Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 31st May 2016, 22:36   #46
maddyguage's Avatar
Thanked: 177 Times
Default Re: VW Polo DIY: Installing a gas strut to lift the hood
But the pricing is exorbitant! Did you check with SGS Engineering or somewhere else?
Keep the length somewhere close to 460 mm; 480 mm although fits, its more of a tight fit. 460 mm should give you some slack. As for the force, keep it between 350 to 400 N (divide by 9.81 for the kg rating).
Hello Gannu_1, first of all amazing DIY job, very neat. After looking at your mod I'm also going to do that on my 2016 Vento. I contacted few local shops and they said I can use Skoda Superb gas strut.
Is it advisable to do so? He asked me 3000 INR for gas strut and installation. I've checked SGS engineering and I'm bit confused there. I will order once you guide me to buy particular model for self opening bonnet.
I am not far from your current city, and I often visit Surat. So I would like to meet you someday and see your amazing DIY mods in person.
CHEERS
maddyguage is offline   Reply With Quote
Old 1st June 2016, 07:48   #47
Gannu_1's Avatar
Thanked: 9,696 Times
You can use any strut so long as the following specs are met:
a. The force of the strut is sufficient to lift the hood. This is usually specified in the strut. Anything more than 400 N is sufficient IMO.
b. The extended length of the strut is such that it can lift the hood to the required height and can retract without interfering with any other parts.
Yes provided the shop can execute a neat job instead of a shoddily fabricated mount. Do not let them drill additional holes anywhere on the car. It doesn't warrant one at least for the Vento.
Looks reasonable to me.
What are you confused about? I've specified what are the parts required in the first post.
I've shifted to Madras from Navsari couple of months back. I might drive to Anand sometime next year.
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 1st June 2016, 10:31   #48
maddyguage's Avatar
Thanked: 177 Times
Oh I see, I thought you are still in navsari. No worries.
Old 4th April 2017, 15:16   #49
csr9's Avatar
Thanked: 102 Times
Hi Gannu_1
Thank you for the simple yet effective DIY. I am considering installing a gas strut on my polo.
1)Would a 350 NM strut induce stresses and cause flexing while pulling the bonnet for closing as we are using a single strut?
2)Since you have recommended different extended lengths (460mm & 470mm), please suggest which one would be a safer bet?
3) Do the SS clamp and MS clamp differ in dimensions?
csr9 is offline   Reply With Quote
Old 25th May 2017, 21:21   #50
csr9's Avatar
Thanked: 102 Times
I ordered for a gas strut from SGS engineering and received the package last week. However, the strut was badly bent. They messed up with the end fixings as well. Took the issue up with SGS, they offered to send in a replacement. Hopefully it arrives in good nick!
VW Polo DIY: Installing a gas strut to lift the hood-img_6176.jpgVW Polo DIY: Installing a gas strut to lift the hood-img_6177.jpgVW Polo DIY: Installing a gas strut to lift the hood-img_6175.jpg
Old 28th June 2017, 10:49   #51
Thanked: 41 Times
Default Re: DIY: Installing a gas strut to lift the hood (VW Polo)
Requested them for a couple of angles and they gave me 8 of these!
Replaced the angle:
I just bought the strut from SGS and planning to do the hood lift DIY and the grab handle dampners in the next couple of weeks.
kishore1984 is offline   Reply With Quote
Old 14th July 2017, 16:54   #52
BlueEyes's Avatar
Thanked: 135 Times
I am planning to order gas struts from SGS for my GT. Interested to know if you have chosen the struts with force rate of 250N or 350N? If it's 350N, would appreciate your feedback
BlueEyes is offline   Reply With Quote
Old 17th July 2017, 11:30   #53
Thanked: 41 Times
I have chosen 250N. Also, make sure you chose 2 ball joints. I chose one by mistake and now there is a delay in shipping the other one.
kishore1984 is offline   (1) Thanks Reply With Quote
VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights Gannu_1 DIY - Do it yourself 79 31st October 2017 09:18
VW Polo DIY: Installing the OEM sharkfin antenna Gannu_1 DIY - Do it yourself 44 11th September 2017 21:03
DIY - Cedia Front Strut Bar Installation Captain Slow DIY - Do it yourself 0 8th November 2014 17:35
DIY: Base for the Hi-Lift Jack Tejas@perioimpl 4x4 Technical 10 12th November 2013 12:38
DIY Josh - Installing the ICE myself moralfibre In-Car Entertainment 16 7th February 2006 15:54
