Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 23rd June 2015, 09:51   #16
shashank.nk's Avatar
Thanked: 749 Times
Default Re: DIY: Maruti Suzuki Swift Bi-Xenon Projectors. Morimoto FX-R 3.0 Installation
Thread moved out from the Assembly Line (The "Assembly Line" Forum section) section.
Awesome work Shashank! And the results speak for themselves. The horizontal alignment seems a wee bit off but you can always correct it at your leisure. You have logged all the steps painstakingly. Thank you so much! Rating the thread a well deserved 5 stars.
Thank you Gannu! The light output is totally worth the effort.Yes, the alignment needs some fine tuning,I left it as it is since I was quite tired that day. In the Swift one has to get the bumper off everytime any adjustment is needed,so will have to keep aside a day for it.
shashank.nk is offline   Reply With Quote
Old 23rd June 2015, 10:39   #17
mayankk's Avatar
Thanked: 3,559 Times
That is pretty nifty, and such a neat job!!
Youve inspired me to take another shot at my lights.
M-seal, why I didnt think of it?
My projectors start bouncing around after a few days. But then again, theyre cheap chinese ones.
What bulbs do these take, H4s? And are the HIDs interchangeable with Halogens?
mayankk is offline   (1) Thanks Reply With Quote
Old 23rd June 2015, 10:52   #18
Thanked: 749 Times
Thank you Its not as complicated as it appears to be,just needs patience and good research prior to commencing the work.
If there are vibrations or if the alignment goes for a toss after every drive,based on what I've learn't it can be two reasons:
Not enough glue (or in case of mini d2s type,the bolt/nut isn't holding up well)
or
Adjustment screws are maxed out, and the additional weight of projectors compared to a H4 bulb (more relevant for Fx-R since with glue its quite heavy) is creating issues.
or both.
These take the more popular D2S bulbs. I remember reading something on how halogen projectors are different compared to HID projectors,so may not be advisable to swap bulbs if its the main beam.
shashank.nk is offline   (1) Thanks Reply With Quote
Tata Xenon Crew-Cab launched : The Downgraded variant of Xenon XT jeepster Commercial Vehicles 183 11th March 2018 22:59
DIY: VW Polo Bi-Xenon Projectors. Morimoto Mini D2S Stage III Installation Gannu_1 DIY - Do it yourself 76 20th September 2016 12:42
PICS : Installed Bi-Xenon Projectors on my Innova nitinbose Modifications & Accessories 20 21st September 2015 20:43
DIY : HID (3000k) Installation in the Maruti Swift ACMohan DIY - Do it yourself 8 17th December 2012 18:44
