Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 22nd February 2017, 08:46   #1
samaspire's Avatar
Thanked: 2,321 Times
Default DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories
Fuse tapping is a clean and harmless way (as in, no OEM wires need to be cut) to power your electrical accessories. I first chanced upon it in this thread by bhpian paragsinchania. This led me to this fuse tapping bible by bhpian arunphilip. These 2 threads have all the technical information and instructions needed to tap any car.
My thread is specific to the 2015 Ford Figo/Aspire as there some things that are different here. For starters, the fuses used are Micro2 and Micro3 (something that even the service centre guys didn't know when I asked them for spare fuses). Micro2 is 2 pronged and Micro3 is 3 pronged; I could only find fuse taps for the Micro2 type.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170103_230804.jpg
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170105_002123.jpg
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170105_002104.jpg
The different types of fuses
Wikipedia link to Fuses
Micro2 and Micro3 are apparently rarely used, and these in particular are probably non-standard. I say non-standard because the fuses and the taps refused to slot into the fuse box. This could also be an issue with the taps that I bought, but that's unlikely.
INGREDIENTS
  • 1 Ford Figo or Ford Figo Aspire 2015
  • Accessory/accessories that need to be powered
  • OCD for clean, clutter free interiors
  • Owner's Manual
  • Fuse Tap/s
  • Extra Fuses
  • Fuse Puller / Cutting Plier
  • Metal Knife
  • Gas Stove (or any heat source to heat the metal knife)
  • Gold File / Goldsmith
  • Waste Newspapers
  • Gardening Gloves (non-rubber)
Ordering Information
Fuse Taps + Fuses
3pcs MICRO2 BLADE FUSE ADAPTER
http://s.aliexpress.com/EvmIziAb
Price: $4.10 (Rs.285.00)
The fuses that came in the set are all 15A and of cheap quality, but the fuse taps feel really well made. I feel it's better to order extra fuses of the correct amperage from Ford.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170127_151529.jpg
This is what I got from AliExpress
Fuse Puller
To pull the fuses out of the fuse box
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-125258557989752792.jpg
2pcs Hot sale Universal Blade Fuse Puller
http://s.aliexpress.com/maMF32Un
Price: $0.46 (Rs.32.00)
You can also use a cutting plier, but be gentle with it.
Accessing the FUSE BOX
The Aspire had 3 fuse boxes - two in the engine bay and one in the passenger compartment.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170103_091648.jpg
In the engine bay
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170103_090812.jpg
In the passenger compartment
The one that we need to access, the one in the passenger compartment, is located behind the glove box.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170225_092719.jpg
Press these clips present on both sides towards the inside to bring the knobs outside the grooves. (be careful not to push them inside too much; one of mine is already half broken)
Name:  20170226 09.28.51.jpg
This unlocks the glove box, so that it can drop down completely to show the fuse box.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170225_092807.jpg
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170225_092848.jpg
This picture shows the fuse taps already in place. Also note the orientation of the fusetap
As soon as taps arrived from China by India Post, I tried inserting one into the empty slot, but it would not go in. I tried the same with the other 2 taps; none of them would slot in. I realised that the grooves on the fuse tap do not match the grooves on the fuse box.
I went to arunphilip's thread for advice.
Here both arunphilip and audioholic suggested that the issue might be with the 2 metal prongs - I had to file them to match the Ford fuses. I checked by inserting the fuses that came in the set and they were right - they wouldn't go in.
This took me on a hunt to all the hardware stores in town. With no luck. Then somebody suggested to try a goldsmith supply store. And he was right - they had a thin file that would work on the prongs.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170221_103905.jpg
It was 40 rupees.
I started to file them but it was taking too much time and effort. So I decided to take professional help and went to an FNG (Friendly Neighbourhood Goldsmith). He did it in 2 days and charged me 100 bucks for it - worth it.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170212_204041.jpg
The filed fusetap
With high hopes I went back to the car and...
...the fuse taps still wouldn't fit in.
