Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 17th September 2013, 18:52   #16
DeepakMenon's Avatar
Thanked: 145 Times
Default Re: DIY: Mercedes W124 Oil Change & Pela 650 Engine Oil Extractor
Originally Posted by Mpower View Post
Very informative, Thanks!
Is the sump guard is only on the Indian model W124?
My buddy has a ML320 complained his oil changes cost him extra because his mech says he has to use something like this! It wasn't clear to me then
Most of the MBs have a sump guard; in some models or areas they are plastic; some have sound insulation; they are then generally referred as splash guard
I think for bad road conditions they provide metal sump guards; and it is heavy and runs the entire length of the engine bay; Advantage You dont have to worry about scraping; disadvantage..its is a pain to realize if your oil is leaking as it never reached the ground; hence why open the sump bolt at the first place
DeepakMenon is online now   (1) Thanks Reply With Quote
Old 18th September 2013, 01:10   #17
Mpower's Avatar
Thanked: 1,687 Times
THe pic you posted is from the 124? Wow its HUGE..looks like plastic?
Old 18th September 2013, 14:18   #18
Thanked: 145 Times
Yes the pic is of W124; In some countries its plastic; however India looks the same but in metal barring some complex curve on the sides
DeepakMenon is online now   Reply With Quote
Old 19th September 2013, 09:56   #19
sagarpadaki's Avatar
Thanked: 1,337 Times
Interesting. In Europe you might have to pay for getting rid of your old oil. Mainly because it needs to be disposed of in a very controlled and environmental friendly way and that always cost money.
In the USA it was free.
Jeroen
Well , here its opposite, people pay the garage to buy used oil from them! although at a pretty low price. Around 20Rs per 5 litres
Old 4th May 2015, 14:45   #20
rakesh_r's Avatar
Thanked: 743 Times
Excellent stuff, care to share the name of the dealer from where you bought the extractor? I am planning to buy one for my swift diesel. I am tired of changing the hex sump bolt on every oil change as the bolt head slips everytime.
rakesh_r is offline   Reply With Quote
Old 9th April 2017, 10:59   #21
lurker's Avatar
Thanked: 678 Times
Originally Posted by nitrous View Post
What I hate about these siphon devices is that quite a bit of dirty oil stays in the sump.
Conventional Draining is better, albeit messy.
you are very clearly wrong. Oil drain plug in most cars is not at the under side of the sump. When they are located on the lateral side, the drain plug thread is always slightly above the bottom of the pan where a lot of gunk/water/debris accumulate. Extraction will mean that the tube inserted will get to reach the bottom of the sump pan via dipstick hole, even below the oil drain plug thread. It will remove an extra 200ml of fluid than conventional sump drain in most cases.
lurker is online now   Reply With Quote
Engine Oil Change : Paid Service vs Buying Oil yourself vs Full DIY neosmart Technical Stuff 77 29th June 2017 11:16
DIY: Oil Change - BMW E90 (E91, E92, E93) aah78 DIY - Do it yourself 13 9th February 2016 11:54
Swift Vdi oil change - DIY shibujp DIY - Do it yourself 22 20th December 2014 19:45
Mercedes E220 W124 - Engine oil? akshay4587 Technical Stuff 12 19th August 2014 19:22
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
