Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 11th June 2017, 22:04   #46
sudeepg's Avatar
Thanked: 1,219 Times
Default Re: DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift
Quick Update on installation of Fog Lamps
We had a few issues with the CN bulbs which were initially installed in our Micros, and we had reached out to XenonPlanet for help. XenonPlanet acknowledged the issue and shipped the new bulbs and we (lovetorque & me) installed them yesterday. The difference was very obvious! Not only did we get the exact same output, the light was much better. I'll do the pictures take it forward from here on.
The full details of it are available in my ownership report here
Details: (Journey from a Honda City to the Maruti S-Cross 1.3L)
Some pictures From Changing Bulbs
Old Bulb to the left, New to the right. Note the base of the bulbs
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-00bulbs.jpeg
New bulbs ignited for first time
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-011justinstalled.jpeg
Compare - New bulb to the left of the car, old bulb on the right fog of the car
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-01comparo.jpg
Bulbs settling in
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-07bulbsettle3.jpg
Bulbs settling in
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-08bulbsettle4.jpg
Old bulbs - These had some yellow spots and the beam was not proper.
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-12old4.jpg
sudeepg is offline   (4) Thanks Reply With Quote
Old 18th June 2017, 13:47   #47
sudeepg's Avatar
DIY - Fixing a Messy Wiring For XenonPlanet Micros
XenonPlanet has an authorized installer in Bangalore at Evo, from whom a few of us have installed their Micro Bi-Xenon fog lamps. We have had a few issues such as bad bulbs and poor bulb seating leading to streaks and incorrect output. To see more of this, please see Dr. Naren's ownership thread and how we subsequently fixed them.
Link
One issue that has always remained worry some for us and more importantly, dangerous, is how the wiring was done by Evo. Not only is it below safe wiring standards, it's also dangerous in some cases. The worst hit being in Dr. Naren's car. As of this writing, we are trying to rectify it.
My case wasn't great either. For the location where the fog lamps are placed, it is essential and extremely important to ensure a water tight connection because that area receives the heaviest and strongest water splashes. Evo did a poor job (in our opinion) here because they did a strip and join wire connection secured with electrical tapes. We believe, these have the following issues.
  • High possibility of corrosion in the long run due to electrical tapes being used to seal the joint. The connection is as good as how long the tapes last. In Dr. Naren's case, they have already come off.
  • Not an industry standard way of creating reliable, good wire connections.
  • Tall claims of high quality install is far from true with such an approach.
  • Wipes out electrical warranty completely. Maruti does mark after market additions in their services, but poor wiring is something that they clearly call out and make note of in their database.
  • Wires were let as it is in the base of the bumper and not secured properly. Given that this area gets water splashes and lot of vibrations, securing the wires is important.
  • The solenoid wires are thin and it is recommended to have additional protection for long life. XP gives two year warranty on Micros
After making multiple visits to Evo by BHP-ians Dr. Naren, myself and lovetorque and not satisfied with the overall quality of install, we decided to take up the matter with XP and also try and fix the issues by ourselves where possible. I decided to improve the wiring myself yesterday and this DIY post is a documentation of my efforts.
IMPORTANT NOTE: I have very little experience in car electrical wiring. With help from many BHPians I attempted to improve this wiring. I, in no way, claim to have done a perfect job, but we do know from our discussions that this effort is far better than what experienced installers do and call as a high quality install. If anyone notices issues with this install, feel free to post it up so that we can improve it further
The changes done are simple. Use proper water proof connectors to secure the wiring joint. Secure the fragile wires using tubes and secure the wiring harness as appropriate.
Connectors used - Thanks to BHPian audioholic for giving it for free. Thanks audioholic! - It was great meeting you and discussing lighting. Your knowledge just blew me away. I wish we had more time to talk, but there's always a next time, isn't it?
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-allconnectors.jpg
Now, for the dirty laundry
In the next picture notice the wiring harness used to tap power from the stock fog lamp connector. It's the worst I have seen! The reason for this approach from Evo was because the bulbs that came with the projectors were older bulbs (with a plastic base and open pins for connection to stock as opposed to a proper male connector; see previous update post on this, left most bulb). The newer ones have this corrected and it's plug and play. During the install, the additional harness used also had two separate pins but had better connection. Those pins were pushed into the stock connector. It was pushed So tight that it had almost broken the connector inside (although very tight connection). It took me a full five minutes to pull them out during this DIY, not to mention all the glue that had stuck to the wiring.
