Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 14th December 2015, 17:07   #46
procrj's Avatar
Thanked: 2,693 Times
Default Re: DIY: Hardwiring your Dashcam
Modified the Power supply provided with the camera in order to hardwire. The power supply was originally meant for the 12V socket but yours truly did an implant surgery on the adapter
Can you elaborate a little more on this? Have ordered the same dashcam based on your review on the dashcam thread and want to hardwire the connection. Also do let us know if this is working fine or if you have had any issues because of this jugaad.
procrj is offline   Reply With Quote
Old 14th December 2015, 19:08   #47
audioholic's Avatar
Thanked: 6,007 Times
Basically, the dashcam comes with a power adapter that you should connect to the cigarette lighter socket. This is not an actual hardwired setup. Instead, I soldered wires into the power adapter and connected the other end to the fuse tap. This way, the adapter could directly draw power from the BCM and the cigarette lighter socket/12V socket will be left free. You can see from the images that I have drawn wires from inside the power adapter which I used for further connections. Now that adapter won't work if plugged in the conventional way since I have removed the outer contacts that exist.
audioholic is offline   (1) Thanks Reply With Quote
Old 15th December 2015, 17:10   #48
vsathyap's Avatar
Thanked: 829 Times
Can you please confirm if I need to get a ATM fuse Tap? I have the new Alto K10 with me. Owners manual simply says "fuse" and does not provide any description.
vsathyap is offline   Reply With Quote
Old 17th December 2015, 09:23   #49
ghodlur's Avatar
Thanked: 2,405 Times
Question Re: DIY: Hardwiring your Dashcam
Dashcam experts,
Where can I get a longer length min 5 or 10 mts mini USB cable with cigarette lighter connection on the 12 V socket. I am asking this for my MMI GPS unit which comes with mini USB connection port. The present cable is too short and interferes with the gear stick and looks bad in present hanging condition. I am not too interested in tampering with the fuse box connections. The car in question is Grande Punto.
ghodlur is offline   Reply With Quote
Old 17th December 2015, 11:01   #50
audioholic's Avatar
You should the fuse tap sized medium as per most online websites. Only the large taps meant for older fuses wont fit into the Alto. The smaller sizes have same blade width and only the size of the fuse will vary AFAIK. My WagonR and SX4 have different types of fuses and yet the same fuse tap fits both. .
EDIT: As per wikipedia, it is the Mini fuse in my SX4 and Low profile Mini in my WagonR. Both are the same in terms of contact points and only the body of the fuse is different.
audioholic is offline   Reply With Quote
Old 19th December 2015, 20:56   #51
vsathyap's Avatar
Thanked: 829 Times
I did a little research on the Fuses of the new Alto K10.
As a reference, I am posting a pic of all the types of fuses available in vehicles. This pic has been taken from Wiki and all ownership and copyrights are those of the original submitter. Referring here for educational purposes only.
I checked the user Manual of the New Alto K10 and here is what the fuse board and the fuses and their ratings looks like:
Now, after peeking below the steering, right next to the OBD2 Port, I find the block of fuses and here's what it looks like - exactly like the fuse diagram given in the user manual.
DIY: Hardwiring your Dashcam-img_20151219_103628.png
Looking back at the user manual and referring the fuse type from the Wiki Image, I am satisfied that the Alto K10 uses the ATM Mini Low Profile type fuse. I go ahead and add it to my cart on Amazon and was about to order the Fuse Tap. Sixth sense prevailed and I decided to have a look at what type the fuse is. This is after many customers had the feedback that the seller shipped the wrong type of fuse which did not match with their vehicle.
Now, even one of the posts above mentioned something about the Low Profile type ATM fuses for the K10. But, I decided to check for myself nonetheless - after all, seeing is believing!
Fast forward 5 minutes and I have a surprise! The Alto K10 uses the REGULAR PROFILE type of ATM Mini Fuse.
Others can also chip in with their vehicle's fuse types so that this becomes somewhat of a "FYI" for your "DIY"
All said and done, I'll be ordering the Mini ATM "regular profile" Fuse Tap from Amazon in some time. Looking at the Fuse Diagram from the User Manual, can anyone suggest where I could possibly connect the fuse tap? Logically speaking, I'd like my Dashcam (I plan to use my Xiaomi Yi Cam) to get power as soon as the Ignition is in Position 2 (just before the crank).
Inputs and feedback welcome!
vsathyap is offline   (1) Thanks Reply With Quote
Old 19th December 2015, 21:31   #52
audioholic's Avatar
There will be no difference between ATM regular and ATM low profile when it comes to fuse tap as I mentioned in my previous post. The tap will fit in either socket without issues. The contact points are the same and only the fusible link location will change with regular and low profile. So in case it is swapped, it wont be an issue.
Coming to where to tap, the Accessory fuse is where you should tap the connection from. From what I have seen, that is the only point that gets powered up only when the key is in ACC position. Rest all are powered by default irrespective of the position of key. Even I wanted it to turn on in second position. But I couldnt find a suitable point to tap. Next time I will check the power steering fuse, which I did not do last time.
Old 19th December 2015, 21:54   #53
vsathyap's Avatar
Thanked: 829 Times
Do you know what the IG2SIG refers to in the User Manual's Fuse Lookup Table? Plus, how do I test the fuses for power ? I have a regular household tester that I use for testing 220V AC power sockets. Will the same thing work ?
