Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 15th April 2017, 14:45   #1
sudeepg's Avatar
Thanked: 1,263 Times
Default S-Cross DIY: LED footwell lamps for the rear floor area
S-CROSS DIY - Foot Well Lights
The top end alpha version of S-Cross is mostly feature loaded, but yet there are a few simple nicecities that are easily doable. The interior cabin light is poor and an upgrade to LEDs is recommended since they are a straight fit. This can improve the overall lighting inside the car. One of the areas that is not well lit is the back side foot wells. The ones in the front use a single LED and not powerful enough, especially if you have a poor eyesight.
I had got LED scuff plates as part of accessories from Nexa at the time of delivery of my S-Cross, but as many know, they are purely cosmetic.
My son does drop things occasionally during trips and it is sometimes tricky to find something in the rear floor area at nights. Given that there was a power source close by, I decided to complete a DIY to install LED foot well lamps at the rear. There are many other threads on how to install LED foot well lights. Well known are Gannu_1 and a4anurag's threads. This is well, yet another foot well lighting thread but what is different in this case is the approach I used to tap power from the scuff plate lights.
The scuff plates connections use simple molex connectors and therefore the easiest way to tap power was, to create a power splitter by using equivalent molex connectors. Further, they also follow the theatre dimming effect when turning off or on as followed by the scuff plate lights. The line is also secured with a 3 Amp fuse and therefore there is no need for an additional fuse as long as you are not overloading the line by adding too many LEDs
Ingredients
  • Male/Female molex connectors and terminals (Source S. P. Road, Bangalore. Cost INR 10 per piece)
  • Wires 24-26 AWG will do. (Source S. P. Road, Bangalore. Cost INR 6 per meter)
  • LED lights - (Source eBay. Cost 200 per lot of 10)
  • Zip Ties (Source S. P. Road, Bangalore. Cost INR 30 per packet)
  • Insulation Tapes (Source S. P. Road, Bangalore. Cost INR 10 per roll)
  • Crimping Tool (Source S. P. Road, Bangalore. Cost INR 800 per piece)
Procedure
  • Create two splitter connections using molex connectors and terminals.
  • Connect the LED's to the male connectors.
  • Remove the Scuff plates
  • Plug and Test
  • Replace the Scuff plates and attach LED lights into the foot well using double sided tapes or Zip ties.
Time Required to Complete this install: 1 hour or less with all equipments ready to go.
Crimping
It's extremely easy to use crimping tools to crimp terminals to the wires over soldering. The connections are flexible and they are pretty robust. Investing in a crimping tool is highly recommended. The brands available in India are alright but not great in quality. There are very cheap and better options available from AliExpress though, some even come with detachable dies so that it becomes multi purpose.
Let the pictures do the talking now.
Required Materials
S-Cross DIY: LED footwell lamps for the rear floor area-1.jpg
Terminals. These will lock themselves into place once you insert them into the molex connector
S-Cross DIY: LED footwell lamps for the rear floor area-2.jpg
Terminals - Crimped (The insulation crimping was not good enough due to quality of the crimping tool). Also, post crimping, the terminals could bend a bit due to the stress applied, in which case you will have to straighten out the terminal to ensure a smooth connection. Ensure you hold the center part of the terminal when straightening it out since they are not very strong
S-Cross DIY: LED footwell lamps for the rear floor area-3.jpg
Splitter Created using terminals and molex connectors. The top two host the male connectors and the bottom hosts the female connector that plugs into the male connector for the scuff plates power source.
S-Cross DIY: LED footwell lamps for the rear floor area-4.jpg
Using the crimping tool. It has a holder so that you can hold the terminal,push in the wire and then push crimp in one shot
S-Cross DIY: LED footwell lamps for the rear floor area-42.jpg
See the small level near the handle? That is used to release the hold lock
S-Cross DIY: LED footwell lamps for the rear floor area-43.jpg
Two - One for each side
NOTE: LEDs are polarity sensitive and therefore when inserting the terminal into connectors, ensure the polarity will be correct when connected.
S-Cross DIY: LED footwell lamps for the rear floor area-5.jpg
Splitter connected to the front side scuff plate connectors
S-Cross DIY: LED footwell lamps for the rear floor area-6.jpg
Testing
S-Cross DIY: LED footwell lamps for the rear floor area-7.jpg
LED foot lights attached using double sided tape under front seats. You can attach it anywhere you like
S-Cross DIY: LED footwell lamps for the rear floor area-8.jpg
Wire exiting from the scuff plates connection, hardly noticeable
S-Cross DIY: LED footwell lamps for the rear floor area-9.jpg
Wire routing - Ensure sufficient flexibility so that when seats are moved all the way front or back, the wires don't strain
S-Cross DIY: LED footwell lamps for the rear floor area-10.jpg
Installed and in action
S-Cross DIY: LED footwell lamps for the rear floor area-11.jpg
sudeepg is offline   (26) Thanks Reply With Quote
Old 17th April 2017, 07:52   #2
Thanked: 24,250 Times
Default re: S-Cross DIY: LED footwell lamps for the rear floor area
Thread moved from the Assembly Line (The "Assembly Line" Forum section) to the DIY section. Thanks for sharing!
