Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 6th May 2013, 09:46   #1
Thanked: 622 Times
Default DIY Conical Air Filter - Maruti Swift
This is a work in progress.
I had a conical air filter from my previous car that I wanted to use on my Swift VDi with the highest setting on the RaceChip module that I have installed.
Started off by experimenting on the placement and securing the filter so that it did not knock about on adjacent parts which would damage it. I also wanted to ensure that on rough roads it would stay in place and not flop around.
My earlier attempt with the stock ECU a couple of year back was not great. I did not use an proper securing mechanism and the power delivery was not what I wanted.
This time around I used a couple of iron angle supports and used a bolt hole of the engine cover to secure it.
I was able to ensure that the filter was secure and did not bump into any parts close by. There was adequate clearance on the top, bottom and sides. Did a test run and the power delivery was fine atleast not degraded. My experience is that only a longer period of 500 - 1000kms tell you the real story as the ECU needs time to adjust to the different parameters. Inference gained mainly from the post settings change on the RaceChip module.
One problem that still remains is that the filter gets pretty hot and is certainly pulling in a lot of hot air from the engine bay. Planning to get a GI sheet enclosure with aluminium foil and some basic piping to fix this problem. Any suggestions on easily available alternate raw materials will be certainly welcome.
Here is a pic of the install. Currently returned back to the stock KN filter due to the hot air problem.
Drive on,
Shibu.
shibujp is offline   (3) Thanks Reply With Quote
Old 8th May 2013, 20:40   #2
Rehaan's Avatar
Thanked: 22,606 Times
Default Re: DIY Conical Air Filter - Maruti Swift
Thread moved out from the Assembly Line (The "Assembly Line" Forum section). Thanks for sharing!
DIY - Spectre Conical Air filter in Fiesta 1.6Sxi mayankk DIY - Do it yourself 79 7th June 2012 16:51
K&N Conical Extreme Air Filter for Sale Slash Shifting gears 5 26th November 2007 19:12
15" alloys & tyres, K&N conical filter, Iridium plugs and Splitfire cables for sale. karthik247 Shifting gears 9 24th January 2007 20:33
Fitting K&N Conical Filter. MexXxentric Modifications & Accessories 10 14th June 2006 12:37
