Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 18th June 2017, 19:13   #1
vsaravind007's Avatar
Thanked: 354 Times
Default DIY: Fixing the Skoda Laura's jumpy blower speed knob
Hello again everyone!
This one needs no introduction to Laura owners, pretty much everyone with a Laura thats over 5yrs old is having this issue or starting to experience this. For those who don't know what this is all about, I'll explain it. In Skodas & VWs, the AC fan blower speed is set/controlled using a rotary knob like all other cars with one significant difference - the don't have fixed steps for speed. They rotate 360 degrees and depending on the direction of turning, it'll either speed up or slow down the fan. Of course there is a speed indicator. This is good(?) for ergonomic reasons, but the technical side of this is quite complex. This kind of setups use something called a 'rotary encoder' which detects the direction of turning and the number of rotations. They're commonly used in car stereo volume controls. This will work as intended for quite some time according to VW. But, in our climatic conditions we might need to adjust the temperature & fan speed to either sides of the temperature spectrum in the same day itself! That takes its toll on the control knobs.
In Laura(L&K Versions), there are 3 such knobs - Driver side temperature control, Passenger side temperature control and the fan speed control. The fan speed control knob is the one that is used more often. When this fails, It'll become hard to adjust the speed of the fan to our liking, the speed will jump up/down irrespective of the direction of knob turning. It'll become extremely hard to adjust & will require a lot of patience. A replacement fix would cost around 10k as they'll replace the whole climatronic control unit which has a couple of LCD screens, seat heating controls and others. I know how these rotary encoders fail & often times they're irreparable. Initially I thought about removing the passenger side temperature control encoder and swap it with the fan speed control encoder. Since the passenger side temperature control is not used often, it was a logical decision. But once I got to the encoder, the German engineering revealed itself! The encoder is completely repairable & requires no swapping! Just a bit of cleaning with a bit of rubbing alcohol did the job and it works good as new!
This is a good read if you'd like to know more: http://practicalusage.com/side-proje...tary-encoders/. Our cars use the same principle but uses superior quality components.
If you're going to try out some kind of DIY on a German, you'll need a Torx tool set. A generic one would do. I use the following tool set & it has quite a lot of tools. This is sufficient for everything interior.
DIY: Fixing the Skoda Laura's jumpy blower speed knob-.jpeg
Disclaimer:
As always, attempt at your own risk!
Steps
1) Remove the plastic trim around the stereo and the climatronic controls. To do that, open the cigarette compartment in front of the gear knob, pull the trim out from the lower side:
DIY: Fixing the Skoda Laura's jumpy blower speed knob-1.jpeg
DIY: Fixing the Skoda Laura's jumpy blower speed knob-2.jpeg
DIY: Fixing the Skoda Laura's jumpy blower speed knob-3.jpeg
Be careful when you pull it out from the top side. Use a bit of caution and DO NOT pull hard, just use a bit of pressure and have patience!
DIY: Fixing the Skoda Laura's jumpy blower speed knob-4.jpeg
2) Once the trim has been removed, you'll get to see the climatronic control unit. Remove the torx screws that are annotated by the red arrows:
DIY: Fixing the Skoda Laura's jumpy blower speed knob-5.jpeg
3) Once the screws are removed, the control unit will come off easily. Now comes the tricky part! Removing the electrical connectors from the unit. These are NOT the usual push and pull type connectors. In the below image, have a look at the red plastic tabs. Pull those up first and then remove the connector. I've annotated where to pull. Just pull the red tabs up, and the the connector itself. They'll come off easily:
DIY: Fixing the Skoda Laura's jumpy blower speed knob-6.jpeg
DIY: Fixing the Skoda Laura's jumpy blower speed knob-7.jpeg
4) Once the unit is out, put it out on a flat surface with adequate lighting.
