Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 15th January 2007, 21:01   #121 (permalink)
Autophile's Avatar
Car PC has came out nice with amazing integration of stuff, whatever you can think of is there already. During install so many times I have lost the count of features and peripherals added .
Kudos to Ankur who has worked very hard on his project and the final outcome is superb.
Though there is one thing which was left out in install and soon will be added, a Stylus (for finer tabs on touch screen) till then he is using a cable tie as a stylus .
Autophile is offline   Reply With Quote
Old 16th January 2007, 10:41   #122 (permalink)
angelfire's Avatar
One word for the install....AWESOME...The integration of the different equipments is simply amazing...
__________________
HELL UnLEAShED@4000rpm...
angelfire is online now   Reply With Quote
Old 16th January 2007, 11:18   #123 (permalink)
ankur's Avatar
Thank you all.
I want to point out one more fact about the install, something that was important to both me and the other guys involved. There is no wire splicing/joints in the car.
We tapped the main wire harness using a Metra reverse harness connector, we used a distribution block for the main power and for the various smaller power connections we used insulated spade connectors further insulated with heat shrink tubing.
cheers.
ankur is online now   Reply With Quote
Old 16th January 2007, 11:26   #124 (permalink)
khanak's Avatar
Awesome stuff Ankur. Congrats on a great setup. This ones a real treat for all us geeks out there
How about listing the hardware nd software used.
Is it running windows?
__________________
Adhish आधीश् ஆதிஷ் ادهش
adhish.wordpress.com
__________________
khanak is offline   Reply With Quote
Old 16th January 2007, 11:36   #125 (permalink)
ankur's Avatar
Sadly yes its running windows and there have already been crashes but i have no choice over the operating system. The device support that in windows is just not there in other operating systems.
Here is what went into it :
VIA EN15000 motherboard with a C7 processor
1 GB DDR RAM
40GB Seagate notebook HDD
Opus 120W car power supply for the main system
Opus 80W car power supply for the peripherals
Xenarc 700TSV 7" VGA touchscreen
SB Audigy 2 NX USB sound card
Pioneer slot loading USB DVDR
Belkin 7 port USB hub
HQCT FM tuner
Linksys USB WiFi adapter
Belkin USB Bluetooth adapter
Audi MMI controller modified to work as a USB device
USB GPS receiver
Elmscan 5 OBD II scanner
Wireless keyboard with built in tracking stick
Software is essentially Windows XP SP2 nlited and tweaked. Other than software for the items listed above i am using Centrafuse as the front end. Mapking for the GPS.
If i remember something else i will stick it in the list.
cheers.
Old 16th January 2007, 12:24   #126 (permalink)
netarchie's Avatar
Does it have a PCMCIA slot? if yes you can stick a reliance or a tata data card into it for Internet access.
__________________
netarchie
netarchie is offline   Reply With Quote
Old 16th January 2007, 12:26   #127 (permalink)
khanak's Avatar
1 GB DDR RAM
HQCT FM tuner
USB GPS receiver
cheers.
Thanks a lot!!
I think I finally understood the installation. Like I said before awesome stuff!!
EDIT - How are the speakers connected to the PC. Do you also have a HU?
btw for those who want to install this but dont want to fiddle with the dashboard heres a product from Xenarc that should solve your problems
its for $500
__________________
__________________
Old 16th January 2007, 13:39   #128 (permalink)
ankur's Avatar
It doesnt, i am trying to find a USB solution for it.
Old 16th January 2007, 13:48   #129 (permalink)
Team-BHP Moderator
tsk1979's Avatar
buy the Reliance base plan nokia phone for around 1100or so. connect a USB data cable(DKU2 or DKU5) and you can do a dialup connection giving around 80-90Kbps.
Reliance also gives you a CDMA USB modem but the cost is close to around 5000rs,
Your monthly rent will depend on the data plan you take.
Other option is to get a slightly more expensive mobile phone (6-8K) which has bluetooth and you can connect via a bluetooth dongle on your car PC USB port. Same 80-90K speed.
__________________
Old 16th January 2007, 14:07   #130 (permalink)
ankur's Avatar
Originally Posted by khanak View Post
Thanks a lot!!
its for $500
The screen is good, i saw it in operation but too many moving parts scare me in the indian environment. See the inside of it, its very precise, like a retractable roof.
I am using a USB soundcard thats connected to the Audison amp and thats driving the speakers.
cheers.
Old 16th January 2007, 14:13   #131 (permalink)
ankur's Avatar
I am not a big fan of Reliance, how is the actual connectivity ? I found out from Tata Indicom but the lowest end phone that supports data was for 5k, that didnt make sense. Maybe i will check out the reliance webworld (ugh!).
Right now i am cobbling together a phone from various Motorola Razor parts i had lying around, and last night i finally got it to work . Its screen is not operational so it will be tricky to get the bluetooth operational. I have a working razor and will follow the key presses based on what appears on the screen on the working phone. Will reports back.
cheers.
Old 16th January 2007, 14:13   #132 (permalink)
Hey Ankur, Do you already have the data card, because I believe that reliance has launched a new USB data modem. In any case have a look at this U132 USB to PCMCIA Adapter. It possiable that you might find it Nehru Place as well.
speedonline is offline   Reply With Quote
Old 16th January 2007, 14:26   #133 (permalink)
ankur's Avatar
I wanted to avoid purchasing the PCMCIA card and adapter, its not worth it. I would rather purchase a phone so i can use it when i disconnect it.
Old 16th January 2007, 14:27   #134 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Reliance has great connectivity in Bangalore and rural karnataka. It works all the way from Delhi to Amritsar and from chd to Narkanda, to Jaipur.
Data connection speed has been tested in cities only(NCR and Ludhiana) and I found it between 70-90kbps always.
Don't know about any other places, when I go there will let you know
If you want a phone which supports data you can have mine. Its a LG handset with color capability. contact me.
__________________
Old 17th January 2007, 18:01   #135 (permalink)
speedzak's Avatar
For internet connectivity on the move, The best option now is to go for the Indicom USB modem kit. Just plug in to a USB port and You're connected. And it's quiet small in size too.
I dunno about the indicom's performance there. Here, it's not that great when it comes to customer service. Network reachability is not bad though.
Ankur! Once again, YOUR SETUP IS AWESOME!! Congrats on finishing it with perfection.
__________________
I have often regretted my speech, never my silence.
speedzak is online now   Reply With Quote
Thread Tools
My First Car PC Install - Research and Planning Stage sys_whiz DIY - Do it yourself 237 30th June 2008 14:44
Install Ipod Dock Connector with AMP in Car ? Lovelydude77 Ask the Gurus 2 2nd October 2007 19:41
Does a 3rd party install void the original Car Manufacturer's Warranty? vebmetal Ask the Gurus 8 24th August 2007 13:50
Indigo Center Console Touchscreen LCD Fabrication shldn DIY - Do it yourself 93 22nd August 2007 11:33
Car audio setup for zen sharu Ask the Gurus 19 25th May 2006 09:09
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
