Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 1st November 2006, 12:03   #61 (permalink)
ankur's Avatar
Originally Posted by iraghava
Ok Ankur I'm gonna disturb your thread a bit but for your benefit only. I just discovered during a friend's birthday celebration last night that speedonline is actually one of my close friends. I would seriously advise you to be wary of this character since he's a GEEK/NERD of the highest order!!! And he's gonna seriously confuse you at some point of time or the other!!!
And Pranav you ... read the damn rules first & post an introduction .....
Hi Raghava,
Thanks for the warning, though i too am a geek/nerd of what order though i dont know . I have been active on the internet long enough to know what advice to take with a pinch of salt and what as is so i am not worried.
cheers.
ankur is offline   Reply With Quote
Old 2nd November 2006, 12:01   #62 (permalink)
Team-BHP Moderator
navin's Avatar
... I would seriously advise you to be wary of this character since he's a GEEK/NERD of the highest order!!!
Ankur, if you even 50% the nerd Rags says you are you are welcome here anytime! I love your work.
__________________
Scixelsyd Etinu
Old 2nd November 2006, 12:12   #63 (permalink)
ankur's Avatar
Thanks . So the painting got delayed because of the bandh, paint shops were closed even though the painter was ready. I needed some matt black paint and clear that he didnt have in stock so i am hoping i can buy them today since the shops are open and take the dash to be painted.
In the meantime i was able to finish the USB ports and switch that will go into the dash. Now i have to figure out a way to make the airbag opening into a easy to use door of some sort. I have some magnets that i think might work in holding the door shut.
cheers.
Old 2nd November 2006, 13:39   #64 (permalink)
Team-BHP Moderator
navin's Avatar
Originally Posted by ankur
. I have some magnets that i think might work in holding the door shut..
I have seen some NdFeB magnets about 5-6mm dia that will work great for such an application. too bad I did not stock up on them. they are imported from china so shops that sell this sort of stuff in delhi might be where to look.
__________________
Scixelsyd Etinu
Old 2nd November 2006, 13:43   #65 (permalink)
ankur's Avatar
I got a couple of these :
cheers.
Old 3rd November 2006, 13:50   #66 (permalink)
Hi ankur, How is the setup comming along?
speedonline is offline   Reply With Quote
Old 3rd November 2006, 16:11   #67 (permalink)
ankur's Avatar
Setup on hold. I am in Chandigarh to watch the Pine Forest Rally. should be back tomorrow and will resume my setup .
Old 4th November 2006, 17:31   #68 (permalink)
theEnd's Avatar
Very nice work Ankur.. I cant wait to see the pics of the final setup.
Slightly off topic, but there was a version of the iMac that matched perfectly with the DIN slot in a car's dashboard. Might be something to look into for future efforts that anyone may make.
theEnd is offline   Reply With Quote
Old 4th November 2006, 20:35   #69 (permalink)
Steeroid's Avatar
I am terribly ignorant about these things, but your expenses so far seem to work out to $2,000. Would it not have cost the same to buy one of those ultra-portable notebooks that Sony and Fujitsu are famous for (1.3 kg, 1.2 ghz, 1 GB RAM, 10.6 in screen, 12 hours battery life, etc) and had a retractible sort of mounting made for one of those in the car? I think Acer has a Tablet PC of the same sort in the same range, if a touch-screen was a must. WiFi, Bluetooth, et al are all built in, too.
Of course that would NEVER give you the kick of building something on your own and customizing it. But am I missing something here?
__________________
Steer
Happiness is nothing more than good health and a bad memory.
- Albert Schweitzer
Steeroid is offline   Reply With Quote
Old 4th November 2006, 23:31   #70 (permalink)
hydrashok's Avatar
This is something I wondered about too. A Mac Mini would have done the job at less than half what you've just spent. If you're not ok with OS X, Win XP on Bootcamp would have done the trick. But then, like Steeroid said, nothing gives you the kick of DIY huh? Hats off to you, man. You're doing great work.