DIY: Fixing the Skoda Laura's jumpy blower speed knob-8.jpeg
Turn it over to reveal the screws behind:
DIY: Fixing the Skoda Laura's jumpy blower speed knob-9.jpeg
Once again, use the torx set and remove the screws. Once the screws are out, the unit can be opened up.
DIY: Fixing the Skoda Laura's jumpy blower speed knob-10.jpeg
DIY: Fixing the Skoda Laura's jumpy blower speed knob-11.jpeg
5) There are 3 encoders and the one annotated in red is the one we're after. They're tiny and not at all like the generic ones. These are well engineered surface mount encoders that use metal tracks and high quality plastics.
DIY: Fixing the Skoda Laura's jumpy blower speed knob-12.jpeg
We can take apart the encoder to clean the inside. To do so, take of the metal caps on them. The caps can be removed easily, use a safety pin or a long paper pin to pry up the cap out of the locks. Refer the below image, use less force, they're delicate and will come off easily:
DIY: Fixing the Skoda Laura's jumpy blower speed knob-13.jpeg
Simply use a tiny force and the cap will come right off:
DIY: Fixing the Skoda Laura's jumpy blower speed knob-14.jpeg
Be sure not to bend/flex the metal cap during handling.
6) Remove the part that is in the middle of the encoder. This part rotates and is partially responsible for the issue we're having.
DIY: Fixing the Skoda Laura's jumpy blower speed knob-15.jpeg
Using a bit of rubbing alcohol, clean the tiny metal fingers annotated in the image. Also, use the safety pin to slightly pull up the fingers to restore them.
Now use a bit of rubbing alcohol and a clean cloth to wipe the tracks on the encoder body. Make sure that you'll wipe the tracks multiple times to clean up well.
DIY: Fixing the Skoda Laura's jumpy blower speed knob-16.jpeg
Once you're happy with the clean up, put the centre piece of the encoder back, and then the metal cap.
7) Putting it back together requires a bit of trickery. On the second half of the control unit, there are tiny tabs that align with the rotary encoders on the circuit board. The encoders have rectangular holes while the plastic pieces on the other half have tiny rectangular projections. Annotated below. Make sure that all of them can go in and lock into place:
DIY: Fixing the Skoda Laura's jumpy blower speed knob-17.jpeg
Once that is done, make sure that all 3 knobs are turning. Put the screws back in and assemble the unit.
8) Putting back the connectors requires the red tabs to be in pulled out position. Put the connectors back one by one and then push the red tabs to lock them in place.
9) Put the unit back into the car, tighten the screws by 2 threads, but DO NOT tight them up yet. Make sure that the unit is in place, take the radio trim and verify alignment. You might have to adjust the unit by moving slightly to the left or right. Once you're happy with the fitment, tighten everything up.
Thats all! Now you have a perfectly working ac blower speed control knob!
Notes:
1) DO NOT use a lot of force while removing the radio trim
2) DO NOT touch the tiny components on the circuit board with wet/sweaty hands.
3) DO NOT take out the LCD displays out
4) Have patience while putting it back!
While working on this car, I've learned that it takes a lot of patience to put something back once it has been removed from the car, quite strange!
Thank you for reading!
vsaravind007 is offline   (26) Thanks Reply With Quote
Old 18th June 2017, 22:29   #2
salbin's Avatar
Thanked: 164 Times
Default re: DIY: Fixing the Skoda Laura's jumpy blower speed knob
Thanks for the detailed writeup
Apart from the patience required for putting everything back, it requires great level of patience to document the whole process, that too with pictures.
BTW, I will be attempting this next weekend.
salbin is offline   (2) Thanks Reply With Quote
Old 19th June 2017, 13:14   #3
TheLizardKing's Avatar
Thanked: 484 Times
Default Re: DIY: Fixing the Skoda Laura's jumpy blower speed knob
Thank you for the post. I have had a problem with the blower speed knob on my 4 year old Polo since the beginning. The speed won't stay in one place. If I set it at 2 bars, it drops back to one bar after a few minutes. Also, when I accelerate, it jumps to 3 bars by itself, before dropping back to 1 bar.
