Go Back   Team-BHP > Under the Hood > Technical Stuff > DIY - Do it yourself
Old 12th December 2017, 22:53   #1
ckranjan's Avatar
Thanked: 108 Times
Default DIY: Adding instrument cluster & HU brightness control to the Hyundai i20 Sportz
Part required :
Part No. 93300-C7900TRY
https://boodmo.com/catalog/part-comp..._rbl-25454400/
Image link : http://www.team-bhp.com/carpics/hyun...ite-i20-06.jpg
Original Switch :
DIY: Adding instrument cluster & HU brightness control to the Hyundai i20 Sportz-img_21941.jpg
Time Required : 5 Minutes
Tools required :
Trim opening tool such as this :
https://www.aliexpress.com/store/pro...842097321.html
Open the existing switch by prying open the switch. Disconnect the wiring. Add the new switch. Reconnect the wiring. Close it by pushing it in the slot.
The result :
The connector for brightness control is already there. This feature is present on the asta models.
ckranjan is offline   (17) Thanks Reply With Quote
Old 13th December 2017, 05:45   #2
AShubrah's Avatar
Thanked: 161 Times
Default re: DIY: Adding instrument cluster & HU brightness control to the Hyundai i20
This will be very helpful to the people who didnít see the Asta or Asta (O) model as VFM, and ended up cursing Hyundai for not providing something as basic as this in a car this expensive.
On a lighter note, itíll be sight to see when the SA explains the difference in features between the Sportz & Asta model using this particular brightness adjustment function to a person whoís read this thread & ends up knowing that it can fixed on to any variant for just ₹ 1625/-
Also, it would be great if you could post some pictures taken during the installation as well.
AShubrah is offline   Reply With Quote
Old 13th December 2017, 06:30   #3
Thanked: 13,387 Times
If this is the case and all it takes is that switch to be added into an existing coupler, this will be good for owners of the lower model Creta.
I say this because I think the cluster is same as in your car of the SX+ and lower variant of the Creta.
DIY: Adding instrument cluster & HU brightness control to the Hyundai i20 Sportz-screenshot_20171213062907.jpg
Part number (Creta specific): 93300-A0900TRY
Old 13th December 2017, 07:25   #4
AShubrah's Avatar
Thanked: 161 Times
The Asta & lower variants of the i20 Elite do indeed share the same cluster as the SX+ & lower variants of the Creta.
Here is a picture from the official review itself.
However, unlike the i20 Elite, there’s a traction control switch in the SX (O) model of the Creta as well, so I’m doubtful if adding the IC Light Adjustment switch will just be a plug n’ play affair.
DIY: Adding instrument cluster & HU brightness control to the Hyundai i20 Sportz-hyundaicreta08.jpg
Old 13th December 2017, 07:40   #5
Originally Posted by AShubrah View Post
However, unlike the i20 Elite, thereís a traction control switch in the SX (O) model of the Creta as well, so Iím doubtful if adding the IC Light Adjustment switch will just be plug ní play affair.
I agree. But no harm in trying.
I'll see if I can get access to a lower variant of Creta. I'll see if this can be added or not.
a4anurag is offline   (1) Thanks Reply With Quote
Old 13th December 2017, 09:54   #6
ckranjan's Avatar
Thanked: 108 Times
It can be easily checked as in i20 there is a seperate wire for headlight control and ic light control. When i took out the old switch both the wires were there. The ic control wire was attached to a dummy socket. All it needed was a real socket to connect the wire.
Hope this helps.
Letme know if any more details are required. I'll probably make a video of it.
ckranjan is offline   (1) Thanks Reply With Quote
Old 13th December 2017, 11:49   #7
Thanked: 43 Times
Default Re: DIY: Adding instrument cluster & HU brightness control to the Hyundai i20 Sportz
Excellent find, gonna order it for my i20 Sportz. This is going to be a big help. In night driving, I find the brightness way too high, almost stings the eyes.
I was wondering about another thing, Elite i20's in other countries like Turkey and Europe do have fuel economy as well as DTE in their MID (both the standard MID and the Supervision Cluster model in Asta(O)).
Did anyone investigate whether its firmware can be flashed with that one. I searched, with no conclusive finding.
ts1506 is offline   Reply With Quote
Old 13th December 2017, 16:50   #8
I have been running around on the same lines for my Creta which too doesn't get the FE data whatsoever.
The new-gen Verna gets it so there must be some way to get it added.
It could be a simple firmware upgrade or the whole instrument clusters needs to be changed along with the software update to ECU and BCM (if such thing exists)?!
a4anurag is offline   (3) Thanks Reply With Quote
Old 13th December 2017, 23:08   #9
deepakr82's Avatar
Part required :
This really helps. The light on the cluster is far too bright during the night time. Thanks a lot for the DIY
deepakr82 is offline   Reply With Quote
Old 14th December 2017, 14:53   #10
sujithsidhardha's Avatar
Thanked: 87 Times
I was hoping for a connector attached to a dummy socket in my E+ Petrol Creta for the illumination control. But, it simply don't have a separate wire. Only one wire and it's connected to the headlight levelling switch. :(
sujithsidhardha is offline   (2) Thanks Reply With Quote
Old 14th December 2017, 15:00   #11
AShubrah's Avatar
Thanked: 161 Times
That was the exact same point I made a couple of posts ago.
Can you please post pictures of the same, good sir?
Also, can anyone with the SX+ variant try the same & confirm if there’s a second wire, apart from the one connected to the headlight leveller, or not?
Old 15th December 2017, 10:02   #12
Thanked: 87 Times
Here is the picture of switch connection E+ Petrol. You can see a dummy socket, but no connector attached to it. But 5 wires on a cable for a head lamp levelling control? Feel suspicious. Could the cable set be used for head lamp leveling and cluster illumination together? if so, the dummy socket may be for the traction control. Need to dig more in to it. Meanwhile, a switch cluster from a higher varient with traction control can provide more clarification.
DIY: Adding instrument cluster & HU brightness control to the Hyundai i20 Sportz-img_20171214_190740.jpg
DIY: Adding instrument cluster & HU brightness control to the Hyundai i20 Sportz-img_20171214_190608.jpg
VW Polo DIY: Removing / upgrading the instrument cluster Gannu_1 DIY - Do it yourself 28 13th April 2016 08:38
Used Parts (Instrument cluster- dials) ..? gary_yuen42 Modifications & Accessories 38 9th April 2014 13:31
can the colour of the in dash instrument cluster lights be changed??? mclaren1885 Modifications & Accessories 23 22nd August 2009 16:04
DIY - Blue instrument cluster & parking lights for Scorpio (2003 model, 1st gen) badboyscad DIY - Do it yourself 55 22nd December 2008 08:55
Instrument cluster light change nikibusa Motorbikes 7 10th September 2005 09:26