Aditya is online now   (4) Thanks Reply With Quote
Old 17th April 2017, 13:31   #3
Dr.Naren's Avatar
Thanked: 6,290 Times
Default Re: S-Cross DIY: LED footwell lamps for the rear floor area
Thanks for the detailed thread buddy. You are the DIY guru for S-Cross now . Much appreciated and very helpful to fellow owners. I am very bad with DIY stuff, will take your help if I need
Dr.Naren is online now   (2) Thanks Reply With Quote
Old 17th April 2017, 22:09   #4
thatfastdude19's Avatar
Thanked: 71 Times
Very nicely done sudeepg. I also recently installed lighting in the front footwells of my Indica. Absolutely chuffed by the result and the best part about DIY jobs like these is the satisfaction you get after seeing the result . Here is a pic of my one.
S-Cross DIY: LED footwell lamps for the rear floor area-img_20170301_183406686.jpg
thatfastdude19 is offline   (4) Thanks Reply With Quote
Old 17th April 2017, 22:57   #5
sudeepg's Avatar
Originally Posted by Dr.Naren View Post
...will take your help if I need
Thank you. Glad to help sir! I look forward to doing more on my S-Cross and post it on Team-BHP
Originally Posted by thatfastdude19 View Post
... the best part about DIY jobs like these is the satisfaction you get after seeing the result . Here is a pic of my one.
Thank you sir. Those lights are really bright and look cool! What you said about DIYs is absolutely true. The best part of DIYs is that care has been taken to do the best possible job. The learnings are just immense and absolutely love it.
sudeepg is offline   (1) Thanks Reply With Quote
Old 18th April 2017, 17:00   #6
Nitish.arnold's Avatar
Thanked: 20 Times
Wow, I liked how bright these are. Can you please share where you got them?
Nitish.arnold is offline   (1) Thanks Reply With Quote
Old 18th April 2017, 17:46   #7
Thanked: 71 Times
These were simple 24 SMD Led (I think that's what they are called) from a local accesories store for ₹60 per piece. These were made for the cabin roof light but I "hacked" into their wiring and used them for the following purpose.
Here are a few suggestions.
S-Cross DIY: LED footwell lamps for the rear floor area-screenshot_20170418174302.png
thatfastdude19 is offline   Reply With Quote
Old 18th April 2017, 23:02   #8
sushil_n79's Avatar
Thanked: 82 Times
Infractions: 0/2 (8)
Hi
Thanks for sharing the same. This is a brilliantly executed work and the steps speaks volumes about the amount of time and effort which has been invested in the same. Just wanted to reconfirm if a similar setup can be done for a maruti alto lxi 2012 version?
Sushil Narayanan
sushil_n79 is offline   (1) Thanks Reply With Quote
Old 19th April 2017, 20:51   #9
sudeepg's Avatar
Originally Posted by sushil_n79 View Post
Hi
Sushil Narayanan
Hello Sushil,
This is an easy DIY (in my case it was even more easier due to the door scuff plates wiring), but I am pretty sure that LED foot well lamps can be installed in your Alto. All you need to do is either tap the power from the front dome lights or via an independent connection using a tap from the fuse box. We have a few interesting threads on this already on T-BHP.
Take a look at the below posts
Installing FootWell lights in Polo by Gannu_1 (VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights)
From Anurag
FootWell lights installation in Swift (D.I.Y. Install: LED Footwell Lighting)
From Mr. Boss
Footwell lights in Nissan Sunny (DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny)
Anytime you have questions, feel free to ask the community and we will be glad to help
Last edited by sudeepg : 19th April 2017 at 20:52. Reason: Correcting a minor error in referencing content
sudeepg is offline   Reply With Quote
D.I.Y. Install: LED Footwell Lighting a4anurag DIY - Do it yourself 44 15th January 2018 00:04
VW Polo DIY: Upgrading cabin light, headlight switch & installing footwell lights Gannu_1 DIY - Do it yourself 79 31st October 2017 09:18
How do you dispose of CFL lamps & Fluorescent lamps? Klub Class Shifting gears 13 19th April 2017 16:57
DIY: LED Footwell Lights & Cabin Lamp for the Nissan Sunny Mr.Boss DIY - Do it yourself 26 22nd February 2017 20:06
Projector Lamps(Low Beam) as Fog Lamps for Ritz LDI alexpaul Modifications & Accessories 17 13th September 2012 20:23
