Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 19th November 2015, 18:02   #31
batterylow's Avatar
Thanked: 677 Times
Default Re: DIY Install: Auto-Dimming IRVM & Anti-Glare ORVMs
There is one thing that we all drivers/riders hate during our daily drives
Great work Anurag, one quick question, the IVRM in my figo is stuck on the front windshield, any ideas on how to proceed with such a case?
batterylow is offline   (1) Thanks Reply With Quote
Old 19th November 2015, 19:41   #32
Thanked: 13,390 Times
Thanks buddy.
Can you take a picture of your Figo's IRVM + IRVM mounting point and attach it here, I'll contact the seller and get the solution.
a4anurag is offline   (1) Thanks Reply With Quote
Old 23rd November 2015, 14:55   #33
hrbheda's Avatar
Thanked: 42 Times
Great DIY a4anurag!
My IRVM is also stuck to the glass and I have the reverse sensor mirror attached to the OEM IRVM. As soon as I change the display of the reverse sensors and figure out the mounting procedure I'm doing it too!
Again, Great job! Cheers!
One question! Do you plan to do this mod to your other cars?
hrbheda is offline   (1) Thanks Reply With Quote
Old 23rd November 2015, 18:31   #34
Thank you the appreciation.
Currently no as on but there are some practical driver useful modifications coming up for my Alto K10.
Old 23rd November 2015, 18:52   #35
hrbheda's Avatar
Thanked: 42 Times
Can't wait for them! Always an interesting read!
Old 23rd November 2015, 21:52   #36
manas_270's Avatar
Thanked: 80 Times
Congrats on the mods and the well documented DIY anurag. Rated a well deserved 5-stars.
One suggestion if I may, it would be nice if you could add the link where you bought each of the items from for e.g. the 12V tester, interior trim remover, crimp plier set etc. so that folks wanting to buy can do so with confidence.
manas_270 is online now   (1) Thanks Reply With Quote
Old 24th November 2015, 09:56   #37
Thank you for the appreciation. Here are the links for the items for purchase:
1. Auto-Dimming IRVM
2. Fuse tap cable with Extra Fuses
3. 16AWG Wire (Red & Black)
4. Crimping tool kit with connectors
5. Heat shrink tube set
6. 12V Voltage Tester
7. Philips Hair Dryer
8. 12 pcs interior panel removal kit
9. Wire/Cable Holder
Hope this helps.
a4anurag is offline   (4) Thanks Reply With Quote
Old 26th November 2015, 18:22   #38
Thanked: 2,073 Times
Awesome information as usual Anurag!
Can you recommend a IRVM that is auto-dimming as well as with dashcam in it? I need both of them and want to avoid pulling too many wires. If there is single unit that does this would be nice! I saw few on AliExpress but not really sure which one I should go for. Please suggest.
abirnale is offline   (1) Thanks Reply With Quote
Old 26th November 2015, 18:57   #39
Hello Avinash bhai,
Thank you the appreciation, tethering the IRVM with dash cam, I have found one link below:
http://www.aliexpress.com/item/170-D...319110290.html
I have simultaneously contacted the seller for suggesting an IRVM that has both auto dimming + dash cam option. Please give me a day's time for the seller to respond. Will update you accordingly. Thanks.
PS: I have no connection whatsoever with the seller and AliExpress.
a4anurag is offline   (2) Thanks Reply With Quote
Old 26th November 2015, 22:52   #40
Hello, just received a response from the seller. Here it is:
He too has recommended the same IRVM that I have in the above post.
Hope this helps.
Old 27th November 2015, 08:56   #41
Awesome buddy! I am buying it. Will have to figure out what bracket will work for my XUV though. Thanks a ton
abirnale is offline   Reply With Quote
Old 27th November 2015, 09:53   #42
sagarpadaki's Avatar
Thanked: 1,271 Times
Take a pic of the mirror mount on the XUV and mail it to him with dimensions if possible. He can suggest the correct mount then
Old 27th November 2015, 13:09   #43
Yes, I am in touch with Anurag as well over PMs. The tricky part with XUV is there is a different assembly which seem to be difficult to pull out easily. extending into sunglass holder and sunroof switches, don't want to take chances. I will visit MASS soon and figure the assembly. I anyway need to do that for DIY to be successful
Old 1st December 2015, 00:19   #44
Originally Posted by arunphilip View Post
How do you find the performance of these mirrors when driving in rain (both day and night)? Does it attenuate light excessively?
Originally Posted by AppyS View Post
I would very much be interested in knowing how fm's deal with the rain issue.
Hey guys, it finally did rain today and did drive in rains for approximate of 10 kms. The rain spell was medium but since I was on the ORR cruising at 100 kmph, visibility wasn't much an issue.
Clicked one picture:
DIY Install: Auto-Dimming IRVM & Anti-Glare ORVMs-img_20151130_182641.jpg
I see the main advantage with these anti-glare ORVM is it solves the primary problem of glare so the water droplets will not be an extra issue. Plus with a use of Rain-X glass treatment, the beading effect is better so water droplets don't stay!
Old 1st December 2015, 11:07   #45
Just to keep everyone posted, I reached out to my SA for XUV500 IRVM. Apparently it seems like a simple cover to be pulled from the IRVM and the assembly will be open. The SA advised not to do it myself unless I know the technique to open the cover on the IRVM attachment. By putting pressure on it in a wrong way, I have the risk of cracking the glass. That is alarming and hence I am now waiting for my chance to visit the MASS and see it myself, click pictures and then buy the auto Dimming IRVM with dashcam in it. if my SA is able to send the pictures of the bracket, I will at least be able to place order meanwhile.
In short, things are delayed by at least another week or so :(
DIY: Auto-dimming IRVM for the Hyundai Creta vinj14 DIY - Do it yourself 38 24th April 2017 09:17
How to reduce the glare on the ORVMs ghodlur Technical Stuff 47 7th July 2014 12:25
Anti honda?? Anti suzi?? Anti fiat?? Anti ford etc etc?? Vent out ur opinions here!!! mclaren1885 Shifting gears 3 29th June 2006 14:23
