| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #33 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Infractions: 0/1 (5) | Quote:
Thanks Sam...
__________________ Its better to be pissed off than be pissed on Last edited by gunbir : 25th August 2006 at 00:07. | |
| | #34 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
No light shedding on that marriage and certainly, no load=shedding either, notwithstanding B&T's overdeveloped forearm.
__________________ Live the YetiLife® Ohne Dich ist alles doof. | |
| | #35 (permalink) |
| Senior - BHPian | B&T : Regarding club sounds, I would def, agree with you, people who crib will complain forever..... Iv heard some phat sounds indoors(overseas though) also it reminds me of the sound at one of the trance parties in goa a few years back... it was NYE 04 - 05. Instead of the usual stacks of sound they had a different setup that time around. You could "feel" the music all the way back of the field... simply amazing. I have the older 6.5" JBL comps for the front, will run that of my old alpine 240 ![]() Your right about the sub, I dont plan on blowing it at all. After having to make do with the bass from the rear 6x9" for the last 1.5 years its time to treat myself to some nice subtle bass. My friend is allready excited about "blowing" up the neighbourhood but none of that for me... I just wanted to be able to get that little extra at those well constructed break-downs...
__________________ "I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson |
| | #36 (permalink) |
| Senior - BHPian | Gunman has been kind enough to confirm that 6.5" can be accomodated in the front door of the santro. Manual windows is not a problem as evident in the pictures provided by him in this thread (Suggest Front Components for Santro (With Pics if possible)) So I guess I dont need to waste time or money building the enclosure building, instead I can use the money for some dampening for the front doors ![]() ![]() Though im curious in relation to the above enclosure, how would it affect SQ /stage ??
__________________ "I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson Last edited by s0uljah : 27th August 2006 at 12:26. |
| | #37 (permalink) | ||
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
Although not indicated in the plot, I would suppose that the recommended ported enclosure would lend some more spl in the bass without more input power, could be a good option if you think you could precisely supervise a carpenter. We have the box diagrams anyway, and all you need to verify the job is a measuring tape. For the front (and this part is really important for house-boys, I am one), don't make a pod that doesn't open out into the door. Use the door's volume, and damp the door really well. The door usually resonates at the same frequency as the kick-line in most electronic music, and you hear like a muffled thud, accompanied by a whirring sound.. that is irritating. It should be nice, crisp and agile. One good way is to give plenty of power and ensure headroom (kicks are actually smaller transients, and take up the most continuous power when playing a dance music-ish waveform). Cut it nice and low on the crossover, like 80 Hz (you can cut off any 6" comp at 80 Hz, it only limits its loudness as compared to cutting off higher, hence use a powerful amp). Next, make sure you don't have air-leakages from the sides of the pod/ ring/ door panel. You should seal this after all the reinforcement went in. Next, play with the subs cut-off frequency and slope till you find the sound as integrated as possible. Theoretically, if the comps are rolling off at 80Hz, it should be likewise for the sub so that their -3dB points co-incide. However, in reality, you may find that results vary thanks to the car's cabin help. Its also useful to have a head unit that allows you to use different slopes on the crossover. Having done all this right, you should have a stomping system.
__________________ Operator! Give me the number for 911! | ||
| | #38 (permalink) | ||||||
| Senior - BHPian | Quote:
Also i just wanted to state that I havent been talking to a regular carpenter for the enclosure. Its a guy who builds speaker pods, planks, enclosures for the car accessory walla's... basically the source. So they have some experience with the buildling... I just need to make sure I get the required finished product. If I go with this custom option I plan on procuring quality connection terminals and pop them in the box instead of the local wire terminals these boys use. Quote:
oh btw Im using th epioneer 7650 hu. Quote:
Thank You !
__________________ "I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson Last edited by s0uljah : 29th August 2006 at 23:29. | ||||||
| | #39 (permalink) | |||||||
| Quote:
By sealing, I meant that the edges of the door panel be lined with a sealant to avoid air from the door coming into the cabin. Of course the speaker edge should be sealed too, to avoid front/ back wave cancellations. Quote:
__________________ Operator! Give me the number for 911! | |||||||
| | #40 (permalink) | ||||
. . . Now coming to a fresh question for the installers / DIY chaps here.... have you ever fitted fans to facilitate cooling down amps ?? Along with using atleast 4 gauge wirie (or thicker!!!) I was told to try and do this if possible. Get a 3" fan with atleast 0.14amp power At the same time Im hoping to be able to mount the amp beneath the front so as to save wiring cost and also I guess it wont cause voltage drops.. so fitting a fan doesnt seem like it will be possible under the front seat !
__________________ "I’m in no condition to drive…wait! I shouldn’t listen to myself, I’m drunk!" - Homer J. Simpson | ||||
| | #41 (permalink) | |
| | #42 (permalink) | |
Now about the fans ?
| | #43 (permalink) | |||
| Quote:
| | #44 (permalink) | |
Yes B&T, I was cautioned as they consider India very veyr very hot place. hehe. Currently the sony 502 under my seat seems to be doing fine. Also correct me if Im wrong but I doubt I can get 4ga in small quantities ? 4ga will probably cost me a fortune... also :( Now this brings me to another part of my ICEing budget - cabling ! Equipment : Amplifiers :
With the above mentioned equipment I reckon I will require
Now its time for the ice heads to work out some options for me & PRICING. I know budget doesnt mean a thing to any of you but do keep in mind that Im not looking at cheap cheap boss.. neither do I want platinum !!! heheApproximate pricing for each of the mentioned items would be reaaaaaaaaly helpful... prices I can expect to pay in India that is... for everything else I can google ![]()
| | #45 (permalink) | |||
| Quote:
And ideally you should get a 4-ga amp wiring kit. It would set you back by about 3-4k I would reckon. Quote:
4-ga kits also sometimes come with small quantities of 8-ga cable that you can use from a dist. block (in the kit too) to wire the speaker amp. Let a 4-ga line go to the subwoofer amp. You might need a maximum of 15 meters of 16-ga speaker cable and 5 meters of 12-ga subwoofer cable in addition to the kit
| Thread Tools | |
Similar Threads | ||||
| Project: Santro custom Interiors with pics...!!! | kpzen | Modifications & Accessories | 50 | 10th December 2007 21:31 |
| (Pics)DeSoto Custom sedan in Pune. | sajo | Vintage Cars & Classics in India | 4 | 13th February 2007 10:06 |
| 2005 Innova Custom audio install | A S H V I N | Ask the Gurus | 9 | 15th November 2006 00:26 |
| Help needed to for an high end install | hitchhiker | Ask the Gurus | 33 | 19th May 2006 12:24 |
| Install Pics from our collection !!! | Autophile | Sound Off and Show Off | 50 | 26th September 2005 13:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342
) enjoys it best with a really attacking midbass and HF. The subs have to be kept to the bare minmum. Not overpowering the rest of the band, and yet strongly there when that bassline comes along.
