Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 6th November 2017, 14:00   #1
sujithsidhardha's Avatar
Thanked: 89 Times
Default DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)
There were rumours around the connection of reverse camera to 5" oem head unit of Hyundai Creta. When taking delivery, I enquired this to my dealership and they denied it and confirmed that its impossible. Instead, they offered the solution to fix the camera on bumper and a separate 7" display or adding a rear view mirror with reverse camera display. Estimate was around 9,000/- and they were ready to offer some discount as well. But I was not interested in drilling a hole on the bumper. From that time, I was searching everywhere about the possibility of adding reverse camera input on my oem 5” head unit. Saw a video on youtube and confirmed that it works. My next task was to identify the pin out and connection diagram. Finally I got the pin out and diagram from one of the Hyundai forums. The 5” head unit is used on other models also.
Items required.
1. Jumper cables or “Car RCA Into 16 Pin Interface Adapter Cable” available at aliexpress, but very costly! Link
2. Pry tools
3. Reverse Camera
4. Tags to keep everything in place.
Cost
600INR for camera plus a half day. If Jumper cables are used instead of the connector, they will cost only around 100 including them and VGA connector.
Removal of head unit face plate
This is very important - To avoid damage to the dash board, keep a thick paper or stick tape around the head unit and start the prying process. Else you will end up with the beige coating on dash board damaged. You need to apply some pressure to get the faceplate removed. Start from the lower middle part and move sideways and finally top. Once the faceplate is removed, don’t pull it apart. You have to unlock and remove the connector of digital clock. Once it is removed, you can start unscrewing the head unit. Once the screws are unscrewed, slowly pull the head unit. No need to take out the head unit completely to fix the new connector. If you need to take out the head unit completely, remove the wiring harness and antennae connector from the back side of head unit.
Prying started.
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-1.jpg
Removing the faceplate
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-2.jpg
Removing the connector of digital clock
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-3.jpg
Removing the screws of head unit for taking it out
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-4.jpg
Connector
The connector is called “Car RCA Into 16 Pin Interface Adapter Cable” and Hyundai ASC had no clue about this connector. This connector is also called Connector C, as per the component documentaiton. I purchased it from aliexpress. This is a 16 pin connector, and we will be using Pin 3 as the camera ground, 4 as the Camera video input and 12 as the camera input trigger,which is the positive voltage line from reverse lamp. In case of unavailability, you can use jumper cables also. Jumper cables are very economical.
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-5.jpg
Connector view
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-6.jpg
Jumper cables, which you can use as an alternative
Connector Pin out
Adaptor cable Connection and testing
Before wiring everything, I need to make sure that the setup works. For that, I connected the Adapter Cable to the back of the head unit and the reverse camera to the other end of the Adapter Cable. You can trigger the camera input with a +ve supply. I checked the camera using the positive terminal from lighter socket and it worked! Now its time to fix the reverse camera and wiring. Decided to do the wiring first and if the wiring is successfully done, I can drill a hole and fix the camera.
Back side of head unit, where the connectors should go. You can see the extra connector on left
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-9.jpg
This is the adapter cable connected to the VGA cable
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-10.jpg
Adapter cable connected to the head unit
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-11.jpg
Wiring
Ensure the Adapter Cable is in place and it’s time to put back the head unit. Once the head unit is screwed back, we can start the cabling. There is a cable already going to the back from dashboard through the left pillars and landing at tail gate through c pillar. Follow the path and you need to remove the plastic trim on a pillar, then the left roof till the tail gate. Remove the grab handles on left passenger side and co passenger sides. Take extreme care when removing the under roof part, as it can easily get folded like a paper carton. I never thought the quality was this much low. Once you reach the back, you can see the cable pass through a rubber cover to the tail gate. You can use the same cover to wire the cable to the tail gate, so that it looks like a factory finish
Follow this path. There is a cable already going thorough this path and you won't find it difficult to follow.
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-12.jpg
Wire through this rubber covering
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-13.jpg
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-14.jpg
Wired through it and fixed it back. Looks not tampered at all.
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-15.jpg
Fixing the camera
Remove the plastic trim from the tailgate. Before removing the panel, make sure to detach the boot unlock switch. Once the panel is removed, drill a small hole and fix the camera. Align the camera as per your requirement. Connect the camera to the cable we wired from the head unit. Once the camera is connected, we have one wire left, which is the camera input trigger. We need to connect it to the positive terminal of reverse lamp.
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-16.jpg
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-17.jpg
Camera trigger
Reverse lamp had 2 blue wires and it was connected to a connector. The blue wires was joined with one light green and black wire. To ensure the polarity, I used a multi meter and found that the light green wire is the positive terminal and it is the wire we need to trigger the camera input. No wire splice or scotch connector was used in my case. I simply spliced the camera trigger wire and inserted it to the green wired connector and plugged it back. There is a dark green wire also in the connector. Don't get mistaked.