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-shabbytap.jpg
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-dirtytapstock.jpg
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-existingconnection.jpg
Additional wiring used - You can see the gauge of wires used. In my case, this is good, but in Dr. Naren and BHPIan lovetorque's case, they used speaker wires!!
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-wireused.jpg
I wanted to call out Distinguished BHPian a4anurag's words here during a discussion on these issues - Do it right, the right way, else don't do it. Don't think that needs any explanation.
Preparing the connectors and adding the new wiring
Tools
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-toolbox.jpg
Slide the water proof seal and, if required, a heat shrink tube into the wire
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-crimpingprogress.jpg
Crimp the wires using a good wire crimper.
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-crimper1.jpg
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-crimper2.jpg
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-crimper3.jpg
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-crimpfinalresult.jpg
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-crimped.jpg
Insert the pins into the female connector with the locking pins facing down. Also to note that the connector has a number marking for wire pairing. In my case 1 is for ground and 2 is for positive. Ensure they match on both male and female connectors, or else you will short circuit the line
Trivia: After I finished this project, I found out that the connectors should have been interchanged, i.e the male connector should be attached to the projector wires and female connector to the wire for the high beam signal. That seems to be the norm, but it doesn't matter in this case.
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-readyconnector.jpg
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-femaleconnector.jpg
Repeat the process with the male connector
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-maleconnector.jpgH]
Connect it up
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-connected.jpg
Complete connection - In this picture, to the left and middle, you can see the connections made using the supplied wiring harness by XenonPlanet. It's literally plug and play. To the extreme right is the new connector we applied.
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-fullyconnected.jpg
The blue connectors are the output from ballasts to the bulb and to the left is the connection I created for the high beam's solenoid operation.
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-connectorset.jpg
All connections complete.
  1. Extreme left - Power from stock connector using supplied wiring harness going into middle connector which is to ballast
  2. To the extreme right is the connection from this DIY
  3. To the bottom is are the blue connectors which is output from ballast to the bulb. Notice the black box in the middle, which is the igniter, I believe
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-endresult.jpg
Fired Up - Let there be better light!
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-lettherebelight.jpg
As an additional precaution for the wiring, I applied water proof tubing over the solenoid wiring to make it more secure. Comments, anyone?
DIY Install: 3" XP Micro Bi-Xenon Foglight Projectors on my Swift-tubing.jpg
Next DIY: Fixing the high beam tap
The high beam signal has been tapped using a splice connector, which we all know are not water proof or even recommended. Considering the engine bay gets washed, it is important to secure this tap. Possible solutions include using a heat shrink tubing or using a silicone sealant such as AnaBond 666 to secure the sides of the splice connector (Don't push the sealant in where the contact points are, just where the wires enter the connector). XenonPlanet is working to get heat shrink tubing over the connector, but I have no idea how they can do it without removing the wiring first. Removing it will be a very bad idea. On the other hand, Anabond is an industrial sealant that can work in high temperature conditions, resists moisture and also used in electrical wiring. I am going to wait and watch how XP goes about this.
Another S-Cross owner Rakesh's (From Pune) case is the worst where the high beam signal has been tapped from the fuse box in engine compartment. It's a fragile connection. The S-Cross has a separate fuse for low and high beam. The installer removed the high beam fuse, plugged in the wire and inserted the fuse back in. Anyone with common sense will know how long this connection may last and it will NEVER make the fuse box water tight with the wire coming out. Really bad!
S-Cross head lamp fuses in engine compartment
Setbacks faced during the install
  1. After wiring up the complete setup, the left fog lamp failed to power on. A little bit of troubleshooting proved that the wiring harness supplied by XenonPlanet to connect the stock fog lamp connector to the ballast was not functioning. Changing it resolved the problem.
