Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 5th November 2012, 07:50   #16
Catalyst_delhi's Avatar
Thanked: 149 Times
Default Re: DIY - Double Crank Prevention
Originally Posted by RM2488 View Post
It is impossible to double crank on my Ikon... mainly because you cannot physically turn the key after a crank attempt, even if it does not start the engine.
This is mechanically done with a ratchet setup in the cylinder. It is irritating sometimes as you have to take the key out to start again.
Catalyst_delhi is offline   Reply With Quote
Old 6th November 2012, 01:51   #17
ghpk's Avatar
Thanked: 193 Times
I am all in for this D.I.Y as a Santro Owner and a big D.I.Y types.
Let me dig some mud off my mind and get back on this, I would prefer a timer circuit to prevent a double crank after initial crank this would certainly help engine start smoothly then cut the chances of re-crank and then resets back to ready state once the key is not in IGN position.
Old 8th November 2012, 15:12   #18
Mr.Boss's Avatar
Thanked: 2,535 Times
Making a PAUSE on this project.
My friend taken back the car as he is traveling to his hometown for Diwali. Hope to continue after a week or two.
Mr.Boss is offline   Reply With Quote
Old 8th November 2012, 17:07   #19
Thanked: 110 Times
Palio has this mechanism but basically its a design with the key barrel assembly. The lock will engage while turning the key and stays in locked position so you cant crank again. Turning to OFF position will reset the lock so you can crank on more time. Pretty useful feature.
vijaycool is offline   Reply With Quote
Old 8th November 2012, 17:16   #20
vikram_d's Avatar
Thanked: 940 Times
Most Fords also have this feature. The Mondeo, Fiesta Classic and the new Fiesta have it for sure. Not sure about the other ones.
Old 8th November 2012, 21:29   #21
Thanked: 2,394 Times
^^ Sir how can that be used to prevent a double crank? Could you please explain?
Taking the logic of fuel pump being cutoff on impact, the default state will be logic 1. That if we invert, we will have logic 0 signal until there is an impact and only then will it turn to logic 1. That will help prevent cranking when there is an impact from what I can think of.
Pump powered => Engine running.
Engine running => Disable starter relay.
Exception to be handled - During initial startup, fuel feed pump is running. This has to be handled. Use a timer.
In pre ECU days, the two common points checked were alternator output, and oil pressure. A crash was not detected by means of sensors, but just by assuming that the engine has stopped running while ignition was still on.
Sutripta
Sutripta is offline   (2) Thanks Reply With Quote
Old 9th November 2012, 11:32   #22
im_srini's Avatar
Thanked: 397 Times
Question Re: DIY - Double Crank Prevention
Hi Sutripta, good stuff... Can we then use the oil pressure switch output & ignition switch output (i.e. ignition is on & oil pressure switch is off), as an indicator that the engine's running ?
im_srini is offline   Reply With Quote
Old 9th November 2012, 11:36   #23
ilangop's Avatar
Thanked: 591 Times
Better to take the Alternator WL output or Fuel pump signal, because in most vehicles the oil pressure switch cuts off even while the engine is being cranked a few turns. You can easily percieve this as the oil warning lamp turns off even before the engine fires and sustains by itself.
I could foresee one issue with tapping the fuel pump signal for preventing double cranking. Some delay circuitry has to be provided because, for the first crank one has to again wait for a couple of seconds till the fuel pump primes and turns off. Without the delay, as soon as the engine is cranked the fuel pump again turns on and would disengage the cranking mechanism. Hence there is a need to delay the deactivation of crank signal if the fuel pump signal is used.
ilangop is offline   Reply With Quote
Old 9th November 2012, 20:19   #24
I think just presence of oil pressure is sufficient to say engine is turning over!
Starting has to be handled separately. (Normally done with a timer, as mentioned). Because one has to distinguish between an engine turning over on its own power, and being made to turn over.
A timer is also usually used to turn on the fuel pump on first ign power up to prime the system. This signal, if accessible, can be used to advantage.
Sutripta
A Definitive Approach to Vehicle Fires & their Prevention Eminenttismo Technical Stuff 27 30th October 2015 15:34
Converting Light Crank to Heavy Crank in Royal Enfield Standard Bullet 350 1996 Model navin_v8 Motorbikes 63 9th October 2013 20:41
All About AMS (acute mountain sickness) Prevention and Cure deky Shifting gears 25 6th July 2010 11:04
Failed Engine Double Crank Preventer, or Whatever The Name Is! dhanushs Technical Stuff 11 25th June 2010 23:06
Road-Rage mishap waiting to happen. Please help in prevention. Eddy Shifting gears 82 16th November 2009 14:50
