Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 3rd July 2014, 23:35   #31
e-katz's Avatar
Thanked: 19 Times
Default Re: DIY: Installing a gas strut to lift the hood (VW Polo)
Sure, do keep me posted! Cheers!
Originally Posted by pillainp View Post
I've had to push my plans back by a couple of months, because of certain overriding personal concerns.
I will definitely keep you in the loop.
e-katz is offline   Reply With Quote
Old 4th July 2014, 01:51   #32
Ray32825's Avatar
Thanked: 56 Times
Good job Gannu, but did you consider going with a pair of shorter struts so that access to the engine compartment is not restricted from the side?
I would probably go with two short struts and in the same orientation as in the pictures you provided. As someone who likes to work on cars I prefer it this way.
VW Polo DIY: Installing a gas strut to lift the hood-bmw-strut-1.jpg
VW Polo DIY: Installing a gas strut to lift the hood-bmw-strut-2.jpg
Ray32825 is offline   (2) Thanks Reply With Quote
Old 4th July 2014, 09:25   #33
Gannu_1's Avatar
Thanked: 10,517 Times
Originally Posted by RGK View Post
This is my hood and engine bay view. Figo has a provision to fix ball studs on the chassis, where as I could not find one on the bonnet.
RGK, sorry for the late response. Overlooked your post. You may have to drill a hole and tap it for the M6 threading.
Raymond, you are right. A shorter strut (or a pair) is much better than the longer one due to the reduced chances of buckling. A longer strut tends to be more slender than a shorter one (for a rod of the same diameter) due to the increased length.
In my case, one of the flanged bolts on the car’s body was readily replaceable with the threaded ball extension so I did not have to drill a hole on the structure and then tap it for the threading. Moreover, the area just below the hinge has a plastic mesh covering the top of the suspension strut dome. The reason why a second strut couldn’t be used on the driver side is due to the windshield washer fluid tubes tied to the hinge. This would interfere with the strut while closing.
Gannu_1 is offline   Reply With Quote
Old 4th July 2014, 09:46   #34
Ray32825's Avatar
Thanked: 56 Times
I did actually bend a strut once, it was on a Lotus Esprit and those are around $200 I think. It had a special locking mechanism that I was not aware of.
Here is a site that seems interesting - http://www.liftsupportsdepot.com/
Ray32825 is offline   Reply With Quote
Old 6th September 2014, 08:59   #35
blr
Thanked: 22 Times
Thanks Ganesh for another great DIY! Neat job.
blr is offline   (1) Thanks Reply With Quote
Old 24th September 2014, 15:29   #36
arunphilip's Avatar
Thanked: 4,824 Times
Very nice thread, with good pictures and write-up. It was good to read about the things you got wrong and how you circumvented them
One safety suggestion - even though you're not doing anything electrical, the very fact that you're working beneath the hood should make you disconnect the battery terminal, and tape the clamp to prevent accidental contact.
Just imagine - you're screwing in a bolt onto the hood's clamp, you drop the wrench, and that contacts the battery terminals. Bad stuff can happen.
When I was changing the air filter in my car, I found that I mentally did not 'view' the battery as an electrical part - stupid on my part, I know! But I decided that hereafter, anything more than fluid checks, I'll detach the negative terminal before proceeding.
arunphilip is offline   (1) Thanks Reply With Quote
Old 16th February 2015, 11:26   #37
Gannu_1's Avatar
Had noticed that the MS (mild steel) angle has rusted a bit:
VW Polo DIY: Installing a gas strut to lift the hood-wp_20150213_09_50_39_pro.jpg
It wasn’t primed and painted as it was meant to be - just a spray paint can was used. So decided to get rid of it and replace them with something better. Had been on a factory visit last week and the factory had a CNC machine capable of fabricating these angles with precisely drilled/slotted holes. Requested them for a couple of angles and they gave me 8 of these!
VW Polo DIY: Installing a gas strut to lift the hood-wp_20150215_23_12_00_pro.jpg
VW Polo DIY: Installing a gas strut to lift the hood-wp_20150215_23_13_17_pro.jpg
VW Polo DIY: Installing a gas strut to lift the hood-wp_20150215_23_12_42_pro.jpg
Replaced the angle:
VW Polo DIY: Installing a gas strut to lift the hood-wp_20150216_07_13_13_pro.jpg
Gannu_1 is offline   (2) Thanks Reply With Quote
Old 29th November 2015, 21:59   #38
The Dude's Avatar
Thanked: 57 Times
Default Re: VW Polo DIY: Installing a gas strut to lift the hood
Hello Gannu Sir, I have always wondered how in the world you do such amazing DIYs. This is what a noob like me would call "Extremely Professional". I have one small question though. Can I do this on my Grand i10?
Thanks in advance.
-Adhi
The Dude is offline   Reply With Quote
Old 1st December 2015, 10:51   #39
noelnelly's Avatar
Thanked: 120 Times
Originally Posted by iTNerd View Post
I had done the same DIY on my Civic a few months ago.
