Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself
Thread Tools
Old 5th December 2008, 15:37   #106 (permalink)
ilovefls's Avatar
Very informative posts!
I have a query of my own - I recently installed a Kenwood KAC 8401 4 ch amp driving a Bull Audio sub and Bull 6.5" components in the front. I have used the Bull Audio 7ga wiring kit. Just wanted a reconfirmation whether the wiring used is good enough for my present set-up or do I need to use 4ga wiring?
Thanks.
__________________
2004 Red Skoda Octavia vRS 1.8T
2005 Silver HH Karizma
2004 Silver Opel Vectra 2.2 - sold
ilovefls is offline   Reply With Quote
Old 5th December 2008, 15:45   #107 (permalink)
Thanks.
Ya you will be happy with that. No need to spend more.
Old 8th December 2008, 21:45   #108 (permalink)
ilovefls's Avatar
Thanks for the confirmation LBM! I am more than happy to save some vitamin M
__________________
Old 14th March 2009, 12:38   #109 (permalink)
If Finolex/L&T can be fantastic VFM options for power/ground use in automotive environment, then why can't it apply to speaker/sub wires as well? Say 10-12AWG (4-6 mm2), if they have a flexible variety made for industrial use?
santosh.s is offline   Reply With Quote
Old 14th March 2009, 15:58   #110 (permalink)
It can be but it is good if we use the Finolex till the power level only. I would go for a good speaker cable.
Old 14th March 2009, 16:18   #111 (permalink)
LBM, I just wanted to know the reason(s)!
Old 14th March 2009, 23:37   #112 (permalink)
karankapoor's Avatar
i don't know much about this but i will never use finolex/l&t for my audio,
there must be some difference between the two,amp kits(any good brand) and finolex if not then why are they so expensive.
i think guru's can shed some light on this.
__________________
P80RSII l ID Chameleon's l Genesis Dual Mono l ID Max l Genesis Dual Mono EXtreme l Kicker l Connection Audison l Dynamat
karankapoor is offline   Reply With Quote
Old 23rd July 2009, 17:20   #113 (permalink)
cyclops's Avatar
Any answer to karan's question? What is the difference between these two? This seems interesting..
cyclops is offline   Reply With Quote
Old 23rd July 2009, 19:14   #114 (permalink)
This is a very debatable question. For me while using the finolex wire and a good branded power cable makes to me no difference except the cost involved. For me the power cable has only one job to transfer the current required by the amp from the source battery/alternator. Beyond this I cannot think of any other aspect which will directly linked to SQ part. I have done chemical analysis of both the wire in which the Finolex was having 99.9 % copper and the branded one had 95 %. So in other words finolex is better.
Leaving aside the technical part there are few things called aesthetics like the branded power cable will look bling and the finolex will look dull and black. The branded cable would be more flexible when compared to the finolex. So if the user want some bling he/she can spend approx 10 times more to get. It all depends on what the user wants.
For speaker and rca I would suggest to go for good brands. I may be wrong gurus can shed some light on this.
Old 23rd July 2009, 19:30   #115 (permalink)
I never wanted to, but still "had to" go for branded power cables
Old 23rd July 2009, 19:34   #116 (permalink)
tsk1979's Avatar
I fail to understand how can copper of same oxygen content from one manufacturer can be different from other. Mostly it looks like a hype created by people in audio business to make shady money. If you sell a copper cable for 50,000rs definitely you will make a lot of money even if you give hefty discount. So you can actually cheat your customer and make him feel special with the 50% off!\
__________________
Reclaimed, wrung dry and recycled....!
Old 23rd July 2009, 19:57   #117 (permalink)
cyclops's Avatar
I agree 100% in terms of power cables, the branded one seems a marketing gimmick. But what about speaker cables? Can we use a thinner finolex wire for speakers as well? Or will it affect the sound quality? If it does affects, why?
How can someone force you to buy branded ones?
Old 23rd July 2009, 19:57   #118 (permalink)
gigy's Avatar
You have the money go for the costliest. This is not a mercedes to maruti comparison.
Good cable matters for RCA only since it carries low power signal, needs to be shielded to prevent electronic noise.
For power and speaker any good wire having more copper than bling will do the job better. in other words whichever has least resistance dose it better. speaker wires are not shielded.
Other than this another issue is the flexibility of wire due material and thickness of insulation, thickness of the strands and its number matters.
I had a terrible time routing a 2g finolex power wire to my amplifier.
When i was buying the wire in a reputed shop he had 2g cable of both finolex and monster. monster with its shiny red colour was looking nice. when he was cutting a piece of it for another customer he used normal wire cutter and it sliced through with ease. when he was cutting the finolex for me his assistant used a metal hacksaw. both were of same thickness.
For speaker also i picked up another cable due to the quality of copper in it. speaker wire also caries current not sound and its a power connection to speakers; i mean its not weak as what RCA carries. to create interference in it you need some really strong interference not possible in normal cars.
So if you want your money's worth buy wisely.
How do you think the industry survives? buy a connector from milan for 200 or pick same from lamington for 20. i had such experience.
Still there are branded good ones also but costing a bomb.
Old 23rd July 2009, 21:13   #119 (permalink)
No, I didn't mean it was done at gun point! I wanted to get things installed by any of the well known installers. Talked to 4-5 of them, but all of them ridiculed me when I told them to use Finolex/L&T for power cables. Then I offered to provide it myself, but then I came to know that none of them "work that way"! Did not have enough experience/patience/tools to DIY. You get the point, I suppose.
Thread Tools
(Royal Enfield) Thick black smoke when revved hard. ron_9191 Motorbikes 43 13th October 2009 14:50
Spark Plugs and Wires bmdesai1987 Modifications & Accessories 0 6th October 2007 11:59
Thick oil for new car PatienceWins Technical Stuff 4 1st October 2007 13:42
Wires For Amp ggoyal_83 Ask the Gurus 7 28th November 2006 14:02
Good RCA Wires low_bass_makker Product Discussions 42 11th June 2006 00:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608