Next I tried the fuses, and they slotted in perfectly. So what I had thought of initially was also true - the grooves didn't match. I now had to change the grooves on my fusetap. Idea was to melt the grooves with heat. The stage was the kitchen - after midnight.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170212_233912.jpg
Knife being heated over flame
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170212_234000.jpg
Carefully flattening the raised portions
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170212_234021.jpg
Done
Note: Using gardening gloves would be safer for the fingers. Also keep waste paper nearby - you will need to wipe off the melted plastic off the knife occasionally.
The tap and the fuses now cleanly slot into the fuse box. You can now follow the other two threads for instructions on how to do the wiring for drawing power from your car.
Here are the fuse charts from the Owner's Manual
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170103_235533.jpg
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-20170103_235556.jpg
Note that all the "unused" slots act in the same way as the accessory socket - always on. Take that into consideration while deciding on which fuse slot to use. I have used the audio system fuse (1) for the Dashcam and an empty slot (20) for the additional accessory sockets.
Last edited by Aditya : 6th March 2017 at 07:30. Reason: Correcting image orientation
samaspire is offline   (17) Thanks Reply With Quote
Old 6th March 2017, 07:32   #2
Thanked: 24,545 Times
Default re: DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories
Thread moved from the Assembly Line (The "Assembly Line" Forum section) to the DIY Section. Thanks for sharing!
Aditya is offline   (2) Thanks Reply With Quote
Old 6th March 2017, 10:54   #3
Thanked: 211 Times
I appreciate your interest, hard-work and persistence in getting these fuses work/re-configured. But I did not understand why this should be done. What is the end game here? Seems like a lot hard work.
bsdbsd is offline   (1) Thanks Reply With Quote
Old 6th March 2017, 11:24   #4
samaspire's Avatar
To power accessories like Dashcam, Bluetooth headsets, etc. without wires dangling in plain view, and to ensure that they switch on/off automatically without direct intervention. Fuse tapping is the 1st step in hardwiring these accessories. The actual process of fuse tapping and hardwiring is detailed in the other two threads linked in the beginning of my post.
samaspire is offline   (5) Thanks Reply With Quote
Old 8th March 2017, 10:23   #5
Thanked: 211 Times
Default Re: DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories
Makes perfect sense now! It all falls into place given the context. I wish car companies make these tasks simple by providing us with some plug-points (like how we have in homes). Having this kind of knowledge during the early days of ownership of a car (read when-you-were-young!) is invaluable. Thanks for such a useful thread.
Old 8th March 2017, 14:00   #6
Mr.Boss's Avatar
Thanked: 2,413 Times
Thanks for putting your effort in detailing the steps.
Sorry for hijacking your thread, I'm adding a bit of salt to enrich the flavor (hope you don't mind)
Please take care in finding the Input & Output terminals of slots in fuse box (either with a fuse tester or multi-meter or by other means) Wrong orientation of fuse tap will add adverse effects.
I'm no good at electrical circuits, pardon for the crappy explanation.
DIY Fuse Tapping the Figo/Aspire: A clean way to power accessories-fuse-tap.jpg
In a fuse tap, Input ends were inter-connected and individual outputs (one to the regular fuse slot and other external output) were controlled by the Fuse. Failure of 1 fuse will not affect the functioning of other.
If the fuse tap direction is reversed, Input for the intended 2nd source will be taken from the output of the original / stock fuse. In other words, the regular fuse will take both the loads. And failure of fuse 1 will affect both the outputs.
Mr.Boss is offline   (3) Thanks Reply With Quote
Car makers tapping fleet taxi space to push sales aniketi The Indian Car Scene 22 25th April 2017 10:52
Tata Indica ICE: 2-way to 4-way DIY gkannan In-Car Entertainment 12 28th October 2015 02:38
Tapping Sound shazikon Technical Stuff 15 30th August 2013 12:34
Rusting of Discs on 2 month Car - is this correct way to clean tyre-area and wipers cool.aquarian Technical Stuff 9 28th February 2010 21:35
Which Is The Best Way To Clean Alloy Wheels? Epic Tyre & Alloy wheel Section 2 15th March 2007 09:59
