| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #76 (permalink) |
| BHPian Join Date: Aug 2007 Location: Chandigarh
| Hi, I am thinking of some changes in my setup, i shall be adding a Monoblock amp to my current setup. Taking Reference from these links:- http://www.team-bhp.com/forum/ask-gu...tml#post220127 (How to determine what size Power Cables for ICE? Answers inside...) & Recommended Power and Ground Cable Sizes Taking the equation into account given in link by gunbir:- I=(TP*2)/Vbatt(12V), Calculating total power= Amp-1 JBL 75.4, 416w@4ohms @14.4v and 568w@2 ohms @14.4v.Fuse rating 2*30A Amp-2 Mono 500w@4ohms @14.4v and 900w@2ohms @ 14.4v. Now calculating the max power should i take into account 4 ohms fig or 2 ohms fig. On 4 ohms fig current draw is-152.6 on 2 ohms fig cuurent draw is-244.6 Though i will be using both the 4 channel amp in 4 ohms mode and in future i might run the mono on 1 Ohm load. How should i go about slecting the Power wires.I have swift,what should be the lenght of power cable,the amp are mounted on rear seat back. My current POWER KIT is Audison FPK 300 it's 8 AWG power & grond cable, 60 A fuse with it.If i upgrade how can i make use of it in this upgrade. Can i run two seperate power cable from battery,so that i can use FPK300,and add a thicker cable for the mono. If i missed out some information plz do ask. Cheers!
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. |
| | #78 (permalink) | |
| Quote: Those who have no idea about basics do tend to get "EXCITED" .Cheers!
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. | |
| | #80 (permalink) |
| had it mate in first go!!!!! Comming to the topic,how should i go about it.
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. Last edited by Gill : 22nd November 2007 at 14:49. |
| | #81 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Dubai (3-10 July)
| Quote:
In the future you will run at 1 ohm? So, the mono operates at 1 ohm? If so, then the current will be greater than the 244.6 you have calculated? Then go for 1/0 right away, I would say. If you get a 1/0 gauge kit, you could probably use a small bit of the Audison 8 gauge cable to take a tap from the 1/0 cable to the speaker amp and for the earth. I dont see any other use for it. | |
| | #82 (permalink) |
| I arrived on the figs as follwoing:- On 4 ohms fig current draw is-152.6 I=(TP*2)/Vbatt== ((416+500)*2)/12=152.6 on 2 ohms fig cuurent draw is-244.6 ((568+900)*2)/12=244.6 @B&T,sorry if i am getting it wrong,you mean to say that,i can use the 8ga wire to speaker amp(75.4) from distribution block. what is double run of power cable?
| | #83 (permalink) | |
| Senior - BHPian | Quote:
formula is Current = Watts (output+ heat generated) / Voltage The watts can be calculated as like for a amp max wattage figure whether it is 1 ohms or 2 ohms or 4 ohms. So let us assume a amp can give Max 100 watts so if it is a AB class double the load as they are 50 % efficient but if it is a D class they are 80 % (approx) efficient so the load figures will be 200 watts for a AB class and 125 watts for the D class not do the current calculation.. for AB class 200 / 12 = 16.6 Amps for D class 125 / 12 = 10.4 Amps So if your amp is 900 watts the If is a AB class it will consume max 150 amps and if it is a D class it will consume 90 amps.
__________________ Looks Can Be Deceiving | |
| | #84 (permalink) |
| LBM, went through few threads about these calculations,but couldn't make out the best way of doing it.even i didn't get, how you have calculated the watts,mono is a class d amp. Is there any benchmark for efficiency(I presume heat generated) for amps of different class. Or why one should consider heat generated(Thermal fig) into account while calucalating the wires it will be lot easier for me if you suggest the wires n fuse i should opt for. Better solve the problem rather making it more complicated. I said so as there already had been a heated debate on this issue.let's have a swift solution. NO offence meant to any one! Cheers!
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. Last edited by Gill : 22nd November 2007 at 18:32. |
| | #85 (permalink) | |
The thermal figure is considered as they will also include while the load is calculated. Yaar simple tell us the amp and we will suggest you the wires and also how we evaluate them. This way it will be easy to understand.
| | #86 (permalink) |
| Amps shall be JBL 75.4 and Kenwood 9103D.Plz do consider the upgrade possibilities for a 4 channel amp. Cheers!
| | #87 (permalink) |
| Senior - BHPian | Kenwood KAC-9103D Mono subwoofer amplifier 900 watts RMS x 1 at 2 ohms at Crutchfield.com and JBL Grand Touring Series GTO75.4 II 4-channel car amplifier 104 watts RMS X 4 at Crutchfield.com both the amps has 30 x 2 amps fuse. Also the 4 channel will work on speaker duty that is with HPF, so the current consumption will be quite less of that amp. But anyways a simple logic you can go for a single 4 gauge cable as it is capable of handling 150 amps. (30+30 + 30+30 = 120 amps fuse total) as the 8 gauge will be less for your application. Recommended Power and Ground Cable Sizes -> check the Power & Ground Cable Specs chart Or One can calculate the Ampere For the Kenwood as it is D class I am assuming it to be 80 % efficient so the max current watts it will draw will be 900 watts + 20 % = 1080 watts so 1080 / 12 = 90 amps The above case will happen when you play a sine wave and never possible with music. For the JBL amp Max it can give is 104 x 4 or 284 x 2 but since you are using it for 4 channel I will take 104 x 4 = 416 watts . Bening it AB class I will assume it 50 % efficent so the total watts drawn will be 416 + 50% = 832 watts so 832 / 12 = 69.3 amps Now one more important thing to consider here is that since you are using the amp in Speaker duty the peak current demand will be never 69.3 amps. so you can consider it less also. Anyways total demand is now 90 + 69.3 = 159.3 amps which can be considerd to be 150 easily. Which a 4 gauge (25mmsq) cable can easily handle without any problem. So calculate it anyway you just need a 4 gauge (25mmsq) cable for the job even if you upgrade your speaker amp also.
| | #88 (permalink) | |
| Quote:
Cheers!
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. Last edited by Gill : 23rd November 2007 at 12:48. | |
| | #89 (permalink) |
| When one has a inline main fuse holder,simple distribution block will do!Or a fused d-block is required.
| | #90 (permalink) | ||
No need to use a fused D- block if there is inline main fuse holder.
__________________ Looks Can Be Deceiving | ||
| Thread Tools | |
Similar Threads | ||||
| Spark Plugs and Wires | bmdesai1987 | Modifications & Accessories | 0 | 6th October 2007 10:59 |
| Thick oil for new car | PatienceWins | Technical Stuff | 4 | 1st October 2007 12:42 |
| Wires For Amp | ggoyal_83 | Ask the Gurus | 7 | 28th November 2006 13:02 |
| Good RCA Wires | low_bass_makker | Product Discussions | 42 | 10th June 2006 23:37 |
| Locally available HT speaker wires | Samurai | Gadgets, Computers & Software | 4 | 26th April 2006 13:45 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
