| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself |
| | Thread Tools |
| | #46 (permalink) |
| BHPian | hi, just wanted to share my experience with boss wires.... my ice - pio 944 amp, hertz esk165 comps, hertz es380 sub, infinity ref 6x9 rears, pio 6850 HU. the infinities are on the HU rest on the amp. the amp was powered by boss wires for quite a while, the problem i was facing was dimming of lights with heavy bass notes. a month back i decided to change the power cable. i bought L&T multi strand 16 sqmm cable and replaced the boss cable with it. i was shocked with the result...the dimming of lights had reduced considerably(around 90%). there was an improvement in bass as well. i dont know the reason behind this so can anyone explain what really happened? IMHO, its better to spend money on the industrial wires rather than buying boss or any other fake or unbranded cables. cheers clip |
| | #50 (permalink) |
| Distinguished - BHPian ![]() | TSK, we are discussing strictly POWER here. No need for shielding of that kind. The kind of shielding you are thinking of is AUDIO cable, not power cable.
__________________ “I am matter and you are matter, but it doesn’t matter.” – Captain Beefheart |
| | #52 (permalink) | |
| Senior - BHPian | Quote:
![]() the 944 takes max 80 amps peak when connected in 2 ohms bridged mode....so a 25mmsq or 4 gauge will provide nice juice to the amp for the job...... the 16mmsq would have higher resistance when compared to the 25 mm sq....and the BOSS wire would have most resistance when compared to the all.....it means that the 25 mm sq would have least voltage drop across it....and the 16 mm sq would be a bit more but the BOSS will have major voltage drop..... here is a calculator use it to see the drop.... Stealth 316 - Wire Resistance and Voltage Drop Calculator | |
| | #57 (permalink) | |
If $$ is not a constraint go for the 25mm sq and do a single run. Though Navin sir has allready pointed out that you can put your existing 16mm sq to good use by doing a DOUBLE run ![]() If you compare the core wire thickness of the industrial stuff to the fancy power cables in accessory shops you will be There's hardly any strands of copper in the supposed 4ga of the run of the mill china maal.
__________________ No fate but what we make! | |
| | #58 (permalink) |
| Senior - BHPian | here is the link again..... Recommended Power and Ground Cable Sizes if you are using two 16 awg wire here is a method to make them connect them and get a 3 amp output...... ![]() |
| | #59 (permalink) | |
| BHPian | hi guys, i hope this is the appropriate thread to post my queries. im upgrading my cars power cables to make my amps life a little bit easier. navinji, i gave a thought to your above mentioned advice. although, it is a really good suggestion to avoid wastage, i dont want to double it up cause it is a thick wire(16mm^2) and it will be a pain to pass it through the firewall. also it would be a little more difficult to snake it around inside. it cant be installed in the bottom plastic trim near the doors(im not too sure) as the plastic trim will get loose with time and come off becuse ill have to force it to lock in place(the trim doesnt have screws, it has a threaded kind of plastic screw type lock). Quote:
the idea is great but a little difficult for me to implement for the reasons i stated above. i compared my L&T 16mm^2 and an L&T 8 gauge to the BOSS's 8 gauge cable(Buy our shi##y stuff, another name after gunman's buy our stupid sh#* lol), i couldn't stop laughing. hahahaha its a shame on our part(to buy the crappy Chinese stuff) and on our governments part to allow these sub standard cables etc to land on our shores. they should do something to curb this menace. ill say it again...its better to buy industrial wires instead of the bad Chinese and fake jbls etc. but Chinese wire are still cheaper than the equivalent gauge good Indian wires so people buy the boss cables without really investigating the facts(quality issues). lastly, my question regarding the dimming lights still are unanswered. why did the dimming of lights got reduced by 90% ? whats the reason behind this? the smaller gauge cable is getting less current than a heavier gauge wire so how will make a difference? does this mean that the smaller gauge wire takes more current than the heavier gauge wire due to the resistance? (current converting into heat due to resistance in the wire? ) please clarify my doubt. navinji, samji, lbm, gunman, B&T. navinji ive bought L&T's 25mm^2 multi strand cable today and im going to install it rightnow. lets see what the end result is. i hope it makes a difference otherwise my 1.5k will be wasted. lol thanks for the advicecheers clip | |
| | #60 (permalink) | |
clip first you install it and let us know the result.... and how much wire did you bought for 1.5k I can get approx 10 meter wire.... | |
| Thread Tools | |
Similar Threads | ||||
| (Royal Enfield) Thick black smoke when revved hard. | ron_9191 | Motorbikes | 43 | 13th October 2009 14:50 |
| Spark Plugs and Wires | bmdesai1987 | Modifications & Accessories | 0 | 6th October 2007 11:59 |
| Thick oil for new car | PatienceWins | Technical Stuff | 4 | 1st October 2007 13:42 |
| Wires For Amp | ggoyal_83 | Ask the Gurus | 7 | 28th November 2006 14:02 |
| Good RCA Wires | low_bass_makker | Product Discussions | 42 | 11th June 2006 00:37 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
