Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 22nd January 2014, 20:50   #16
dass's Avatar
Thanked: 444 Times
Default Re: DIY - Car Key Button Repair
I was thinking, wouldn't the key repair shops have these rubber/plastic material buttons for the keys readily available with them? Instead of using these rubber tubes and pencil eraser, if those parts are available in open market, they may be a better option.
dass is offline   Reply With Quote
Old 22nd January 2014, 22:12   #17
audioholic's Avatar
Thanked: 6,115 Times
Since the designs of each manufacturer or vendor isnt uniform, its very difficult for spare parts or buttons to be available any where else other than the manufacturer itself.
Today I attempted a DIY fix on my Nippon remote of the SX4 which wasnt working. Basically it was due to a crack in the solder which caused the remote to become non functional. The issue was solved after I resoldered the key component, ie the oscillator.
The remote of my SX4 keeps hitting the surrounding panels when the car goes over bumpy patches which keeps causing this problem. Now I am considering replacing the remote itself with the one that comes inbuilt in the key. This stays in one place and doesnt get damaged.
audioholic is offline   Reply With Quote
Old 23rd January 2014, 00:53   #18
keralshobhit's Avatar
Thanked: 22 Times
My santro cobra remote keys suffered the same. Finally found this
FLIP KEYS
350 ₹ was pretty good a deal, since my car remote was really in a bad shape.
waiting for product to arrive, since its currently out of stock and they are sourcing it in a week time.
keralshobhit is offline   Reply With Quote
Old 28th January 2014, 16:22   #19
Thanked: 609 Times
in my case, the metal key is fixed to the case, containing the immobilizer circuit. so if the case is damaged then it has to be entirely changed to new one, transferring the circuit to new one. The metal key needs to be grooved with correct 'levers' for it to function when circuit is faulty! The just previously mentioned method at store, worth Rs.1200.
Also I noticed in my vehicle, when the vehicle is locked with remote (not metal key), then later if I try to open with key (manually), the alarm goes off! Service Adviser at workshop spoke this of correct logic - the mode of opening & closing needs to be same. So, if lets say the remote doesnt work (battery dead or circuit kaput), then close with key and then open with key; the alarm may not be problem.
pcpranav is offline   Reply With Quote
Old 10th March 2014, 19:20   #20
DipakDZireLover's Avatar
Thanked: 15 Times
I have a DZire with Nippon Remote. The backup remote is not working even though the green light flashes on it. It is not a battery problem either. The M.A.S.S. guys tried to get away with it saying the button is a little loose. But I know it is not. Can you please share what you checked and what you did?
If you could post some pictures or share the details over here or PM me, it would be great.
DipakDZireLover is offline   Reply With Quote
Old 7th January 2015, 14:03   #21
sanjeevgpc's Avatar
Thanked: 24 Times
Try to swap the batteries between the two remotes just to make sure its not the battery. If that doesn't help, you may need to reprogram the remote as possibly it was never programmed well or may have lost the programming. If the auto-lock system is not from the car manufacturer, you can look for the guide online or on the manufacturer's website. You may need to follow some series of steps to program the remote yourself. In case autolock is ties to ECU, you would need help of OBD scanner.
sanjeevgpc is offline   Reply With Quote
Old 7th January 2015, 14:26   #22
audioholic's Avatar
I shared details nearly an year after you asked. Sorry for missing this one and here is the solution in case you still face the problem http://www.team-bhp.com/forum/techni...em-remote.html
Originally Posted by sanjeevgpc View Post
Try to swap the batter......some series of steps to program the remote yourself. In case autolock is ties to ECU, you would need help of OBD scanner.
audioholic is offline   (1) Thanks Reply With Quote
Old 26th March 2015, 11:55   #23
Thanked: 609 Times
update:
I have been searching across quite few places for the Xylo remote key shell, but couldnt find.
two days back, I found it being sold on ebay; more so some ebay sale was going on, plus I had the 7% disc code by Vodafone bill payment. waiting no further I have ordered below items :
key shell : http://www.ebay.in/itm/161632968614?...84.m1439.l2649
key cover : http://www.ebay.in/itm/281602401230?...84.m1439.l2649
Old 1st April 2015, 13:52   #24
Thanked: 609 Times
the silicon cover is of good quality and easy fit, it will save the rubber keypads.
the new key shell's blade needs to be cut, which I went to key stall within hyper-city mall (Ghodbunder, Thane). The guy was surprised of me getting these things "online", as he couldnt source it for me since all these months!
The cutting was done on the machine just within few minutes, I paid him 300/-. the guy checked the new shell with manual lock/unlock (since it didnt contain the circuit yet), it worked well.
then the guy inserted the new key in ignition slot and turn-up - wait! the car wont start, because the transponder chip isnt detected in key! this security feature of the vehicle prevents starting with duplicate key. I had the original key with me anyways, which I tried with, but still the car didnt start. The solution - just leave the car locked for 10 minutes, and again try with original key. It worked. Requesting other users to keep this point in mind.
Next task was the migration of circuit & transponder chip from old key to new shell. Overall its a pretty easy task, just ensure that all parts are handled delicately and fitted well in the new case. Also, the transponder chip (sensor) is glued in the original key, which needs to be very delicately removed - i gently used a blade. Migrated these parts in new case, but didnt use glue to stick the chip - hoping that it wont move in a closed case.
I found a nice video of the entire process, uploaded by one of the vendors. hopefully its allowed to link it here :
finally, the pictures of my new keys:
(you can see my repaired shell, which I'll keep as backup)
more colors added in life :-)
regards,
pcpranav is offline   (1) Thanks Reply With Quote
Old 28th November 2015, 10:16   #25
Thanked: 609 Times
recently my friend purchased a Xylo and looking at his keys I pointed to get some protection for same, thought of gifting him one!
purchased a pair of silicone covers from ebay.in (listed at INR 499, I also put a 7% discount code received from Vodafone bill payment):
http://www.ebay.in/itm/221827696150?...84.m1439.l2648
delivery was prompt, and items look good, will check after fitting on his keys. notice the slight difference in design, especially the small cover to conceal/protect the key ring part.
comparing with my key cover (with daily usage, ofcourse my cover color has bit faded):
today evening I'll meet my friend, and protect his keys too !
regards,
Pranav
What to do if remote key fob fails and vehicle is equipped with Start-Stop button? arjab Technical Stuff 33 3rd February 2018 22:39
Duplicate Keys, Remote Key OBD Programming : Key Master (Andheri, Mumbai) frankmehta Mumbai 30 24th June 2017 19:00
DIY: Flippy Key paragsachania DIY - Do it yourself 59 23rd February 2016 10:52
DIY: Honda HISS Key Programming yogisays0909 Superbikes & Imports 7 27th December 2013 10:19
"King of Key" - Guess the car or bike from its key! vrprabhu Shifting gears 67 24th April 2010 18:16
