Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 26th December 2006, 17:58   #1 (permalink)
clipto333's Avatar
Default advice for all you people with pioneer HU problem(alt whine)
hi,
i wanted to share this solution to the alt whine problem with pio HU
Earlier i had no problems but suddenly there was some sound which started coming from the speakers(alternator whine, it increased with the revs.) so i chnged my HU with a kenwood MP3 player(sparingly used)the noise went away. so i figured my pio HU was the culprit. I googled and i found out that there is a tiny fuse on the main circuit board near the rca inputs which gives up easily.its a problem with pio HUs so my repair guy bypassed this little fuse with a tiny piece of wire. So when i connected it back, the noise was gone.
(the fuse is on the backside of the board and there is this thing written next to the fuse [FU and some two or three digits with it] on the board.
i Guess quite a lot of people are having this kind of problem with their pio HU. IMO this is the only solution. ofcourse you can get the fuse replaced if its available.
Please correct me if im wrong.
Take care
clipto333 is offline   Reply With Quote
Old 26th December 2006, 18:20   #2 (permalink)
Sam Kapasi's Avatar
Hello clipto,
No you are not wrong, but this is not a blanket solution. A lot of pioneer HUs do have a fuse in the ground path and when it blows, the ground path to the audio out is left open, creating a loud ground loop whine.
The solution to all alternator whine problems is not so simple. It varies from a change in wiring, to a rerouting of cable to sitting back and accepting that you are in trouble.
OK the last one is no solution, but it's often true.
__________________
Live the YetiLife®
MA-DONNA! MA-DONNA! MA-DONNA!
Old 26th December 2006, 19:09   #3 (permalink)
jkdas's Avatar
well when this fuse blows teh HU works????
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 26th December 2006, 19:10   #4 (permalink)
Sam Kapasi's Avatar
Yes sometimes the fuse just breaks the ground to the audio section. I have seen this happen before.
__________________
Live the YetiLife®
Old 26th December 2006, 21:01   #5 (permalink)
Team-BHP Moderator
navin's Avatar
if the fuse broke ground completely you'd have a lot of fried ICs.
__________________
Scixelsyd Etinu
navin is online now   Reply With Quote
Old 26th December 2006, 22:51   #6 (permalink)
Hi friends .
This thing has started happening with my Esteem ( Pioneer HU) and the best part is apart from Alternator Whining // the A/c Fan Speed Noise ( goes like WHHOOOOOOOOO ) other than I can even hear my cars Horn coming from speakers even the Indicator ( tick tick) but sometimes all of a sudden it just VANISHES.
( This all just started happening 2weeks ago after I got my car serviced along with A.c servicing ....went to MArusti Guys they didnt have any idea and as luck would have it the problem just didnt show up when i went to Maruti..... had to go 2~3 times.... theyw erent able to diagnose it )
So now what to do ?
get the fuse checked in HU ?
Tnx n Rgds
P4C
passion4cars is offline   Reply With Quote
Old 27th December 2006, 01:20   #7 (permalink)
Tool's Avatar
hello.. umm this post might not pertain to pioneer Hu's but i had a minor alternator whine too which my alpine 9855 used to pick up . now i knew it wasent my wires and i tried every possible re-route too.. but still the slight whine didnt go.. finally when i upgraded to MSD 8.5mm super conducting igniton wires... Bingo.. no more whine at all. They are superbly sheilded against the Electro-magnetic interference generated by the super strong magnets in our alternators.
so this post might not help pio owners but for anyone else who has the best wires and has tried everything to get rid of the alternator and still has the whine...Try the MSD wires. they are better for your car and so...it cant hurt .
thats about it
boom
__________________
Why Drink And Drive When You Can Smoke And Fly ??.
Front Wheel Drive Is The Work Of Satan !!!
Tool is offline   Reply With Quote
Old 27th December 2006, 03:00   #8 (permalink)
clipto333's Avatar
Originally Posted by Sam Kapasi View Post
Hello clipto,
Hi Sam,
the solution i was talking about was only for those who were having this problem with their pio HUs.
Thanks.
Old 27th December 2006, 03:11   #9 (permalink)
clipto333's Avatar
Talking
hi,
in my case the HU was working. i did some jugaad to fix it temporarily. i grounded the outer part of one channel of the rca to my HU(i dont know what is the technical name but it was the outer ring and not the pin which goes inside the rca socket). please let me know the technical name if anyone can
thanks
Old 27th December 2006, 08:42   #10 (permalink)
Team-BHP Moderator
navin's Avatar
Originally Posted by Tool View Post
...finally when i upgraded to MSD 8.5mm super conducting igniton wires... boom
Tool,
firstly let me congratulate you. This is the first post of yours I could understand without having to read it twice. Excellent!
Do you have a link to these MSD wires?
__________________
Scixelsyd Etinu
Old 27th December 2006, 14:08   #11 (permalink)
clipto333's Avatar
Originally Posted by passion4cars View Post
Hi friends .
So now what to do ?
Tnx n Rgds
P4C
hi,
well the same thing was happening with my pio HU but only when the engine was not running. only alt whine was there when the engine was running. do you have an amp installed in your car. if yes there might be many reasons. But IMO there is some possibility that your HU fuse is blown.
Try some other HU and see if the sound is there.
Old 27th December 2006, 17:49   #12 (permalink)
amit_sound's Avatar
hi
I too am facing the same problem with my pio 7750. But wouldn`t the bypassing of the fuse lead to a possible burnout of the internal ckt. So how safe a bet is it to bypass ?
I will try and get the fuse replaced and see if it works.
Thnx
__________________
TRUE TO THE SOURCE - DD
Bass is an addiction...
And Professionally I am MAD: Mobile Application Developer
amit_sound is offline   Reply With Quote
Old 27th December 2006, 18:03   #13 (permalink)
viper's Avatar
Tool,
Hi Navin,
Here you go.
MSD Ignition Super Conductor Spark Plug Wire | Products from Viper Performance ...
Viper
__________________
NO ONE DARES COME CLOSE
viper is offline   Reply With Quote
Old 27th December 2006, 18:05   #14 (permalink)
gunbir's Avatar
Amit, the fuse usually blows when installers are careless with the RCA out connectors with the unit on. The centre (hot) pin touches ground somewhere and blows this fuse. A simple alternative (as pointed out by clipto) is to ground the RCA connector's ground externally. This will cure the whine in most cases where the Pioneer HU is the culprit.
__________________
Stuck in my head - Goldspot - Rewind
gunbir is online now   Reply With Quote
Old 27th December 2006, 18:15   #15 (permalink)
amit_sound's Avatar
hey
ooo ok, got it. thnx gunbir for the prompt reply...i definately will do that. Hoping this whine eventually subsides now.
__________________
Thread Tools
AC Compressor Problem: Info & Advice manveet Technical Stuff 11 1st August 2007 04:25
pioneer 5850 problem deepak_ms Ask the Gurus 5 16th July 2007 17:41
pioneer 7850bt backlight problem hemanthisgreat Ask the Gurus 8 15th July 2007 00:04
HELP!Problem with my Pioneer HU(DEH-740MP) somebodystopme Ask the Gurus 9 16th February 2007 23:04
pioneer Gm-x904 amp advice clipto333 Ask the Gurus 10 28th December 2006 09:18
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
