Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 24th August 2016, 12:37   #16
Thanked: 492 Times
Default Re: Street Guardian SG9665GC v2 Dashcam: Review & Install
Harsh, one question:
In regular use, the way you have installed the dash cam, how easy or difficult is it to remove the SD card from the camera to view on the computer, and how easy is it to put it back into the camera? Specifically with the way you've positioned the camera.
Thanks and cheers
tilt is offline   Reply With Quote
Old 24th August 2016, 13:16   #17
harsh79's Avatar
Thanked: 610 Times
Thanks and cheers
The SD card can be retrieved and inserted back without removing the camera from the mount. There's enough space on the side.
harsh79 is online now   (1) Thanks Reply With Quote
Old 28th August 2016, 18:57   #18
harsh79's Avatar
Thanked: 610 Times
Night footage ( clear view after a brief shower clearing the pollution and haze)
harsh79 is online now   Reply With Quote
Old 30th August 2016, 13:53   #19
harsh79's Avatar
Thanked: 610 Times
SG9665GC vs Mobius - Night
Mobius with C2 lens - Settings - 1080p, 30fps, WDR - on, FOV - wide.
SG9665GC - 1080p 30fps, WDR - on, Metering - centre.
Old 26th November 2016, 21:14   #20
Thanked: 55 Times
Hi Harsh,
I got a generic A118 and using Samsung 32GB class 10 card with it. From day 1 it has been highly unreliable, the camera stops recording in between and several of the recorded clips are less than 3minutes(random lengths like 0:59, 1:27, 2:00 etc). Did you face such issues with Viofo A118C?
I am mulling over buying Street Guardian despite its prohibitory pricing. What card it came with, is it the high endurance type? My main requirement is reliability i.e the camera shouldn't fail to record any time even when in use for continuous periods. Please do share any information on this and help me decide.
Thanks for such a detailed review.
maverickmano is offline   Reply With Quote
Old 1st December 2016, 22:31   #21
harsh79's Avatar
Thanked: 610 Times
Originally Posted by maverickmano View Post
Hi Harsh,
I've never faced such issues with the Viofo A118C. Try changing the card and see if the problem persists. Also are you using the supplied charger?
I received a 32GB card (which I don't use) with the camera, it isn't the high-endurance one, normal 400x red and black Transcend. These are MLC based cards and are highly recommended by the manufacturer, I'm using two 64GB ones for both the SG9665GC and the Mobius without any issues whatsoever.
The GC's scores full points for reliablilty, not a single missed or corrupt recording till date.
V3 will be out soon. Improvements are a better lens, notches on the lens housing to accomodate a CPL filter (which'll be included) and a pre-flipped GPS module with a shorter cable.
Old 3rd December 2016, 21:27   #22
Thanked: 55 Times
I figured it out, it was the 'Motion Detect' feature ! it was set to 'ON'. When motion detection is set to ON, the camera records only when it detects a 'motion', so in long highway runs when there is nothing much happening camera stops recording. This feature is seemingly inaccurate and unreliable and hence advised to not to use it(Reference dashcam related forums)
At present using cigarette plug USB adapter of 'Anker' brand and my hardwire kit already on its way.
Great to know GC is very reliable and I think MLC based memory card is a must for dashcams for reliability and peace of mind.
I am afraid it would cost even higher !, any idea if it is going to be a dual channel version?
Old 3rd December 2016, 22:26   #23
harsh79's Avatar
Thanked: 610 Times
Yup, motion detect's known to cause such errors due to the poor implementation, it's been reported to be working way better for some folks with the A119. Personally if I'd want any kind of motion detect or parking mode function, my choices would be limited to cameras with proper motion-detect implementation and pre-buffered parking mode.
Don't think it'll cost a lot more than the V2 due to the CPL as it's a mass produced version, the CPL isn't out yet but from what I've read, it shouldn't be more than $20.
Again from what I've read on DCT there's a dual channel and a remote dual channel version under development, the dual channel will be out a lot sooner.
Old 5th December 2016, 08:02   #24
graaja's Avatar
Thanked: 2,648 Times
Fantastic review of a fantastic dashcam! Thank you for putting together such an extensive review with tons of comparision videos, detailed installation instructions etc.
When I was looking for a dashcam for my Polo GT TSi, I had the same priorities that you had. I had compared the A118, Mini 0806 and the SG9665. What made me choose the SG were:
  • The glass lens in the SG vs. plastic lens in other dashcams which result in better video. The Lens is the major contributor towards video quality.
  • The metal lens mount in SG vs. plastic mount in A118, which could cause image warping when exposed to higher temperatures.
  • The Novatek chipset producing high quality night time videos.
I think SG could prove to be much more reliable than the others. With these positives, I think it is totally worth spending those extra bucks on the SG.
Can you point me to the link from where I can download the latest firmware? I see that the latest firmware has speed information embedded in the video. My dashcam has an earlier firmware version that does not embed speed information.
graaja is offline   (1) Thanks Reply With Quote
Old 5th December 2016, 13:47   #25
harsh79's Avatar
Thanked: 610 Times
The latest public versions can be found here -
https://streetguardian.info/support
Beta releases here -
https://dashcamtalk.com/forum/thread...-access.16310/
My GC is on the latest Beta available.
