Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 26th May 2013, 21:16   #31
Thanked: 84 Times
Default Re: DIY: How to clean 'Tough' Stains from the body
[quote=Suhas_6981;3129209]
Originally Posted by vishwasvr View Post
Hello everyone,
For several months, I'd noticed strange build up of stains around my car and only the grooves, lettering etc. I enquired with 3M, HSR layout but it was of no use since the guy who supervises the place said ''It won't go sir!''
I found it hard to believe that it would never go! It started becoming an eye sore thanks to the white color of the car.
Hey vishwasvr,
A very useful thread , really nice to know that there exists a home remedy for this.
Hard water is not the only reason for these stains to develop, these stains do appear even when 'soft' or treated water is used, they are caused mainly due to the drying up of residual water containing traces of dirt and soap after washing the car. Because places like these are not easily accessible to the cloth while wiping dry after a wash.
Very surprising that 3M people did not have a solution. I got these stains removed by them during my last visit 2 weeks back, they used a similar procedure (not lemon and tamarind but a cleaning liquid along with a tooth brush) and it worked well. Suggest you speak to Mr.Siddhu or Pradeep on your next visit.
Thank you Suhas_6981. Yes that's true.
I spoke to Mr. Pradeep during one of my visits there and he's the one who had said it won't go! I'm unsure why he said that though. Good to know you were able to get stains removed.
vishwasvr is offline   Reply With Quote
Old 31st May 2013, 15:08   #32
nipcarlover's Avatar
Thanked: 307 Times
Originally Posted by mishraak View Post
1. Wet the surface with hot water, then directly apply dry home detergent (Surf/Ariel) on the wet surface and give a strong rub with fingers(not nails) it should come out. Wash again and repeat for all letters.
Just did this and it worked beautifully, the stain/residue is almost completely gone now. Slight traces are left, but I am sure that with another session of the same procedure tomorrow or day-after would completely remove it!
Thanks a lot mate!
nipcarlover is offline   (1) Thanks Reply With Quote
Old 10th June 2013, 03:02   #33
VTEC_Rocks's Avatar
Originally Posted by nipcarlover View Post
Hey, does anyone know how to remove this stain/residue from a car?
Attachment 1087157
This stain/residue was caused when I tried to remove the dealer sticker off the car. It is not very visible, but I know it is there and it irritates me a lot!
I have tried using soap water and a cloth, but it did not work.
Any ideas?
The best way to remove sticker stains is petrol.
Put a little petrol on the soft cloth and slowly rub it off
Works like a charm
VTEC_Rocks is offline   Reply With Quote
Old 10th June 2013, 15:46   #34
Hello everyone,
Awesome. I need to try this around the VW badge on my car as well. I tried just about everything to remove the glut around it.
Btw, I don't have anything sticking to the body of the car . It reamins squeaky clean after getting the CQuartz application done. All it takes to remove any foreign substance is a nice smooth whisk of the microfiber to dust off. Shiny White!! Glassy
Papa Blaze is offline   Reply With Quote
Old 24th June 2013, 19:26   #35
Thanked: 13 Times
Does anyone know how to remove jamun (fruit) stains from the painted body ? The purple marks are indeed stubborn and are not letting go. More so on the bonnet. I am afraid of straining the car if I rub too hard with a a wet cloth. The stains are about 48 hours old.
sunny13 is offline   Reply With Quote
Old 24th June 2013, 22:05   #36
Thanked: 24 Times
Try WD40. Spray it on the stain area and wipe it with some soft cloth. It should take care of that.Once the stains start coming off just wipe it off with a damp microfiber cloth.You can get the small can for just 60 bucks. I keep one in my car cause it has so many uses.
Dr.Ameya is offline   (1) Thanks Reply With Quote
Old 26th June 2013, 11:43   #37
Thanked: 13 Times
I tried last night on a small patch. The splash stains are still not going off. One of my neigbourhood accessories shop suggested doing a wax buffing which he said will surely get these off. Still unsure if it is worth the effort and the cost also (approx. 1200)
Old 30th June 2013, 12:43   #38
Thanked: 24 Times
wow...wd40 usually works for me ,even the holi colors went away after i had used it more than a week later. On a side note i wont be parking under a Jamun tree from now on. Will he be charging 1200 just for the patch or the entire area. I am not sure if wax buffing can help in taking the stains away.