I saw a "jugaad" setup for this at one of the local accessories shop - the guy has a bulb which has 2 wires soldered to it. He grounds one end of the wire to the body and the other end to "touch" connections to check power delivery. If the bulb glows, its ON, else, he asks his buddy to turn the key / honk / etc. He then figures how to go about the wiring for the actual circuit. Dont know what bulb and what rating he was using.. it was so old and dusty that I was wondering what he was upto. Didnt realize what he did until I connected the dots and figured it out and I was like duhhh
Old 19th December 2015, 22:07   #54
Thanked: 14,356 Times
IMO, it means 'IG'nition 'Si'gnal.
Look at the things I used when I did a DIY for installing the Auto-dimming IRVM using a Hard wiring kit.
Tools Required (DIY Install: Auto-Dimming IRVM & Anti-Glare ORVMs)
Here are links to buy:
Link to Buy (DIY Install: Auto-Dimming IRVM & Anti-Glare ORVMs)
Link to buy the tester for checking the Fuses:
12V Car Voltage Tester
My Swift uses the Low-Profile ATM Fuse:
Low-profile ATM Fuse
a4anurag is online now   (1) Thanks Reply With Quote
Old 22nd December 2015, 12:22   #55
Thanked: 26 Times
Hello,
Does anybody have fuse details (layout details) for Skoda Rapid?
I have a Blaupunkt 2.0 dashcam for which I am using the lone 12V socket that is available in the car.
In order to tap a connection from any of the fuses (either to have second 12V socket or to connect dash cam cable directly, I am in search of the fuse details. The owner's manual does not mention any details, neither the service people share it.
JitendraK78 is offline   Reply With Quote
Old 9th September 2016, 14:07   #56
dpkbehera's Avatar
Thanked: 207 Times
Nice to see you back after a long time. I think you were away for some time in between. This post has an amazing attention to detail. Fuses,Wiring etc i thought were beyond me and as a result stayed away from them. However this article did bring clarity on them. I need to use both the dashcam and mobile (navigator). But since i have only one 12V socket in front, will have to look at the options mentioned by you. However in the long run, as you mentioned it is always better to go in for hardwiring.
I am guessing irrespective of hardwiring, it is always better to keep the following for long road trips i.e.
Car Radio Stereo, Dash Removal Install Tools (Set of 12)
Low-Voltage Car Electric Circuit Tester
Emergency Fuse Kit
dpkbehera is offline   (1) Thanks Reply With Quote
Old 11th September 2016, 20:35   #57
arunphilip's Avatar
Thanked: 4,816 Times
Thank you for your kind words. Yes, I'd gone on silent mode for a few months, but am now back to contributing
While I will still recommend hardwiring the dashcam to make its operation transparent and automatic, you do have a few other options:
Get a Dual-Port Car Charger
If your 12V socket switches off when you turn off the ignition, then you can use a dual-port car charger. I personally recommend and use this Aukey charger, because I trust the brand, and because it has a healthy 2+ amp output per port. The charger is also very compact, and sticks out only about 1-2 mm from the socket.
If you also get a lengthy USB cable (like this 10-foot one) you can use it to route the cable to the dashcam quite neatly in the way I described. This will help you minimize wiring clutter.
Get a Y-Cable for Mini-USB and Micro-USB
There are Y-cables which have a regular sized USB port on one side (i.e. a USB A male port), and have 1 mini-USB and 1 micro-USB port on the other side. You can use this to change your phone and run your GPS using just a single USB port.
For example, consider this Y-cable. I would personally look at this Y-cable from Amazon.com since it has good reviews.
Size:  23.6 KB Name:  31brXA58L.jpg
The cable lengths are pretty short, so you might require extension cables based on how you usually position your dashcam and where you keep your phone.
Emergency Fuse Kit
I definitely agree that keeping the 12V circuit tester and an emergency fuse kit is a good idea. The dash removal tools are required only in those cars where we cannot access the passenger compartment fuse box directly (our EcoSports are a great example of this! ).
arunphilip is offline   (3) Thanks Reply With Quote
Old 26th September 2016, 11:29   #58
Thanked: 2,518 Times
How do you guys identify which type of Fuse tap would fit the vehicle? Seeing the fuses in the fuse box, I am confused between the standard and mini one.
Anyone hardwired a dashcam in a Scorpio?
Dry Ice is offline   Reply With Quote
Old 26th September 2016, 12:07   #59
arunphilip's Avatar
This is how the different fuse types look. Look at the shape and size (both width and height) of the pins when comparing.
Do you have a picture of the Scorpio's fuse, lying flat, to compare? You might not have to access and remove a fuse, your Scorpio's emergency kit should have a few spare fuses in there. Page 21 of the owner's manual shows where the fuse box is present, by the way.
Last edited by arunphilip : 26th September 2016 at 12:10. Reason: Resized image for watermark
arunphilip is offline   (2) Thanks Reply With Quote
Old 26th September 2016, 12:24   #60
Thanks Arun. So very nice of you to pull the owner's manual. Mine is actually the previous gen but the fuse box locations are identical. I had removed one from behind the steering wheel (from where I wish to route the wire), but did not take a picture. To my eyes, it looks like a mini fuse. But I am not really sure. I will try to get a picture by evening. The pain with ordering from Aliexpress is the long drawn delivery time. God forbid if I order the wrong one, that 60 day cycle will start again!
That is why I want to be sure before placing the order.
Dry Ice is offline   (1) Thanks Reply With Quote
The Dashcam / Car Video Recorder (DVR) Thread SS-Traveller In-Car Entertainment 2260 18th June 2018 07:54
DIY : Debadging your ride s0uljah DIY - Do it yourself 224 16th April 2018 12:16
Use your Camcorder/Digicam as a Dashcam for Rs.100 mukeshgoel Modifications & Accessories 20 15th September 2015 14:24
Ford Figo DIY for USB cable! How do I DIY? fedexp In-Car Entertainment 51 27th February 2013 21:22
