Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 31st May 2017, 17:01   #16
Crankpin's Avatar
Thanked: 67 Times
Default Re: D.I.Y. - Changing the brake pads of my Honda Civic
I think there is air in the system hence the softness in pedal movement. You'll need to bleed the brakes till there is no air.
Damn..I thought those SVC guys are supposed to bleed it off completely.
Crankpin is offline   Reply With Quote
Old 31st May 2017, 18:38   #17
R2D2's Avatar
Thanked: 1,096 Times
Ok, here's the thing; if your car has ABS the tech performing the service is also supposed to take due care to ensure the system is bled properly.
If they've taken short cuts due to pressure of getting the job done ASAP (which is quite the norm) there may be a little bit of air that's trapped in the system.
Please ask them to do a thorough check, bleed the system properly, top off the brake fluid (if required) and, most importantly, test the brakes when done.
Even the most inexperienced technician will know if the brakes are spongy and what causes it.
Old 31st May 2017, 19:04   #18
Crankpin's Avatar
Thanked: 67 Times
Yeah that's what I had thought that it would be the air in the system that's causing the sponginess besides,
Since I had got the fluid changed I was under the impression it's something else. Taking it back and asking him to recheck is a challenge!
Old 1st June 2017, 12:19   #19
RGK
RGK's Avatar
Thanked: 205 Times
Default Re: Pictorial : DIY - Changing Brake pads of my Honda Civic
Originally Posted by laluks View Post
Making ready for the new Brake Pads
The round portion is the one which pushes the brake pads towards the discs when you hit the brakes.
Attachment 1642624
p
Great and detailed DIY . This round portion is called the brake piston (single piston) which pushes the pads when the pressure is applied from the master cylinder.
RGK is offline   Reply With Quote
Old 14th June 2017, 15:04   #20
Dude this looks pretty comprehensive, is there a way we can order the pads online?
Drmani is offline   Reply With Quote
Brake Pads.. karthik247 Technical Stuff 44 3rd June 2017 23:11
Price of New Brake Pads for OHC 1.5? buzzin_hornets Technical Stuff 26 22nd March 2015 11:50
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Rear Pads Worn Out Faster Than Front Pads! How is this possible? Tripod Technical Stuff 13 29th April 2009 22:16
STOP PRESS - Ferrari Enzo brake pads on a Jeep!!! GTO Modifications & Accessories 7 23rd February 2006 11:22