  2. Frequent removal and fixing the fog lamps have caused them to have vibrations when going over potholes or mild patches that span across the road, much like the stock headlamp complaint that many have raised. It's due to a couple of screws not sitting tight. This still needs some solution
  3. When inserting the wire into male connector, I over pushed it which caused it to pop put over the connection side and wouldn't lock. A quick google search provided the solution on how to remove the wires from the connector. Essentially, there is a pin on the top that secures it. Using a small flat blade screw driver, lift it up and the wire comes out easily!
Credits
  • Dr. Naren - For continuous, unbiased feedback (good & bad). It helps improve a lot of things in our car
  • Distinguished BHPIan: a4anurag - for all the helpful advice and smart solutions
  • audioholic - For providing me with free connectors and free advice during the DIY.
  • Rajat from XenonPlanet - For being a listening post to our issues, acknowledging problems, help trying to sort out issues and being active with communications
IMPORTANT NOTE & DISCLAIMER
I, in no way, in this post intend to disgrace or defame any institution or individuals. I am merely sharing my observations based on my understanding in how secure wiring should be applied to ensure continued electrical safety and warranty in the best possible manner. This DIY is a direct result of concerns & problems some of us have faced, in talking to subject matter experts on wiring car electricals. It is my need to ensure safety and trouble free ownership of my beautiful S-Cross. I like to keep my cars as perfect as possible - I should be able to drive it at any given point in time without having fear or have reliability concerns due to these aftermarket solutions on a journey (unless of course due to some unforseen circumstances).
Hopefully this information is useful to the community here. Thanks for reading
sudeepg is offline   (9) Thanks Reply With Quote
Old 18th June 2017, 13:53   #48
Dr.Naren's Avatar
Thanked: 5,610 Times
@sudeepg : Very informative post and good to see that you have rectified the major wiring issues. Do send the link of this post to EVO Bangalore, it would be very helpful for them . I couldn't believe that I paid 2500 Rs for the dirty unsafe installation job done at EVO. It's high time Xenon Planet find a better installer to offer at least safe wiring for Bangalore customers.
Dr.Naren is online now   Reply With Quote
Old 18th June 2017, 13:59   #49
Thanked: 61 Times
Sudeep- Great work. I am sure there are only minority of folks who will spend time and effort to get this done. I am really privileged to be in the company of such experts and assisting me and everyone in the forum with even the minutest details. Kudos to Team-BHP for bringing us together.
On a separate note, as acknowledged earlier - Rajat from XP has been providing unstinted support to all for all their issues and of course the perennial complaints made against his company. He has to fix his partners better and across India and that will help his business grow leaps and bounds. I am sure he is working on it.
Ananthc is offline   (1) Thanks Reply With Quote
Old 18th June 2017, 16:18   #50
sudeepg's Avatar
Originally Posted by Dr.Naren View Post
I couldn't believe that I paid 2500 Rs for the dirty unsafe installation job done at EVO. It's high time Xenon Planet find a better installer.
Agreed on both points. I and lovetorque paid 2750. Does the install look anything that's worth that money?
100%. The only reason I opted for them is because their support is outstanding. Their major issues are with their partners. I believe XP is working to sort out problems.
sudeepg is offline   Reply With Quote
Old 18th June 2017, 16:21   #51
Dr.Naren's Avatar
The install at EVO was just to make the XP Micro "Work". They have cut corners everywhere. It is like you guys paid 2750 Rs for a planned suicide of your car and yourself
Dr.Naren is online now   (1) Thanks Reply With Quote
Old 19th June 2017, 18:16   #52
sudeepg's Avatar
Yes, they have cut corners for sure. Imagine at the price of installation we paid, a simple connector and waterproof tubing hardly costs 100 rupees. Is it worth passing on such a big risk for such a low cost to the end customer? Absolutely no!
It's high time XP found better install partners in Bangalore. They need to work on this and fix these issues as soon as possible.
I'd recommend that you use tapes over the exposed connector just to keep it safe. A water splash to those fog lamp connectors could give you serious trouble on your car.