__________________
Αυτο ειναι ολα τα ελληνικα μου
hydrashok is online now   Reply With Quote
Old 5th November 2006, 02:28   #71 (permalink)
khanak's Avatar
yupp. maybe as an alternative but i was thinking of the same thing.
get a laptop nd stick it on a cooling mat in the boot. run a power adaptor into your boot and have the laptop running on power all the time. run the video through the svideo out and connect it to your HU which is connected to a screen or connect it directly to the screen if possible. run the audio through either an external soundcard (for better sound) or through an SPDIF connector to your HU. Use a bluetooth mouse and keyboard which can be stored under your seat or in the glove compartment.or use touchscreen any get rid of the mouse nd keyboard though using the virtual keyboard will be a pain
this way you can just unplug the laptop and use it elsewhere as well.
__________________
Adhish आधीश् ஆதிஷ் ادهش
__________________
khanak is offline   Reply With Quote
Old 5th November 2006, 12:41   #72 (permalink)
ankur's Avatar
Hi guys,
I will try and summarize my thoughts on most of your points raised. Using a laptop ofcourse takes away the fun of building something but it has its issues. Firstly the laptop power system obviously runs on different voltage so an invertor would be needed to connect its power adapter to it. The power consumption is higher on a laptop/macmini as compared to the low voltage motherboard i am using, this would impact the drain on the battery when you are switched off. Ideally you want to leave your car system in a standby mode so it can be in a usable mode quickly as you start driving, not wait for the system to boot up everytime.The laptop has its limits on upgradability and installation of a laptop in an automotive environment is not that easy. However some people have cannibalised their existing older laptops for such a system. The input methods are most key, the keyboard and mouse is really not practical for a car computer in its primary function. For instance if i need to change a song or start navigating to a point of interest or something like that. I would need to park on the side of the road in the interst of safety if i intend to do it through a keyboard/mouse. I am using a touch screen as my main input device and also a software front end specific for car use. If it was just for the sake of putting a computer in the car certainly a mac or a latop would have made a substitute but my intention was to make a car pc that feels like is a car pc and not a pc put in a car (if you know what i mean). The car functions like the ECU and reverse camera/sensors etc are all going to be integrated into this and i would strive to make it seem like a factory option.
If you are just looking at the cost of the whole system against the cost of the laptop or mac mini then its really not a fair comparison. I would need to buy most of the addons for the other as well and you need to add those to the cost of the laptop too, like the OBD scanner, the touch screen, the gps receiver, the FM radio, the reverse camera etc.
About putting a tablet PC or laptop on a mount near your dash, come one guys would anyone want to leave it visible like that ? If not would you keep removing it and putting it back everytime you want it ?
cheers.
Old 5th November 2006, 12:50   #73 (permalink)
ankur's Avatar
Majorly off topic, since i mentioned i was away to watch the Pine Forest rally, if anyone is interested i am posting some pictures (phone camera) :
Here is Gaurav Gill on the Super Special stage in Chandigarh
Here again is Gaurav in the hills taking a bend with a sideways slide, amazing driving
cheers.
Old 5th November 2006, 20:46   #74 (permalink)
Team-BHP Moderator
navin's Avatar
ankur we have a forum for these pics and travelougue.
__________________
Scixelsyd Etinu
Old 6th November 2006, 12:10   #75 (permalink)
ankur's Avatar
Sorry about posting them here, i did see the other thread and put one pic up there. Didnt really have much to write or show and since i had mentioned i was there, thought i would just stick those pics up here.
cheers.
Thread Tools
My First Car PC Install - Research and Planning Stage sys_whiz DIY - Do it yourself 219 3rd May 2008 17:52
Install Ipod Dock Connector with AMP in Car ? Lovelydude77 Ask the Gurus 2 2nd October 2007 19:41
Does a 3rd party install void the original Car Manufacturer's Warranty? vebmetal Ask the Gurus 8 24th August 2007 13:50
Indigo Center Console Touchscreen LCD Fabrication shldn DIY - Do it yourself 93 22nd August 2007 11:33
Car audio setup for zen sharu Ask the Gurus 19 25th May 2006 09:09
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
