Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 28th April 2015, 13:12   #16
mukeshgoel's Avatar
Thanked: 379 Times
Default Re: DIY Install: LED cabin lights for the Maruti Swift
I installed a 48 SMD LED in my Swift last December. Light is too good and I am glad that I installed it.
Bought it from ebay at around Rs.150/- with some discount coupon.
http://www.ebay.in/itm/Super-Bright-...-/271623727959
This pic is from ebay listing. Will post my car pic soon.
Earlier I had installed a 16 SMD LED but it was not sufficient to illuminate the cabin
mukeshgoel is online now   (1) Thanks Reply With Quote
Old 28th April 2015, 15:45   #17
nishantbhatia84's Avatar
Thanked: 259 Times
Originally Posted by sinhead View Post
Guys, some cars have a dimming effect when the door is closed, ie the light dims and switches off slowly, instead of switching off instantly.
Will that dimming effect still be there if I use these?
I've got the threater dimming effect in my Figo as well, but once I replaced it with the 28 SMD LEDs it now switches-off immediately.
Originally Posted by Blow Horn Ok View Post
Tried the same mod in figo 2 years ago by ordering the stuff from aliexpress in 1.2 dollars including shipping. The result was bright but the color temperature felt harsh on eyes and the led kept glowing little bit even in off position. The bulbs started to flicker in 2-3 weeks and created an irritating disco. Replaced it with the OEM bulb.
Hope this is the better of better quality and serve you for long period of time.
Even on my Figo the led bulb stays slightly on at all times. The bulb is still working so I havent bothered much! Looks like a known issue with Figos w/r/t leds.
nishantbhatia84 is offline   Reply With Quote
Old 28th April 2015, 16:11   #18
paragsachania's Avatar
Thanked: 10,941 Times
Originally Posted by FordDodo View Post
Nice upgrade, the Parag style. I know many people whom Parag has helped doing this DIY, in the same way he has done in his Ertiga and WagonR. A much needed mod in Classic cars, to save on the energy.
Thanks! In fact these LEDs have a Rajkot connection in both car cars. Both of them got their LED Cabin lights when I drove to Rajkot in WagonR earlier and Ertiga later .
I have loads of time here at my relative's Automotive workshop that saw a few of these LEDs and plonked them in my cars.
Originally Posted by funkykar View Post
A very common thing that most people nowadays do. Had done it on some of my cars. On my Palio, Parag did it for me well as installing the FIAT projection light for both doors.
True. I think replacing cabin light is something many may not have tried thinking its a complex task or for the reason that it fuses very rarely.
In fact, what I have in the WagonR and Ertiga are of these type which doesn't need a separate connector as the LED Board itself is designed in a way that its a direct fit:
Name:  LED Cabin Light.jpg
Come on, you guys do it for the looks, brightness & functionality . What power conservation? The cabin lights are on for barely a couple of seconds in a car's daily routine. It would have zero effect on the battery.
I did it for curiosity and nothing else especially when the tints were removed after the Ban, the huge glass area in both the cars (WagonR and Ertiga) and then the lighting up of the interiors with these brighter and whiter shade.
In fact, the only time I usually turn on these lights is to arrange cash for paying up at the next toll booth or taking out the right toll receipt to show at the booth.
In WagonR I have installed another roof lamp exactly at the top of the Second row. This became a necessity due to my daughter who often wanted the light to be turned on for no particular reason when she was barely 6 months old. Having the primary light (Near the IRVM) On and driving was not a good idea that made me install the second one.
I bought the cabin light for the Esteem at a price of 90 Bucks and did a parallel wiring by running 3 wires from the primary roof lamp behind the roof ceiling to this second light.
So, when any of the door opens in the WagonR, both these light up. Also, both of these can be controlled individually based on ON-DOOR-OFF Position irrespective of their relation.
I didn't have to drill any holes to mount the second light but merely used Fevicol SR Synthetic adhesive to paste this to the roof carpet. A very small (3cmX3cm) portion of the roof carpet was cut to take the wires originating from the primary cabin light.
Will try to post the pictures later today when I have the WagonR at home as this was done at least 4 years before and I had never thought of creating a DIY thread then!
paragsachania is online now   (7) Thanks Reply With Quote
Old 28th April 2015, 16:17   #19
v_safari's Avatar
Thanked: 59 Times
These LED/SMD roof lights are available for mere Rs 30 - Rs 45 per piece, depending on the size and number of leds in Kashmiri Gate automobile accessories market here in Delhi.
