Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 6th January 2016, 15:04   #16
Red Panda's Avatar
Thanked: 260 Times
Default Re: DIY: An overland vehicle on a budget! Storage & sleeping area in a Thar
Hello 911er this DIY project is absolutely brilliant.
Red Panda is offline   (1) Thanks Reply With Quote
Old 7th January 2016, 13:08   #17
Originally Posted by 911er View Post
This is a great design. Have one question - how did you fasten the wooden assembly to the vehicle. IF not fastened would it not be rattling and moving around? Besides you need to restrain it at the front otherwise it could push the front seats when you brake suddenly. I am planning to do something similar and with a hard top. I would also like to know if there is any one in this group who can accompany a team to say Myanmar and then to Thailand by the Asian Highway - Overlanding and some hotel stays
Last edited by tsk1979 : 7th January 2016 at 14:28. Reason: removing large quoted post
vdumashanker is offline   Reply With Quote
Old 11th January 2016, 22:08   #18
911er's Avatar
Thanked: 88 Times
Thank you so much.
Yes, having the storage loose would be a very bad idea. Not only would it move into the front seat, it would also move around and up/down on a bad road or while offroad. I have fastened the entire assembly using 3 bolts on either side. These holes, with welded nuts, are the ones on which the rear seats were mounted. I made a groove in the wood so the bolt would be flush with the top.
To further stop any rattling, I insulated the entire rear cab with heatlon foam. (See photo below). This not only helps stops any squeaks, it also helps insulate sound and heat coming from the rear cab. Let me know if I can help in any way when you're making yours. I'd be happy to!
DIY: An overland vehicle on a budget! Storage & sleeping area in a Thar-insulation-done.jpg
911er is offline   Reply With Quote
Sleeping habits / Team-BHP Insomniac's thread revtech Shifting gears 120 6th April 2016 00:25
Swift DIY - Sliding armrest with USB, LED illuminated storage, cupholder and ashtray bkc DIY - Do it yourself 4 10th January 2016 15:05
DIY: Sleeping Bed in a Scorpio bwar DIY - Do it yourself 99 22nd September 2015 19:25
DIY: Storage Bag / Space Maker for Cars kittigadu DIY - Do it yourself 18 25th October 2014 23:32
