Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 21st October 2016, 11:26   #61
anshumandun's Avatar
Thanked: 290 Times
Default Re: VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights
I installed the OEM cabin light with map lights. Then I replaced the yellow W5W bulbs with Philips X-treme Ultinon LED Car Lamp | T10, 6000K, 12V, 1W. This made it so much better.
I was unable to find any good C5W 42mm LED online so went to a shop and he installed a spring fixed LED bulb which had a slight flickering so did not take it. But I discovered that 42mm was not a fixed dimension, I could bend the holding metal clips slightly and fix a smaller length bulb. So I ordered a Philips Fest 10 5x38 LED 12944 6000K Interior Bulb (12V, 1W). I installed this and everything looked good as in below photo.
VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights-img_0199.jpg
However, when I locked the car, I noticed that the LEDs did not switch off completely. There was still about 5% illumination in them. So I took out the 38mm festoon LED and kept it's slot empty. The problem persisted. The only way to ensure that all LEDs are 100% off was by using the stock yellow C5W bulb. I also noticed that if I touched the 2 metal clips with my hands, the 5% illumination on the W5W LED would go away. Probably I was completing some circuit that is necessary for proper working of the LEDs. Below photo shows the 5% illlumination.
VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights-img_0197.jpg
Any idea why this is happening and how I can fix it?
anshumandun is offline   Reply With Quote
Old 21st October 2016, 15:22   #62
Vik0728's Avatar
Thanked: 1,951 Times
Hey anshumandun I have a similar setup for my Cabin light and with the LED bulbs, there is always some illumination if you leave the switch in the 'Unlock-On' position.
My guess is that since these are LED's which require much lesser voltage than the regular bulbs, the tiny amount is enough to light it up a bit.
I always make sure I turn the dome light switch completely to 'OFF' position, as long as there are no night drives/outings planned.
Vik0728 is online now   (1) Thanks Reply With Quote
Old 26th October 2016, 17:57   #63
negativeH's Avatar
Thanked: 52 Times
LED have an after glow of sorts. Am not sure what the apt term would be but LED lights continue to glow very slightly even after switching off for some seconds afterwards. Is your 5% remaining light continuing beyond sometime?
negativeH is offline   Reply With Quote
Old 2nd November 2016, 11:17   #64
Thanked: 290 Times
Yes, it is always glowing if switch is at "door open" position unless I put the switch to "Off" position. If I use the stock 42mm c5w bulb in the center position, there is no glow in the w5w led pilot bulbs so it has something to do with the center bulb. I will see if I can repost this to a larger audience in the GT TSI official review forum and get some solution. For now, I am using it as it is with all LEDs and the bulbs are always 5% glowing.
Old 27th February 2017, 15:20   #65
Thanked: 34 Times
Hi anshumandun, have you manged to resolve this issue?
This is due to the induction current generated and should be able to solve by connecting a very low resistor in parallel to the bulb.
keeru is offline   Reply With Quote
Old 27th February 2017, 16:59   #66
Thanked: 290 Times
I have just let it be. I'll try putting a wire maybe in parallel and see if it fixes the problem.
Old 27th February 2017, 17:40   #67
graaja's Avatar
Thanked: 2,486 Times
Do you mean put a wire in parallel to the LED bulb? Do not do that. That will actually create a short circuit in the cabin light circuit and may blow a fuse. What you need is a resistance that can bleed the leakage current, but not create a short circuit.
graaja is offline   (3) Thanks Reply With Quote
VW Polo DIY: Installing a gas strut to lift the hood Gannu_1 DIY - Do it yourself 50 28th June 2017 10:49
VW Polo DIY: Installing the OEM sharkfin antenna Gannu_1 DIY - Do it yourself 41 21st May 2017 19:50
DIY Install: LED cabin lights for the Maruti Swift a4anurag DIY - Do it yourself 112 17th September 2016 13:36
VW Polo DIY: Cruise Control! Gannu_1 DIY - Do it yourself 51 28th August 2016 17:55
VW Polo DIY: Removing / upgrading the instrument cluster Gannu_1 DIY - Do it yourself 28 13th April 2016 08:38