I
v_safari is offline   (1) Thanks Reply With Quote
Old 28th April 2015, 16:38   #20
akash_m's Avatar
Thanked: 88 Times
GTO, the cabin lights come in handy when you are eating from a fast food joint at night, sitting inside the car (in winters). This might take 30-45 min. I say in winters because in summers, the engine is usually running because of the AC.
akash_m is offline   (2) Thanks Reply With Quote
Old 28th April 2015, 16:54   #21
SunnyBoi's Avatar
Thanked: 2,794 Times
Nice Mod. I picked up a gigantic 48 LED panel with the festoon adapter from eBay for ~65rs after discounts. It was really big and barely fit in my car's roof light
However the light was so damn bright, my friends nick named it "cricket stadium lights" after seeing the lights on in my car
Not able to find the original listing but this one seems close :
http://www.ebay.in/itm/Car-Auto-Dome...item3ccbcdcea1
SunnyBoi is offline   (3) Thanks Reply With Quote
Old 28th April 2015, 18:26   #22
Thanked: 13,387 Times
Yes, my Swift has the 'dimming-effect' and it works pretty well with these LED's too.
Why not try again and see if the problem repeats or no.
Hopefully these are reliable and long lasting.
+1.
48 SMD will be dazzling bright. Awaiting the picture. Now that's one bright car!
Old 28th April 2015, 19:45   #23
madhav14's Avatar
Thanked: 117 Times
Nice DIY there. After seeing the LED light pic, the old pic looks like some kind of lantern was set up there.
Awaiting your LED arrival for the DIY in your car too.
Next is to get into replacement of OEM bulbs of tail lights, indicators, parking lights into LED's.
Can't wait any more dude!! Let's meet up this weekend and do the same on my car too. Also I'm quite excited about the tail lights and indicators now. Let's plan that as soon as possible.
madhav14 is offline   Reply With Quote
Old 28th April 2015, 22:30   #24
autotranny's Avatar
Thanked: 209 Times
Anurag, my car will be driven to Pattancheru on a weekend. You will be doing the DIY, while I relax
autotranny is offline   Reply With Quote
Old 28th April 2015, 23:10   #25
latentpotential's Avatar
Thanked: 377 Times
If you guys have access to, consider using warm white lights instead. They look & 'feel' much better, especially in the Swift than cool white and the reach is more with smaller lights.
latentpotential is offline   (1) Thanks Reply With Quote
Old 28th April 2015, 23:57   #26
Done sir.
I'll be waiting for your car and do order the part as well now.
Old 29th April 2015, 00:41   #27
WildInstincts's Avatar
Thanked: 59 Times
Thanks for this DIY. I too wanted to do it in my Swift but was thinking it would mess up the original setup and I wouldn't able to go back in case I want to. After seeing your post, it is clear that the mod is very simple and can be put back very easily. Will try it soon.
WildInstincts is offline   (1) Thanks Reply With Quote
Old 29th April 2015, 10:20   #28
So this is the LED doing duty in the WagonR since 2011.
DIY Install: LED cabin lights for the Maruti Swift-1430283001828.jpg
This Pic shows the Second light that I installed for the rear by running wires parallel to the OE Lamp near IRVM.
DIY Install: LED cabin lights for the Maruti Swift-1430283015670.jpg
paragsachania is online now   (2) Thanks Reply With Quote
Old 29th April 2015, 12:40   #29
TheLizardKing's Avatar
Thanked: 484 Times
Hi Anurag,
DIY Install: LED cabin lights for the Maruti Swift-img_20150429_115836.jpg
Ze Germans have been very very efficient with the usage of space, and I am not sure if there is enough room in the ceiling light compartment of my Polo. Can you give me the exact size of the LED panel? It is not available in the product description on the Snapdeal website...
I have a feeling it is not going to fit. I guess I will end up buying this one instead...
Product URL: http://www.snapdeal.com/product/spee...d-car/62780493
TheLizardKing is offline   (1) Thanks Reply With Quote
Old 29th April 2015, 12:56   #30
Thanked: 91,845 Times
What difference does it make, buddy? Your alternator will anyway fully charge the battery within 1 - 10 minutes of driving away from the restaurant.
That said, yes, if keeping the cabin lights on for an extended duration, your odds of ending up with a drained battery are lesser with LEDs.
GTO is offline   (1) Thanks Reply With Quote
VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights Gannu_1 DIY - Do it yourself 79 31st October 2017 09:18
DIY Install: LED Bumper Reflectors for the Ertiga paragsachania DIY - Do it yourself 36 29th June 2017 21:12
DIY: LED Tail lights on my Fiat Linea T-Jet ZBlue DIY - Do it yourself 19 30th April 2015 15:01
DIY interior courtesy LED lights - Punto Emo pack. madhunm DIY - Do it yourself 16 22nd April 2014 18:05
DIY underbody LED lights on Polo and i20 599gto DIY - Do it yourself 15 6th June 2013 13:44