The camera trigger was connected to this
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-18.jpg
Final testing
Now everything is in place and I double checked the installation. Switched on the head unit and put the gear to reverse. I could see the rear image on head unit screen. Mission Success!
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-19.jpg
Camera fixed
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-20.jpg
Long view
DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)-21.jpg
Reverse camera in action
sujithsidhardha is offline   (61) Thanks Reply With Quote
Old 8th November 2017, 10:38   #2
sudeepg's Avatar
Thanked: 1,287 Times
Default Re: DIY: Adding a Reversing Camera to the Hyundai Creta (5" OEM Head-Unit)
Superb DIY. Very well documented too. Thank you so much for this. I am not surprised to hear that Hyundai Service is unaware of this approach. Most after sales service workshops do not want to tamper (even if its completely safe) with any equipment, unless they have a direction from the manufacturer for installation of the accessory. In my S-cross the door sil guards were installed by the dealer and they had a specific document on how to install it, which includes wire splicing using 3M scotch lock. On the second service, service folks made a hue and cry about the scotch lock connector, to which I simply showed them the Genuine Nexa booklet that shows how this official accessory must be installed. That silenced them.
Using connectors is always the best approach since it allows reversal of the install and most importantly it always ensures a secure connection. In my experience AliExpress is THE place to get all types of connectors, its simply not available in India.
sudeepg is offline   (2) Thanks Reply With Quote
Old 8th November 2017, 11:19   #3
Thanked: 1,123 Times
Infractions: 0/1 (5)
This is neat. Very well done work.
I hope your DIY work will provide necessary support to other forum members to take up this task in their cars.
Reverse camera is very important and useful.
Thanks for your taking up this challenge !
i74js is offline   (1) Thanks Reply With Quote
Old 8th November 2017, 18:58   #4
PetaWatt's Avatar
Thanked: 56 Times
Nicely done and explained well too.
Originally Posted by sujithsidhardha View Post
Cost
600INR for camera
You got a very deal on camera. I bought the camera with similar dimension but Chrome finish from amazon for INR 2500. Before installing, I measured the current consumption, it was 180 mA. Did you get a chance to measure the current consumption of the camera?
Wiring
Attachment 1693082
It will be great if you can share some photos (if taken). When I was installing camera 2 weeks back in my Duster, I was uncomfortable opening roof lining, used the floor lining instead. For roof lining, I was suppose to remove the door beading and those handles too. I felt removing floor line was cheaper approach as door bead's start and end point was there itself.
PetaWatt is offline   Reply With Quote
Old 8th November 2017, 23:11   #5
PetaWatt's Avatar
Thanked: 56 Times
Correction: In my log book I found that the current consumption for the camera I installed on my Duster is 95mA. By mistake, I told the current rating of the camera I had rejected(The free one with the display, it was heating up too)
Old 10th November 2017, 10:10   #6
Thanked: 89 Times
I got the camera from aliexpress and hence the low pricing. Sory. I haven't measured the current consumption. Since it is not an always on device and works only on reverse, i didn't bothered to check it. Defenitely, i will check it when i have a chance to open it again.
Sorry again. No photos were taken during the wiring through roof. If its a creta, once you open the a pillar trim, you can follow the existing cable all the way. I checked roof as well as floor and found roof as the easiest way to do the cabling. Wiring through the floor required additional work like more plastic trims to be removed. Seems it depends on the vehicle. In my santro, wiring through the floor was an easy task.
sujithsidhardha is offline   Reply With Quote
Old 20th November 2017, 13:03   #7
Thanked: 89 Times
Those who are not interested in drilling the plastic trim can opt for another camera model. If anyone is interested, link is here and cost around 700INR. This can be installed by removing the existing number plate illumination light cover. Do consider the below reasons as well which kept me away from this model.
1. Can easily be removed/ stolen and can be damaged with a twist.
2. Seems it will protrude more than the existing camera. Not sure though, it seems so.
Only merit is that you don't need to drill the trim.
Step-by-step instructions: Updating the Hyundai Creta's Head-Unit software nkghai In-Car Entertainment 14 11th February 2018 19:06
Volkswagen Vento Highline Plus launched - LED headlamps, LED DRLs and reversing camera dZired The Indian Car Scene 69 26th October 2017 20:49
Hyundai Fluidic Verna : Upgraded to OEM Head-Unit with Touchscreen, Navigation & more drhoneycake In-Car Entertainment 14 16th June 2017 14:32
MapmyIndia's Smart Mirror: Integrated IRVM, Reversing camera & Navigation solution GTO Modifications & Accessories 9 19th August 2015 09:25
