Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 4th September 2014, 12:27   #16
ZBlue's Avatar
Thanked: 114 Times
Default Re: DIY: LED Tail lights on my Fiat Linea T-Jet
Originally Posted by adrena View Post
Very neat job @Zblue!
I got here looking for LED replacement bulbs for my TJet when one has blown and found this treasure.
Really want to see the diagram. I am certain I will be able to do this without much hassle. I've done a fair amount of this in the past.
Well the electronics bit here is quite simple. What is more involving is fitting the LED boards so that the LED's are at the proper angle , sealing the lights so that they are watertight etc. Also , it is imperative that one has the tail light lenses available separately in order to do this DIY.
The original lights have the following bulbs :
  • Park - 5W
  • Brake/Fog/Turn/Reverse - 21W
The power draw for these are :
  • Park - 5W/12V ~ 400mA
  • Brake/Fog/Turn/Reverse - 21W/12V ~ 1750mA
Now what I have found is that the CANBUS is satisfied as long as the power draws/resistances are around a certain range about the above figures. For example , for the park lights , you do not get an error as long as they draw around 150mA to 600mA. Anything less than this and you would get the error message in the MID but the lights would still work. But if your park lights draw around 1A for example , then the BCM would cut power to the park lights completely (after sampling for about 3 seconds) and you would again get the error message.
Basically , your LED's would need to draw current as mentioned above (either just the LED's themselves , or through a combination of LED's and load resistors) in order to be error-free.
The LED's that I have used are these :
These are called "superflux" LED's and are a popular choice among DIY'ers. I used Phillips red-orange ones for park/brake/fog and Cree amber ones for turn. These are rated for a max current of 70mA , but are usually run at 50mA to increase longevity , and also because visually there is very little difference between the brightness at 70mA and 50mA. They have a forward voltage of around 2.4V and I ran them in series of 4.
Just to take the brake lights as an example , if each series of 4 LED's is run at 50mA , I would need a total of 1750/50 = 35 strings. This comes to 35*4 = 140 LED's.
if I regulate the input voltage to 12V , then by Ohm's Law the resistor is calculated as :
Voltage through the resistor = 12 - (2.4*4) = 2.4V
V = IR gives R = 2.4/.055 = 43ohms.
Is that helpful ?
ZBlue is offline   (1) Thanks Reply With Quote
Old 4th September 2014, 13:38   #17
adrena's Avatar
Thanked: 90 Times
Originally Posted by ZBlue View Post
Is that helpful ?
Extremely helpful.
I suppose I should then fire up Corel Draw to line up these strings in similar concentric circles and wire things up.
Now I only have to find the time.
I also noticed a post that mentioned the VW Jetta tail lamps. I really loved the way they looked. I've always maintained that the VW group really gets lighting and gets it right more often than anyone else.
Let me try a combination of stuff I see here and report back on how this goes.
adrena is offline   Reply With Quote
Old 4th September 2014, 13:55   #18
ZBlue's Avatar
Thanked: 114 Times
Extremely helpful.
While I'm sure Corel would work , I used a software called Diptrace myself - quite user-friendly and it's meant specifically for designing PCB's. Just to give you a sneak peek , this is what the Diptrace circuit for the turn signals looks like :
DIY: LED Tail lights on my Fiat Linea T-Jet-screenshot-20140904-135135.jpg
ZBlue is offline   Reply With Quote
Old 28th April 2015, 20:06   #19
jfxavier's Avatar
Thanked: 1,290 Times
That's an exellent job.
I think the amount of patience & work hours spent would have been tremendous.
Should rate more than 6.5/10 just for that.
I also want to replace my bulbs with LEDs but am procrastinating. Probably will go for some ready to install replacements. But impossible to get the result that you get from a custom DIY job.
jfxavier is offline   (1) Thanks Reply With Quote
Old 30th April 2015, 15:01   #20
abhii176's Avatar
Thanked: 91 Times
That is one really impressive DIY ZBlue. The final result is fantastic, the rear look of the Linea looks really transformed now. The turn indicators are simple ingenius.
abhii176 is offline   (1) Thanks Reply With Quote
Fiat Linea T-Jet : LED Mods / Upgrades ZBlue Modifications & Accessories 24 8th January 2017 02:36
Renaissance of my JET - White FIAT Linea T-Jet+ (27,000 Kms Up) Sathya_sc Test-Drives & Initial Ownership Reports 225 4th August 2014 20:29
Fuelled FIRE into my (T)JET - The Fiat Linea T-Jet bnzjon Test-Drives & Initial Ownership Reports 123 12th May 2013 00:16
