Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 28th September 2016, 12:12   #16
sushrutha's Avatar
Thanked: 324 Times
Default Re: DIY installation: Ritz tachometer in a Swift LDi
No confusion here.
Originally Posted by YoungSaint View Post
LXi model swift DZire petrol and have always felt the need of a tachometer
Make sure you pick the Tachometer for Ritz Petrol and not the Diesel one.
This was in reference to DZire petrol.
So petrol Tachometer is what needs to be installed
Originally Posted by sushrutha View Post
Tacho price is Rs.1037 inclusive of all taxes.
It's a diesel tacho (note - petrol tacho will not work) with readings till 6K rpm.
Part number is 34200M83K10
@ Sushrutha: It's a diesel tacho (note - petrol tacho will not work) with readings till 6K rpm.
Both of you are giving different versions to buy. Please clarify which one works actually. Petrol tacho or diesel tacho ?
I was referring to the installation done on my Diesel Swift.
Old 28th September 2016, 12:15   #17
Waspune's Avatar
Thanked: 279 Times
Originally Posted by NiInJa View Post
Excellent DIY .. will show this to one of my friends who has a Alto and wants a tacho badly. Hope it will work on that car, Or will it ?
Also, can experts tell me if the same assembly can work on other brands, say the Kwid ?
For Alto, the A-Star tachometer can work as the alto k10 and the erstwhile a-start used to share the same engine.
Waspune is offline   Reply With Quote
Old 28th September 2016, 12:55   #18
CGB
CGB's Avatar
Thanked: 166 Times
As long as it's a 4 cylinder Suzuki MPFi Engine, it is possible to fit Ritz Tachometer in Zen.
Will the Zen have the same engine speed (brown) wire as Swift? If someone can confirm, I'll take the plunge and do it this weekend!
CGB is offline   Reply With Quote
Old 28th September 2016, 14:04   #19
audioholic's Avatar
Thanked: 5,267 Times
Originally Posted by CGB View Post
Parag, is it possible to set Ritz(petrol) tacho on jellybean Zen? Mine is 2007 model that came with facelift and has a MPFI engine and EPS.
It should. But please check the PS module and check if the wiring is common, else access a service manual to verify the signal before buying. It
Yes for the Alto, but not sure about the Kwid. Signals vary from manufacturer to manufacturer and its just the uniformity within manufacturer that enables this install on multiple cars.
For a 3 cylinder engine - ALTO, one can try installing A-star tachometer.
This is not required. They are cross compatible. Number of cylinders does not matter for the digital ones. The analogue ones which take the engine timing as reference have this issue.
audioholic is offline   (2) Thanks Reply With Quote
Old 28th September 2016, 14:12   #20
sushrutha's Avatar
Thanked: 324 Times
Else, if you are planning to put an aftermarket tacho in Zen Mpfi,
You can tap the input to tachometer from ignition coil.
I had done as per below
In the below pic, marked in red.
pic courtesy - Google image
sushrutha is offline   (2) Thanks Reply With Quote
Tachometer Installation In An MPFI Gypsy King satan Technical Stuff 12 1st August 2013 17:50
jugaad di gaddi! (DIY rattle fixes on my swift LDi) rider60 DIY - Do it yourself 34 14th February 2011 18:44
Maruti Swift Vxi or Ldi? EDIT: Bought Ldi Gurudatta Nayak Hatchbacks 27 14th May 2008 20:09
Building a Tachometer for Swift LDi vishnugs Technical Stuff 9 7th May 2007 19:39
