Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 26th February 2016, 18:39   #31
Thanked: 34 Times
Default Re: VW Polo DIY - Adding a lamp to the glovebox
No. 16. Turns off with the key in off
Gannu, slot16 is not empty. You wanted me to tap this fuse? Is there any empty slot I can use which activates with ignition ON?
keeru is offline   Reply With Quote
Old 26th February 2016, 19:15   #32
Gannu_1's Avatar
Thanked: 10,520 Times
It isn't empty but you can use the fuse tap and connect both the fuses to the tapping cable. Works.
Just to add, this doesn't alter the primary circuit in any way. We are only tapping an extra 12V and providing an independent fuse to it.
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 3rd March 2016, 14:10   #33
Thanked: 39 Times
Default Re: VW Polo DIY: Adding a lamp to the glovebox
hi gannu_1
i ve got some rear footwell lights and an auto dimming irvm/dashcam for my vento (2015). im planning to get some fuse taps from ali express and do not know if i should get the mini or medium fuse taps for the same. I see fuse taps with different amperes as well. which ones should i be looking for? any tips would be much appreciated
thanks
famousshoes is offline   Reply With Quote
Old 3rd March 2016, 14:14   #34
Gannu_1's Avatar
Originally Posted by famousshoes View Post
hi gannu_1
thanks
Both would work. You are essentially tapping 12 V from a source. Stick to a 5A fuse.
Old 14th March 2017, 18:23   #35
samaspire's Avatar
Thanked: 2,694 Times
Noob question, but can I use the door switch from any refrigerator for lighting the glove box? Any cheap way to convert the 250V input?
Edit: I found this link on AliExpress.
Is this ok?
samaspire is offline   Reply With Quote
What items do you always carry in your car / glovebox? johnda Shifting gears 116 10th January 2018 14:10
VW Polo DIY: Adding dampers to grab handles Gannu_1 DIY - Do it yourself 14 2nd July 2017 09:45
(DIY) Head lamp washer manikjeet DIY - Do it yourself 34 15th August 2016 15:34
DIY-Blue LED Parking Lamp & Speedo Meter+Wire Mesh Grille & Underbody Neons for Alto badboyscad DIY - Do it yourself 133 1st March 2015 00:50
DIY: Adding an extra bulb to the Tail Lamp (Ford Figo) RGK DIY - Do it yourself 19 2nd July 2014 22:13