That's a nice DIY, even I was thinking of a 2 strut system for my Amaze, could you share some more details like where did you procure the struts from and the end fittings and detailed pictures of the mod please?
Hey thanks for the post, I was wondering if it's possible to procure this locally since you happened to mention that it is used in a lot of applications, I'm pretty sure some car's boot strut might be able to do the work or some big hardware store might be stocking them in various sizes and load combination. Did you try to get them locally first or straightaway go the imported way?
Thanks.
noelnelly is offline   Reply With Quote
Old 1st December 2015, 12:40   #40
Gannu_1's Avatar
This can be extended to any car which has hex. head bolt on the panels which can be replaced with ball joints of the same metric thread.
The headlamp has a bolt which can be replaced:
VW Polo DIY: Installing a gas strut to lift the hood-engine-bay.png
Name:  ENGINE BAY 2.png
Not sure how the arrangement is on the bonnet's hinge. If there is a similar bolt there, you can have it replaced along with the 90 deg. clamp and the ball joint.
You might be able to source these locally. Back then, I didn't know of a source that retailed these locally. That said, the extended length of the struts used for the boot is lesser so do check.
Old 1st December 2015, 13:00   #41
noelnelly's Avatar
Thanked: 120 Times
I checked the strut on the WagonR, too big, like 28', Zen(old) also big, 22'. I need something like 11' or 28-30cm extended length. Will check out a few more cars.
I have a feeling the Swift might just make it. Can you just check on your Polo? The extended length of the boot strut?
Old 15th December 2015, 09:38   #42
PatchyBoy's Avatar
Thanked: 1,397 Times
Very nice DIY Gannu. Now I am tempted to try this on my T-Jet. I am in correspondence with SGS engineering. The gentleman talking to me feels that there may not be enough space for struts in my car. Could you please look at the pics and suggest? Thanks a lot.
VW Polo DIY: Installing a gas strut to lift the hood-img_20151215_071046310_hdr.jpg
VW Polo DIY: Installing a gas strut to lift the hood-img_20151215_071103198_hdr.jpg
VW Polo DIY: Installing a gas strut to lift the hood-tjet-engine-1.jpg
Name:  TJet Engine 2.JPG
PS: Ignore the markings in red. They are for a different purpose
PatchyBoy is offline   Reply With Quote
Old 16th December 2015, 11:27   #43
Gannu_1's Avatar
Sorry I missed this one. Will let you know shortly. But do ensure that the hatch struts have sufficient force to raise the hood.
Some cars required drilling and tapping to have a new bolt on the body wherever there was no bolt available which could be replaced readily.
The bolts marked below look a bit bigger (M10?).
VW Polo DIY: Installing a gas strut to lift the hood-img_20151215_071046310_hdr.png
IMO, you can have a 90' clamp inserted here on which the strut's round head bolt can be threaded to.
For the one on the top, I don't suppose the hinge bolts can be used due to the shape of the hinge. If you can drill a dia. 8 hole to accommodate an M6 bolt, use a 90' clamp to fix it to the bottom part of the hinge and then screw the round head bolt, I think this should work:
Required an extra hole to be drilled which seems to be the only caveat.
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 17th December 2015, 12:26   #44
bhargavd's Avatar
Thanked: 31 Times
Hi all,
Planning to buy GT TSI, so I am crawling most forums related to it. Gannu- The kind of DIYs you do are superb. Would love to see your car in flesh sometime.
Regarding local sourcing of struts- Amazon has the new Car and bike category which lists some gas struts.
http://www.amazon.in/s/ref=nb_sb_nos...gas+struts+480
I have searched "gas struts 480" to give me the extended length required. However other conditions to check if one of the struts can be used for Polo is not clear due to given info.
@Gannu can you please check the struts available and which one could be used?
This one seems to be the closest: http://www.amazon.in/Force-Studs-Str...gas+struts+480
bhargavd is offline   Reply With Quote
Old 18th December 2015, 21:35   #45
Gannu_1's Avatar
Originally Posted by bhargavd View Post
Hi all,
But the pricing is exorbitant! Did you check with SGS Engineering or somewhere else?
Keep the length somewhere close to 460 mm; 480 mm although fits, its more of a tight fit. 460 mm should give you some slack. As for the force, keep it between 350 to 400 N (divide by 9.81 for the kg rating).
VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights Gannu_1 DIY - Do it yourself 81 28th May 2018 14:29
VW Polo DIY: Installing the OEM sharkfin antenna Gannu_1 DIY - Do it yourself 44 11th September 2017 21:03
DIY - Cedia Front Strut Bar Installation Captain Slow DIY - Do it yourself 0 8th November 2014 17:35
DIY: Base for the Hi-Lift Jack Tejas@perioimpl 4x4 Technical 10 12th November 2013 12:38
DIY Josh - Installing the ICE myself moralfibre In-Car Entertainment 16 7th February 2006 15:54
