Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 19th November 2015, 15:08   #31
rohitnp's Avatar
Thanked: 37 Times
Default Re: VW Polo DIY: Cruise Control!
Awesome stuff! This and the steering upgrade really had me wowed! Though I could never imagine DIbY (Doing It by Myself). Seems too much at stake and too many things to know about. Would love to have someone else do it for me though! :-p
rohitnp is offline   (1) Thanks Reply With Quote
Old 19th November 2015, 20:00   #32
Gannu_1's Avatar
Thanked: 10,403 Times
Thanks guys! The ECU removal part is not scary at all once you get started. Just remember to disconnect the battery if there's any electrical work involved in the car.
Originally Posted by Rajeevraj View Post
Can you come to Bangalore and do it for me (or a bunch of us)?
Originally Posted by srinivasnvns View Post
EDIT: As Rajeevraj mentioned, maybe you should come down to Bangalore for a master class session.
Not headed there any time soon guys. Will be driving to Palakkad next year - if Bangalore is a pitstop en route, I shall definitely help.
If not, you guys can get this done from those Bosch FNGs. It is pretty simple once you have the steering wheel removed.
Originally Posted by bigvishnu View Post
Gannu bhai, tell me the truth. Which of the below was a bigger effort:
  1. Researching, acquiring all the parts and completing the DIY
  2. taking pictures at every stage, adding animation and call-outs on the pics, and building this thread filled with sheer awesomeness so that some of us could benefit from the same
Haha compiling this thread and collating all the snaps took me a few days for sure.
Gannu_1 is offline   Reply With Quote
Old 20th November 2015, 00:38   #33
MindOnWheels's Avatar
Thanked: 48 Times
Hi Gannu, amazing stuff. Totally blown by this post of yours. One of those best technically described post I have read in recent times. Few things:
1. Though you indicated that it took almost an year from the time you conceived this idea to reality, how much time it took from the time you got your BCM unit till you drove with it - just wanted to measure your patience
2. Not sure I missed, the cost of this project
3. Any trial & error situation or you got right the first time - any which way, doff my hat!
Time to say DIFMP - Do It For Me Please
And, keep posting such amazing projects.
MindOnWheels is offline   (1) Thanks Reply With Quote
Old 23rd November 2015, 12:43   #34
This is a fantastic post. Thank you. Have been dreaming to have a cruise control in the car. So with your post, there is still hope, that I can have it on my Polo. Of course don't have the courage for the immense research and dedication you have out here though. Great Job!!
Last edited by Gannu_1 : 23rd November 2015 at 12:50. Reason: Removing quoted post. A long quoted post inconveniences our mobile users. Thanks! :)
rockyb4u is offline   (1) Thanks Reply With Quote
Old 24th November 2015, 00:04   #35
adi_petrolhead's Avatar
Thanked: 1,052 Times
Out of curiosity, why did you not go for these stalks which have the newer design?
(Source: Google)
adi_petrolhead is offline   Reply With Quote
Old 24th November 2015, 16:28   #36
Gannu_1's Avatar
Attachment 1442829
(Source: Google)
The pricing. As much as I would have loved to get these which are now installed in the Octavia, these were almost 3x expensive compared to what I paid for the set I sourced (less than 100 Euros). Aliexpress didn't have these anyway so the other option was to import them from EU. Wasn't worth it.
Old 24th November 2015, 17:36   #37
I did see a few links on Aliexpress. Here is one, but I think a steering module is needed with it.
http://www.aliexpress.com/item/Volks...rchweb201560_1
Old 24th November 2015, 17:43   #38
Gannu_1's Avatar
Won't fit on the Polo. That unit is for the Golf. The mounting holes for the stalks used on the Polo are on the top plane:
VW Polo DIY: Cruise Control!-wp_20150918_20_17_53_pro.png
whereas those for the Golf's unit is on the front plane:
I am betting even the connector at the rear would be different.
Old 24th November 2015, 19:33   #39
Spot on! But the newer stalks look much nicer and even the action is very tactile compared to Polo original stalks (I have a Vento). May be later you can source it for cheaper, I think 200$ is a fair price for these premium stalks.