The workshop guys have not acknowledged the problem, and say it is as designed. Do you think your DIY will fix my problem?
TheLizardKing is offline   Reply With Quote
Old 19th June 2017, 21:44   #4
Thanked: 354 Times
Thank you salbin! Try it out and let me know the outcome!
Hello TheLizardKing, I don't think the issue you're facing is related to this. But there is a possibility of a broken rotary encoder doing this. Is it working fine when you adjust the speed? If it is working fine when you turn the knobs, it is not related. Else, you can try to clean them up carefully.
vsaravind007 is offline   (1) Thanks Reply With Quote
Old 19th June 2017, 23:44   #5
salbin's Avatar
Thanked: 164 Times
Couldn't wait till the weekend and I did both your DIYs today itself
Now both works flawlessly.
Thanks...
In fact, I did cut both the upper and lower parts of the button. The upper one switches on and off the AC, whereas I couldn't figure out what the bottom half does
Any pointers?
salbin is offline   Reply With Quote
Old 20th June 2017, 06:29   #6
Tgo
Tgo's Avatar
Thanked: 268 Times
Wow, great job.
I was wondering if this switch/encoder is similar to the volume adjuster on my Figo's music system. Its become very difficult to adjust the volume. Either moving the knob makes no change to the volume or it makes a change in random steps +2-1+1-3+4+1-5 like that. I have noticed that applying a slight pressure on the knob along its axis gives you some sort of control.
Tgo is offline   Reply With Quote
Old 20th June 2017, 09:31   #7
Thanked: 354 Times
Thanks...
Any pointers?
Hi salbin! Glad you got it fixed. The bottom switch is marked as 'Dual' in other VW cars with similar climatronic control units:
You can find the details of it here: http://forums.vwvortex.com/showthrea...nic-control-do. I was lazy to do a bit searching on its functionality & hence I skipped! Let me know if it is working.
Originally Posted by Tgo View Post
Wow, great job.
Thank you so much Tgo! Yes, the encoder has gone bad on your music system. These things are bound to fail under moderately heavy usage. It works fine when a bit of pressure is applied is because the tiny metal legs on the rotary part has gone flat. When a bit of pressure is applied, they can make the contact with the tracks. I highly doubt if it can be fixed with a DIY if you're not comfortable in taking apart the stereo! Any TV/stereo repair guy can fix it.
vsaravind007 is offline   (2) Thanks Reply With Quote
Old 21st June 2017, 10:11   #8
Thanked: 484 Times
Hi. Thank you for taking the time out to reply to my query. The knob works fine 99% of the time (except the odd instance where I turn it and nothing happens). The VW workshop guys gave me some spiel about it being related to the climatronics, but I have my doubts.
Old 29th June 2017, 09:13   #9
Thanked: 354 Times
Hi TheLizardKing, I too have the same opinion, climatronic control unit(the unit in which switches and the tiny LCD is located) maybe the culprit. Easiest way to check it is to swap it with a unit without issues. Also, when it behaves oddly, try to check if other switches/knobs on the unit are also having issues. If that is the case, you're looking at a control unit replacement fix!
DIY: Fixing the central locking / unlocking switch (Skoda Laura) vsaravind007 DIY - Do it yourself 2 4th February 2017 23:33
Fixing the noise from Santro Heater/Blower assembly ashish_me2 Technical Stuff 4 16th July 2016 00:56
DIY - Fiesta v1/Classic Gear Knob Change mayankk DIY - Do it yourself 6 23rd June 2014 14:23
DIY: BMW E90 (pre-LCI) - M5 SMG Knob retrofit aah78 DIY - Do it yourself 3 16th May 2010 20:26
Nissan Quest - Intermittent air-con blower speed vivekiny2k Technical Stuff 1 21st July 2009 13:11
