Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 20th August 2012, 12:23   #31
ACMohan's Avatar
Thanked: 106 Times
Default Re: DIY: Headlamp Bezel Painting (Maruti Swift)
You can remove the dust by blowing air into the headlamp assembly. You have to remove the bumper for this. I'll have to remove the bumper again, if you need more pictures.
Here's a link to nikhilv12's post on Removing the bumper of Swift. (Remove Swift Grill?)
Hope that helps.
ACMohan is offline   Reply With Quote
Old 20th August 2012, 12:38   #32
mayankk's Avatar
Thanked: 3,490 Times
Hope that helps.
to blow air, why not just remove one bulb and point a hose in?
two, if youre going to be pedantic about exhaust...
mayankk is offline   (1) Thanks Reply With Quote
DIY Project: Automatic headlamp control using Arduino audioholic DIY - Do it yourself 32 2nd July 2017 11:22
DIY: Upgrading the headlamp bulbs of the Elite i20 hakunabatata DIY - Do it yourself 23 12th December 2016 15:00
DIY : Dismantling Fiesta headlamp & Painting the shrouds mayankk DIY - Do it yourself 20 9th May 2012 18:35
Wanted - Matiz Fog Lamps (Clear Full Lamp - Without Bezel) zzzehar Shifting gears 3 7th March 2012 15:47