Dr.Ameya is offline   Reply With Quote
Old 30th June 2013, 18:51   #39
FlatOut's Avatar
Thanked: 365 Times
You can try rubbing with a little acetone.
Just watch out for paint removal with acetone - it's powerful stuff. Petrol dissolves most things which acetone does, without the same risk. Acetone is the business for glass, though.
It even will perform the performance and economy of your engine, petrol or diesel. Tests have shown a diesel does best with 0.15% by volume acetone added, about 0.25% in a petrol.
FlatOut is offline   (1) Thanks Reply With Quote
Old 1st July 2013, 08:56   #40
Thanked: 13 Times
[quote=Dr.Ameya;3164533]wow...wd40 usually works for me ,even the holi colors went away after i had used it more than a week later. On a side note i wont be parking under a Jamun tree from now on. Will he be charging 1200 just for the patch or the entire area. I am not sure if wax buffing can help in
THe accessories guy quoted 1200/- for the the entire car but now I have parked my decision to do it as I was advised against it by Renault service. They assured that they would take care of it during the 1st service (at a price of course) which is anyways due in 10 days. BTW white vingear is effective but it is taking ages to clear it and does not clear the stains totally.
Old 25th August 2013, 08:47   #41
Thanked: 13 Times
[quote=sunny13;3165072]
During the first service, this issue was resolved by the 3M adviser who did a "step 1" treatment and the body is back to normal. The entire process took over 4 hours but it was a decent job. He first did a test on a small patch before proceeding.
Old 25th November 2014, 21:29   #42
maximuzz's Avatar
Thanked: 62 Times
Default Issues with New Corolla Altis VL AT
Hi all. I haven't posted in a long time. I just bought a new Altis pearl white petrol automatic top end model. It had been a long 5 year wait for the car.
Everything was going good but when I got the car refueled from HP, the next morning a yellow line developed just under the area where the fuel is filled.
I called the toyota sales person who handled me during the sale, and he advised some rubbing. The mark went away after some rubbing.
Now after that I thought it could be a one off incident and advised my wife that I ll handle the refueling next time onwards.
But as luck had it I was not in town and she got the car refueled, this time from Indian Oil. When I came back the next day a bigger and more permanent mark was left on the car.
Now I have taken the car to the showroom and they are saying that this is a one off incident and it may be due to some additives mixed in the fuel. They tried to remove the mark by same the rubbing and buffing but in that process the eight layer paint has chipped along the petrol tank and they are saying that it requires re-paint.
Now I don't know what to do, my car is just 20 days old. They had clicked pics and send to TKM (Toyota Kirloskar Motors). As per TKM it is due to the fuel and there is nothing wrong with the paint.
One mistake I did was not to take pictures. Need advice on how to go forward. I stay in Bangalore and bought the car from Viva Toyota near Hebbal.
I am feeling really helpless.
MODS:- Kindly put this under correct section.
maximuzz is offline   Reply With Quote
Old 26th November 2014, 01:59   #43
D C
D C's Avatar
Thanked: 302 Times
Default Re: Issues with New Corolla Altis VL AT
That's sad. However, it doesn't seems too critical. Even if that needs a re-painting, you just need to paint the rear left panel between the tail lamps and the rear door. My best guess is that it will cost you 5K or less
Since, the Showroom chipped your paint off trying to remove the yellow mark, they should ideally accept the responsibility to get it repainted.
D C is offline   (1) Thanks Reply With Quote
Old 26th November 2014, 08:30   #44
Sahil's Avatar
Thanked: 2,718 Times
This is a common problem on white cars, samething happened to my RS5 which too is white. Over a few weeks the stain will go away if you get your car washed regularly. If you want to speed up the process take it to a good detailer in your city and have them treat the area affected.
Sahil is offline   (2) Thanks Reply With Quote
My Mahindra Bolero DI: A tough nut, but not as tough as I would have liked. EDIT -Stolen & Recovered rahul4321 Test-Drives & Initial Ownership Reports 103 15th April 2018 20:51
HELP Urgent : White water stains on the windscreen nanu28 Technical Stuff 13 3rd March 2015 09:32
How to remove oil stains??? sidd_city Technical Stuff 9 8th October 2008 18:26
How to remove sticker stains from windshield? akash_m Technical Stuff 3 25th January 2008 11:07
Paint stains on my car Chetu Technical Stuff 26 3rd April 2007 21:22
