| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #31 (permalink) |
| BHPian | Great job!,im inspired to do it again. Just a few Qs, How did you manage to get pin 7 to fit in place without falling out.Solder?? Do you have and amp and a sub,and are they working properly with this wire?
__________________ HAhaha Last edited by binz : 7th January 2007 at 07:49. |
| | #33 (permalink) | |
| BHPian | Quote:
So tot of gettin some from banglre...
__________________ HELL UnLEAShED@4000rpm... | |
| | #36 (permalink) | |
| Newbie Join Date: Aug 2006 Location: Bangalore
| Quote:
For the pin no. 7 i used the same 4-pin cd-rom audio connector and chopped off 2 pins with a blade so that it tightly fits in place. The connectors are big and stick out of the plug so, i'll put a zip-tie ( used by mall shops to tie the shopping bags) around the connector to make it like a plug. I have the following ICE setup : Front JBL components and Rear JBL 2 -way connected/powered by HU. A 300.1 JBL amp running a 12" JBL tube. Yes, all of them work perfectly with the i-pod. | |
| | #37 (permalink) |
| BHPian | i also got a aux in for the ipod done from local accesory wala for 300 bucks the sq wasnt good and anyway the hu was giving me way too many troubles it was the 6850(dual panel) so I sold it for 6k(bought for 22k 3 years ago) and got myself a sony gtx550 with aux in |
| | #38 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
I dont know where I get my heat sleeve from. You see I work in a company that makes eletronics so the purchase dept does that part. Our office in Bangalore also has no trouble obtaining this locally so I assumed it was freely available.
__________________ Scixelsyd Etinu | |
| | #39 (permalink) |
| Distinguished - BHPian ![]() | Heat sleeves are available easily here at SP road. Even the purchase department in my office orders these from SP road in various sizes. I use some sort of heater gun dont know if it's infrared. angelfire, does mangalore have an area like SP road where you get all computer or electronics stuff. you could check there.
__________________ \ / ][ |) `/ [_] "!" (\./) (o.o) ( X ) This is Bunny. Copy Bunny into your signature to help him achieve world domination. |
| | #40 (permalink) | |
| BHPian | Quote:
Nd navin..if i can get a pic of that spring stuffs..wil def post it..It looks very primitive...
| | #41 (permalink) | |
| Quote:
So next thing to do was remove the elctrical tape of the wire and put some heat shrink tube. I did this with a hair dryer and once the tube was in its place i pulled over another piece of the tube on the original one just to make it more strong. ![]() It sure looks much more neat now . | |
| | #42 (permalink) |
| BHPian | Hi guys, Since this thread is named as DIY thread...tot i`d post out here only...moving from cables..lets come to speakers... I have a pair of kenwood 4"..that come with the esteem...Pics below...quite decent soundin though...in terms of calrity...but disorts a lot even if the volume is turned up a bit nd could not handle high power.....i removed nd replaced it with JBL....Now since they are lyin around tot i`d do somethin with them....like modifying them...for better use mating it with tweeters nd using it as comps...if possible that is...(i know am asking for too much from those 4 inchers... .but whts the harm in tryin..)Wanted to try makin 4" comps with jbl co-axials... ...but am quite happy with them...so tot i`d attack the kenwood speakers instead...![]() ![]() ![]() so All you diy`ers out there...want your inputs on this..anythin i can change to improve the sound....Especially navinji... Well..this is for my info... 1.Wht decides the power handling of a speaker?? 2.Does the size of the magnet affect the quality of the sound?
| | #44 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote: 1. Power handling: essentially of 2 types, mechanical and thermal. Mechanical power handling is determined by the suspension parts, glues used, integrity of the assemble etc. Thermal power handling is merely how much current the voice coil can take. The speaker in the picture must be about 15 W rms at best. 2. Size of magnet: It is one of the two main electrical parts of the transducer we know as the loudspeaker, the other being the voice coil. Magnet is responsible for the static field. Larger magnets can increase the flux density and damp the voice coil movement and keep it well controlled. However, the fluxshould be optimum, and hence it does not mean that largest of magnets will have the best sound. It depends on the rest of the parts of the motor also. At the same time, a tiny magnet will mean inadequate flux, control, and hence poor sound.
__________________ Operator! Give me the number for 911! |
| | #45 (permalink) |
| angel, B&T has covered much of what you need. you could work with this driver if you limit it's input to 200Hz+. a) Try using a bass blocker (which is really only a large capacitor in series with the speaker). b) If after the bass blocker you find the HF a bit harsh you could build a simple 1st order LPF for the woofer and mate it with an alternate tweeter (not the Pio TS20 though - that tweeter is also quite tizzy). Most tweeters need atleast a 2nd order HPF, some prefer higher order XOs. If you are using a 2nd order HPF for the tweeter remember to reverse the phase. if all this talk excites you and you want to know more just say so. The Gurus will surely chip in and satisfy you.
| Thread Tools | |
Similar Threads | ||||
| The Riddle Thread | whatcanthisbe | Shifting gears | 101 | 3rd September 2008 21:21 |
| The Do It Yourself Thread. | Cyrus43 | Modifications & Accessories | 12 | 12th July 2008 10:57 |
| The IPL Thread | normally_crazy | Shifting gears | 1315 | 21st June 2008 09:15 |
| The 'Thank You' thread.. | Deepz | The Indian Car Scene!! | 2 | 17th June 2007 09:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