Old 20th December 2016, 18:48   #26
harsh79's Avatar
Thanked: 610 Times
Post cleaning the front windshield from the inside and the GC's CPL using a Lenspen a week or so back, the next day I'd noticed the VLT70 clear film was peeling off the glass from one of the top corners.
The 3M SP70 had always appeared to have a very milky haze to it under white LED or T5 street lighting, the slight peeling gave me a strong urge to go park under a streetlight and check if the difference could be compared; through the inch of (now) exposed glass.
Wasn't really surprised as I did expect a cleaner/clearer view but never expected the difference to be as drastic as it turned out to be. Guess what happened next?
Street Guardian SG9665GC v2 Dashcam: Review & Install-film-001.png
Street Guardian SG9665GC v2 Dashcam: Review & Install-film-002.png
Didn't look as dark as can be seen in the pictures above when I'd gotten it installed. The samples stuck on the dealer's office glass door (that sold me) also looked like a non-tinted clear film. Seriously confused about the shade of the film that's come off.
Not too bummed as this is their inexpensive version. would it have been the CR70, that would've hurt.
Since all the videos posted in this thread have been recorded whilst the 3M VLT70 clear film was installed on the front windshield, I'll be adding new videos with and without the CPL as the film has now been removed.
New Videos without the 3M VLT70 film
Firmware - Beta 27
1080p @ 30 FPS, WDR - on, Metering - centre, Contrast - medium, CPL - no.
https://www.dropbox.com/s/vku50hu1sg...B27-1.mov?dl=0
Old 21st December 2016, 20:45   #27
harsh79's Avatar
Thanked: 610 Times
Firmware - Beta 27
1080p @ 30 FPS, WDR - on, Metering - centre, Contrast - medium.
https://www.dropbox.com/s/3dvrfl3f2eb7ir2/mkt.mov?dl=0
Without CPL
Street Guardian SG9665GC v2 Dashcam: Review & Install-vlcsnap2016122017h25m42s569.png
With CPL
Street Guardian SG9665GC v2 Dashcam: Review & Install-vlcsnap2016122017h24m53s451.png
Without CPL
https://www.dropbox.com/s/nnyizg90qp...wocpl.mov?dl=0
With CPL
https://www.dropbox.com/s/t8nizr991o956pa/wcpl.mov?dl=0
harsh79 is online now   (2) Thanks Reply With Quote
Old 4th January 2017, 10:30   #28
graaja's Avatar
Hi harsh79,
My StreetGuardian is a little lose on the base and due to this there is lot of vibration in the video when going over rough roads. Do you have this problem? If yes, how did you solve it?
I see some pieces of double coated tissue tapes in the package. Are these meant to tightly secure the camera to the base?
graaja is offline   Reply With Quote
Old 4th January 2017, 15:44   #29
harsh79's Avatar
Thanked: 610 Times
Hi harsh79,
Hey graaja,
I've never had vibration issues as I'd stuck one of the EVA foam pads supplied with the camera from the very first day to the mount.
One pad should be enough to get the snug fit back.
Old 12th March 2017, 08:26   #30
harsh79's Avatar
Thanked: 610 Times
Videos under different lighting conditions with the latest available firmware update.
There are multiple clips from some locations but the camera settings and time of recording differs.
Youtube's encoding introduces a lot of macro-blocking and degrades the video quality (especially the daytime clips). Download the linked RAW files to view the original uncompressed quality. The difference is significant!
Street Guardian SG9665GC V2 (F.W V. Update 4) - 1080p @ 30 FPS, WDR - On, Metering - Centre, Contrast - Medium, CPL - Yes.
Early evening.
1
https://drive.google.com/open?id=0B9...GVjRHJWdFprakE
2
https://drive.google.com/open?id=0B9...3d4V3gtTkR4blk
Evening.
1
https://drive.google.com/open?id=0B9...URnQ0J2am5pNDQ
2
https://drive.google.com/open?id=0B9...DhDcW1qZ255WUU
Market.
1
https://drive.google.com/open?id=0B9...UJwVTh3bE1tNkE
2
https://drive.google.com/open?id=0B9...2wyVzdKc0FFT28
Street Guardian SG9665GC (F.W V. Update 4) - 1080p @ 30 FPS, WDR - On, Metering - Centre, Contrast - Medium, CPL - No.
Early evening.
Tree lined road.
https://drive.google.com/open?id=0B9...2F2Rm9xaExVeEU
Away from the sun.
https://drive.google.com/open?id=0B9...XBsRnZGRmNpbnM
Towards the sun.
https://drive.google.com/open?id=0B9...XcyZFBibHd0Z3M
Evening.
Slow moving traffic.
https://drive.google.com/open?id=0B9...G44Nm1RTThTSlk
Headlights off.
https://drive.google.com/open?id=0B9...1pYZ29XSUtNbE0
Market.
https://drive.google.com/open?id=0B9...lNEYTg2UFVsWm8
Night.
