Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 25th November 2014, 17:26   #31
ventoman's Avatar
Thanked: 165 Times
Default Re: DIY - VW Polo/Vento: Getting rid of Door Rattles
@ d_himan,
Thanks a ton for finding this fix.
I've been literally living with this door rattling all along, until I found your thread. Applied it last week and since then drove around the usual routes where I get to hear them. Magical total silence now, apart from good old front arm rest!
ventoman is offline   (1) Thanks Reply With Quote
Old 26th November 2014, 20:30   #32
d_himan's Avatar
Thanked: 633 Times
Originally Posted by ventoman View Post
@ d_himan,
Yeah, magical is the word. That whole German build-quality thingie becomes real with this little piece of rubber pipe!
d_himan is offline   Reply With Quote
Old 27th November 2014, 20:31   #33
Rachit.K.Dogra's Avatar
Thanked: 730 Times
So I finally decided to give this idea a try too. After all it was not that expensive or labour intensive. The answer is, it definitely WORKS!!
I have only driven the car for around 4 Kms after this fix, but it does seem to have improved and become quiter.
Thank you very much for this fix @d-himan and the ebay link to the product also helped a lot.
A big thumps up from me. Thank you.
Rachit.
Rachit.K.Dogra is offline   Reply With Quote
Old 29th November 2014, 11:41   #34
d_himan's Avatar
Thanked: 633 Times
Rachit.
Glad it worked! I've been on the fix for a month now and hopefully should last long
Old 8th December 2014, 00:16   #35
Thanked: 22 Times
Originally Posted by d_himan View Post
I started getting it on my GT, exactly the same creek from day 3 of ownership.
Your post is very informative I must say. I've been wondering about this noise on my 2 month old tsi!!
Even I thought it was the seat belt issue. Will try this and get back.
Thanks a ton!!
HR.
humbleroadster is offline   Reply With Quote
Old 8th December 2014, 09:25   #36
manas27587's Avatar
Thanked: 58 Times
Turns out mine is not a rattle from the door.
I feel something is resonating and rattling inside the bonnet on the passenger side.
Tried to see any metal to metal contact happening but dont see anything.
The sound is irritating when outsides are quieter but as soon as car is above 40-50kmph the sound disappears.
manas27587 is offline   Reply With Quote
Old 8th December 2014, 09:39   #37
sumeshmani's Avatar
Thanked: 105 Times
4. Apply a thick layer of Collinite 845 (recommended) on the metal surfaces highlighted in yellow in the second picture ( borrowed from rtm_8055's Polo posted on the forum)
May I ask what the idea of the wax is?
Is it to minimise friction?
sumeshmani is offline   Reply With Quote
Old 9th December 2014, 20:40   #38
d_himan's Avatar
Thanked: 633 Times
Yes, minimises friction at the contact patch location of metal with the felt/rubber.
There is a known issue of fuel line vibrations...do search the forum/internet
Last edited by suhaas307 : 27th January 2015 at 12:21. Reason: merging consecutive posts
Old 10th December 2014, 06:10   #39
Thanked: 241 Times
There was also an issue with the engine mount/s on 1.2 L Petrol Polo's.
We had got one of the engine mounts replaced in our 2012 Polo about 4 months after delivery.
Please check it out
rpunwani is offline   Reply With Quote
Old 15th December 2014, 16:29   #40
Thanked: 335 Times
Hi All
All those who have done this DIY can you please update as to how it is holding up. i bought a Vento recently and it is creaking from day 3 onwards. It really is irritating. I have bought the pipe and most probably will try it today evening. I ma still not clear as to where the wax is to be applied. Is it on the metal or on the rubber beading on the car body
Wouldn't applying wax create the same problem that WD-40 created, meaning attract dust?
Mohan Mathew A is online now   Reply With Quote
Old 16th December 2014, 18:44   #41
d_himan's Avatar
Thanked: 633 Times
Originally Posted by Mohan Mathew A View Post
Hi All
Holding well! Just try it without the wax procedure - should be good enough.
The wax is on the metal. A high quality one like Collinite 845 is like a wax-cum-sealant and has dust repelling properties.
d_himan is offline   (1) Thanks Reply With Quote
Old 17th December 2014, 11:12   #42
Thanked: 335 Times
I tried it without the wax and the sound is gone 95%. I am loving the silence. Thanks. I want to take it for a pressure wash to be sure that there is no leakage
Thanks for the tip
Old 27th December 2014, 11:40   #43
deepfreak15's Avatar
Thanked: 303 Times
Does your rattle happen around the 2k rpm mark under linear acceleration an vanish once the rpm reaches around 3k ?
deepfreak15 is offline   Reply With Quote
Old 27th December 2014, 13:36   #44
manas27587's Avatar
Thanked: 58 Times
Nope nothing like that it is audible more when I go into a pothole.
Old 13th January 2015, 11:04   #45
alexxx's Avatar
Hi deepfreak
Im having exactly the same issue that you have mentioned..mine is a petrol vento and while its on perfectly even roads, under linear acceleration there is a rattling noise like a screw is loose or something. This vanishes once the rpm hits ~ 3 k. I have been looking for the source of this sound for quite some time now.could anybody please help?
alexxx is offline   Reply With Quote
Getting Rid Of Brake Pad Glaze 1self Technical Stuff 1 26th March 2010 10:05
getting rid of ohc type 1 tail lights honda3938 Modifications & Accessories 8 27th November 2009 18:22
Getting rid of planks in palio to mount jbl gto 937 vickyre In-Car Entertainment 4 25th October 2007 21:05
