, iPad or on the Pioneer 8490BT head unit. I don't have a warranty to worry about, hence the mods
All the best!
Thanks for the info Suhaas - I think I'll go with a replacement air intake first, then consider Remus or Magnaflow. I do know about Automech - I had bought a complete FFE (including replacement headers from them) for our Ikon 1.6 (many years back, think it was 2004). Any idea where I can get Remus/Magnaflow in Delhi? RRP and RaceTech are both Bangalore.
And as Vid66339 correctly pointed out, the Civic headers can't be replaced. If you look closely in the engine bay, there's just a single tube on which the oxygen sensor is mounted. Even the catalytic converter is in the engine bay.
Aah thanks Manan - was wondering about that. Could you PM me Speedsports location/numbers? Thx for the help.
The Pioneer AVH-P8490BT - yes, I had my eye on it for a long time. Finally picked it up from AutoMarc in Def Col (I stay just 5 mins away from him).
Well to each his own I guess. In my opinion, the blue shiftknob is far easier to use than the ugly stock one, somewhat matches the colour of the car, and almost exactly matches the colour of all the interior lights (including the head unit). Plus, it's not a permanent change - I can switch back to the stock one if I get bored - or any any other design (from the same US seller - doesn't cost much).
And the iPad app (DashCommand) is not up and running all the time. I mean, it's not like I keep the iPad mounted on the dash while driving. It's an enthusiast accessory, helps you know the car better, diagnose problems (if any) - plus it's great when you want to show off to techie friends
dynomite is offline   Reply With Quote
Old 22nd June 2012, 12:47   #13
suhaas307's Avatar
Thought as much
There is a Mitsubishi Lancer Cedia up north that has been tastefully modified by RRP http://www.team-bhp.com/forum/modifi...tsu-cedia.html (RRP Hyperdrive in a friend's Mitsu Cedia) I'm sure a quick contact search will help you
Racetech is also based in a few cities other than Bangalore.
Remus/Magnaflo can be sourced via several dealers. All you need to do is some research. Remus end-cans are supplied by Methods Automotive.
suhaas307 is offline   Reply With Quote
Old 23rd June 2012, 09:48   #14
m4ugr8's Avatar
Thanked: 123 Times
They are located in Chattarpur. Details to their google map location below. Contact person Phil @ +91-9818400027
28.485723,77.162089 (Mandi Road, Delhi, India) - Google Maps
m4ugr8 is offline   Reply With Quote
Old 29th July 2012, 13:43   #15
NOTORIOUS's Avatar
Thanked: 89 Times
Thats Awesome Bro
can you shred some more info on parking lights replacement and license light replacement SMD'S ???
looking for these for my verna
Thanx
NOTORIOUS is offline   Reply With Quote
My Skoda Yeti - DIYs, OE Upgrades & Custom Mods. UPDATE: Park Assist video on Page 8 ajaypjayaraj DIY - Do it yourself 188 4th February 2018 17:01
Hyundai i20 1.2L Asta - It's not cool; it's uber cool! manz Test-Drives & Initial Ownership Reports 49 28th January 2011 18:12
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
Hello from a kiwi Millecento nicegold90 Introduce yourself 12 22nd August 2008 21:58
The Kiwi Down under - Turbo Sales mazrx Shifting gears 1 25th January 2005 10:49
