Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself
Thread Tools
Old 25th August 2004, 18:06   #1 (permalink)
libre sito's Avatar
Unhappy Need help in making my subwoofer box
i need help in making a subwoffer box for my 15" audiobhan subwoffer as my old box got crapped by battery acid.
__________________
HAVE IT FLAUNT IT
libre sito is offline   Reply With Quote
Old 25th August 2004, 19:01   #2 (permalink)
Rehaan's Avatar
Check out this thread.
to quote "Digital Vampire"
Originally Posted by [b
Quote[/b] ]So the area where they can really goof up is the design of the vented enclosure. This area used to be a black magic art earlier, but with the advent of smart softwares like WinISD, it is much simplified these days. Armed with the correct Small-Thiel parameters for the subwoofer which is usually available from the manufacturers website, designing a Ported Enclosure is a cakewalk. A few years back, I’ve designed a ported enclosure with WinISD and coupled with a 12” Marantz driver, it outperformed my Yamaha Subwoofer (Dual 8” Drivers) in the home theatre setup.
Im sure he will be able to help you out!...
cya
R
__________________
The memory of you will ride by our side forever.
Old 26th August 2004, 17:16   #3 (permalink)
there are a lot of programs available on the net, if fact just google the name of your sub for ex: "audiobahn 15xxx box specs" & you'll get a lot of replies on different forums etc.
lib if you want the box made, lemme know i'll give you instructions on getting to this person in sion who will make an excellent box for you, all you have to do is give him the specs
Godspeed is offline   Reply With Quote
Old 27th August 2004, 15:45   #4 (permalink)
libre sito's Avatar
Hey godspeed im not able to get the right specs some how some help will be appreciated nd how much would da guy in sion charge me for da box
__________________
HAVE IT FLAUNT IT
Old 27th August 2004, 18:47   #5 (permalink)
ok libre
you will have to get me the model name of the woofer, for example one of the models is the AW1500Q, if you have the manual most of our work will be done, see what all you can find out.
Box will not cost more than 800-1000 bucks,will be of good quality mdf.
Old 27th August 2004, 23:42   #6 (permalink)
libre sito's Avatar
Hey Godspeed
I have emailed audiobhan for da specs lets see weder dey replied
__________________
HAVE IT FLAUNT IT
Old 28th August 2004, 00:24   #7 (permalink)
The Specs may be available from the AudioBahn website.
Go to http://www.audiobahn.com/frame2004.html and select the appropriate model/year.
The page also lists a host of box calculators as well...
__________________
If you could live forever, What would you live for?
Digital Vampire is offline   Reply With Quote
Thread Tools
Hello from an engineer in the making !! d3mon Introduce yourself 16 13th December 2008 21:51
Making a Will Raja Shifting gears 18 25th November 2008 22:01
Best direction to face box subwoofer in boot of car ? DRAGONLORD Ask the Gurus 4 28th December 2007 02:31
suggestions regarding making of subwoofer box beanstalk_230 DIY - Do it yourself 110 23rd October 2007 16:59
New AC making noise Real_man Technical Stuff 2 22nd March 2006 05:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