Old 24th November 2015, 21:07   #40
Gannu_1's Avatar
Adi, the new stalks for the Polo 6C will not fit the 6R models. Their construction is entirely different (mount holes as I had mentioned in the previous post), the clock spring is different and the connectors as well. Here are the pics:
VW Polo DIY: Cruise Control!-_57.jpg
VW Polo DIY: Cruise Control!-6c095965313.jpg
Found a few links on eBay Germany and UK (E.g.) retailing these stalks for as cheap as 100 Euros but no point anyway since they wouldn't fit on our cars.
Old 15th February 2016, 14:05   #41
sivasain's Avatar
Thanked: 69 Times
Hi Gannu,
This is a great DIY. Hats off to you. I have not gone to this level yet.
I am very keen to do this one my 2013 GT TSI. But have some questions.
1. Has anyone here done this on the 2013 GT TSI ?
2. I have the 087 series BCM. So would it be compatible. Anyway to check it without having to remove the BCM and looking at the PINS ? Can i see if it accepts the Coding ?
3. Will the cruise control work with the original cluster? Does it have the CC light ?
Thanks in advance.
sivasain is offline   Reply With Quote
Old 27th February 2016, 23:49   #42
Gannu_1's Avatar
All the 087 series BCMs except the F variant has the cruise control terminals. You can use VCDS to check what variant you have. Do a Google search - you can find the pics of most BCMs online.
Cruise control works but the cluster doesn't have a notification LED. The newer clusters with the white backlit MFD has the notification LED.
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 10th March 2016, 12:05   #43
vin_b's Avatar
Thanked: 243 Times
Hi Gannu,
I have read your DIY thread multiple times to get courage to go ahead with CCS installation for my Vento Comfortline TSI 2015 (pre facelift), but decided not to do DIY but instead source the necessary parts and then probably head to BOSCH service centre or VAGTUNE for installation. I have couple of queries in sourcing the parts
1. In Aliexpress, I can find the part 6RD 953 503J . Since I have trip indicators on my right stalk, I am hoping its a straight swap.
2. Would I be needing different airbag slip ring and if needed can I use the same one existing stock one
3. Would I be needing any additional wiring ? One of the comments in Aliexpress said that it doesn't come with EPS wiring which has got me worried
vin_b is offline   Reply With Quote
Old 10th March 2016, 20:26   #44
Gannu_1's Avatar
It should be but you may face an issue w.r.t. the stock slip ring unit.
I suppose this one does not have a steering angle sensor and since your model is a TSI (which has ESP), you will need a slip ring with a steering angle sensor.
Best to ask the dealer not to ship the slip ring - he can deduct the amount from the net price and you can use your stock slip ring. At best, you may have to chop off some plastic bits from the stalks unit like I did to accommodate the stock slip ring on the European stalks but that isn't a deal breaker.
Can't say about the wiring part unless we know what the Aliexpress dealer is bundling. There's a harness and that's all I can see. Insist on some clear pics of the harness.
Old 11th March 2016, 10:10   #45
vin_b's Avatar
Thanked: 243 Times
Thanks for the heads up on the slip ring. I will contact the seller not to ship the slip ring and will plan to use the stock one.
I have dropped seller a note on this, but in mean while I stumbled across a pdf from one of the European forum (probably the same person from whom you purchased the stalk) on what needs to be modified for wiring if purchased from Aliexpress. What are your thoughts on that ?
File Type: pdf POLO 6R. Wiring cruise control system. CCS.pdf (1.34 MB, 683 views)
VW Polo GT TDI ownership log. Update: 130,000 km up + new set of Primacy 3STs! Gannu_1 Long-Term Ownership Reviews 1077 10th June 2018 08:37
Aftermarket Cruise Control turbo_c Technical Stuff 46 10th February 2018 23:37
Active Cruise Control in BMW sanjaykk The International Automotive Scene 24 25th February 2008 10:50
HELP! cruise control failed, Octavia RS da MotorHead Technical Stuff 11 21st September 2006 22:06
Installing a cruise control Tarun Modifications & Accessories 52 27th March 2005 21:24