1
https://drive.google.com/open?id=0B9...lBETkI4aV94cTA
2
https://drive.google.com/open?id=0B9...XBkZW5DeEpFNUk
3
https://drive.google.com/open?id=0B9...EVhM085NmRpYms
4
Headlights off from 0:27 to 0:50.
https://drive.google.com/open?id=0B9...UxrUk5qam1renM
5
https://drive.google.com/open?id=0B9...HdEM0dSUk9jSW8
6
https://drive.google.com/open?id=0B9...kxTaFQ5Yml6WWM
Foggy
Daytime.
Driving into a basement parking.
https://drive.google.com/open?id=0B9...npWRV9Ba3VuX3c
Driving out of a basement parking.
https://drive.google.com/open?id=0B9...Xk1cG9OSXdXQmc
Street Guardian SG9665GC (F.W V. Update 4) - 1080p @ 30 FPS, WDR - On, Metering - Centre, Contrast - Medium, CPL - Yes.
Daytime.
https://drive.google.com/open?id=0B9...3pXNjBnaWhLZkk
https://drive.google.com/open?id=0B9...FgtU0hUWEtDUjQ
Evening.
Raining
https://drive.google.com/open?id=0B9...VFxSENYNFdlUlU
Evening.
Raining
https://drive.google.com/open?id=0B9...FhuSEhzTkVleFE
Raining - market
https://drive.google.com/open?id=0B9...nZlcTd6TlNvWFk
Night.
Highway
https://drive.google.com/open?id=0B9...2RQaWFqRm9FeFk
Parked, only DRL's on.
https://drive.google.com/open?id=0B9...jQ2UkZRQlNOdUk
No streetlights.
https://drive.google.com/open?id=0B9...TNXNG1QckN6bmM
Afternoon.
https://drive.google.com/open?id=0B9...nhTZXJheXRraG8
Night.
https://drive.google.com/open?id=0B9...nprSHZicnZxQ1k
Before sunset.
Away from the sun
https://drive.google.com/open?id=0B9...UZjR0tWZEE1bHc
Towards the sun
https://drive.google.com/open?id=0B9...nlfNVllOGJmbEk
Billboards and signage
https://drive.google.com/open?id=0B9...VkxNDJCV0J0X2s
Daytime.
Gloomy morning
https://drive.google.com/open?id=0B9...01PWkVtVnNNcmc
A few seconds of Hindi audio towards the end.
Evening.
Market
https://drive.google.com/open?id=0B9...lhpUlU3QzBIeUE
Daylight.
Market
https://drive.google.com/open?id=0B9...1BWYlQ2N1dKMTA
Slow moving traffic
https://drive.google.com/open?id=0B9...jExb1hNWnhQZ0U
Dusk.
Market
https://drive.google.com/open?id=0B9...FB1bXBDRHhjTWc
Night.
1
https://drive.google.com/open?id=0B9...XUwV1pjNWNIdmc
2
https://drive.google.com/open?id=0B9...UZoXzVoN2lGWEU
3
https://drive.google.com/open?id=0B9...VNUU1lnMFliN3M
Night.
https://drive.google.com/open?id=0B9...E8yNWo3NFlCUUE
Market
https://drive.google.com/open?id=0B9...011bDFYejZJV2s
Daytime.
Sunny
https://drive.google.com/open?id=0B9...nhRWEVHYWxFUlE
Tree lined road
https://drive.google.com/open?id=0B9...V9BNzUyQ1hVdDQ
https://drive.google.com/open?id=0B9...DR4eWExV0FMV28
https://drive.google.com/open?id=0B9...jdVVjU3NnhKNmc
Market
https://drive.google.com/open?id=0B4...C1RVHpwN1I5d0E
Different market
https://drive.google.com/open?id=0B4...zhmYVVNcFFzZUk
Away from the sun and then towards the sun
https://drive.google.com/open?id=0B4...053ME5wNmtGUzA
Sun and tree cover
https://drive.google.com/open?id=0B4...XNkeHFUQjUzNHM
Street Guardian SG9665GC V2 (F.W V. Update 4) - 1080p @ 30 FPS, WDR - On, Metering - Centre, Contrast - Medium, CPL - No.
Night.
Market
https://drive.google.com/open?id=0B4...3lRWmdQTkx0cnc
Streetlights
https://drive.google.com/open?id=0B4...Eh4SEtqc1gxeXc
Market
https://drive.google.com/open?id=0B2...mFUdW5OUVBvNVU
Different market
https://drive.google.com/open?id=0B2...jBqSHp1YjZLbzA
Bajaj Avenger 150 Street / 220 Street launched at INR 75,000 / 84,000 aniketi Motorbikes 29 21st September 2017 18:39
DIY: G1WH Dashcam Installation & Review vsathyap DIY - Do it yourself 16 20th August 2016 22:06
DashCam Review : Blackvue DR500GW-HD silversteed In-Car Entertainment 17 20th September 2015 21:36
Morris Street : A Customised Street Rod, made in Delhi GTO The Indian Car Scene 26 22nd July 2012 18:46