Old 8th July 2017, 23:04   #53
sudeepg's Avatar
Some of the affected cars are getting rectified now. BHPIan lovetorque's car was the first to get the fixes. Detailed information is posted here
XP Micro Woes - Fixes applied (XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences)
Old 9th July 2017, 23:09   #54
nischaltopno's Avatar
Thanked: 11 Times
Wiring schematics for this install
Here's the basic wiring of connecting the HID bulb to its ballast
Attachment 1639177
(Source: Google Images)
From the diagram it looks like that tapping power directly from the battery is NOT required (which is normally done for 100/90 upgrade with wiring harness and relay). However, wanted to check and confirm on this if the input to the ballast from O/E connectors is sufficient and the right way to do.
Any impact on the original wiring in terms of load?
Wiring done to connect the high beam of the XP Micro
Attachment 1639178
Did you upgrade the fuse, since you are tapping the input for high beam from the O/E fog lamp power source. Or since it's just the solenoid, the bump in the power requirement is quite marginal?
nischaltopno is offline   Reply With Quote
Old 9th July 2017, 23:13   #55
Thanked: 13,278 Times
Ya the power for the ballast comes from OE connections.
I have kept the fuse etc stock. Also since the solenoid is what triggers the high beam conversion, didn't add any relay.
If one is going for a 55W setup then it is advisable for a relay.
a4anurag is online now   (2) Thanks Reply With Quote
Old 10th July 2017, 11:57   #56
Thanked: 121 Times
Infractions: 0/1 (5)
Quick update on the micro XP install fixes done in my S Cross:
http://www.team-bhp.com/forum/modifi...ml#post4230975 (XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences)
http://www.team-bhp.com/forum/modifi...ml#post4231517 (XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences)
The issues with the install done previously at EVO has been fixed at Blackworks, thanks for Shyam, Venkat and his mechanic.
Special thanks for Anurag for the inputs, Sudeep for the spares and more importantly spent the evening to make sure all fine
lovetorque is offline   (2) Thanks Reply With Quote
Old 12th September 2017, 00:08   #57
Thanked: 95 Times
Hi a4anurag,
I will be travelling to Goa in next few weeks and really want to change my stock lamps as I will be driving at night continuously. I was looking to upgrade the head lamps of my Xcent but stumped upon your thread on XP Micros. Do you recommend to upgrade my stock fog lamps to micros ? Also do you recommend to get them installed at the distributor (priced heavily) or can a auto electrician fix them ? Thanks for your suggestion !!
HighwayHopper is offline   Reply With Quote
Old 12th September 2017, 00:29   #58
Hi Sir,
I love the XP Micro in my Swift, highway driving is pleasure thanks to good beam spread that lights up a wider area without glaring oncoming vehicles.
I see you are from Hyderabad, when are you planning to buy? Please PM me. We can take it up and complete the installation if things go well.
a4anurag is online now   Reply With Quote
Old 12th September 2017, 02:23   #59
Thanked: 95 Times
Hi Sir,
Thank you so much a4anurag for offering . I was looking into another thread where the early users of XP Micros had terrible experiences but reading your post gives me immense confidence to go with it. I stay in Alwal (very near to Suchitra) and I am planning to buy a pair in second week of October. Do you recommend to buy them online or talk to the distributor and get it from him. Thank you again !!
Old 12th September 2017, 10:15   #60
Coincidence, I stay near Loyola PG College, Alwal.
You can buy it from the local XP partner. I'll PM you his number. Contact him and get the setup.
XP Micro: Bi-Xenon Projector Foglamps. EDIT: Terrible experiences Dr.Naren Modifications & Accessories 198 13th September 2017 13:55
Installed! Bi-Xenon Projectors on my VW Polo GT TSi. EDIT - Reliability concerns on page 8 graaja DIY - Do it yourself 127 18th May 2017 15:00
DIY: VW Polo Bi-Xenon Projectors. Morimoto Mini D2S Stage III Installation Gannu_1 DIY - Do it yourself 76 20th September 2016 12:42
PICS : Installed Bi-Xenon Projectors on my Innova nitinbose Modifications & Accessories 20 21st September 2015 20:43
DIY: Maruti Suzuki Swift Bi-Xenon Projectors. Morimoto FX-R 3.0 Installation shashank.nk DIY - Do it yourself 17 23rd June 2015 10:52
