Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 1st April 2008, 14:32   #196 (permalink)
Originally Posted by DerAlte View Post
Superb, @diezel! Congratulations.
1. What was the length of the cable(s) from the PC cabinet to the LCD?
2. What is the 'black box' at the extreme right of the boot?
3. Did you connect the audio direct to the amp (looks like a Sony 4-ch) or did you wire it to the HU? (Which HU?)
4. Where did you put the DC-DC Convertor? (not visible in the PC cabinet)
5. Where did you draw power from?
Thanks guys, last couple of days I have been going through some stability tests and finally managed to get the system completely stable.
1. I bought a Extended M-F VGA cable of 2m length.
2. The black box on the extreme right is just the cabinet's top cover. Behind that is my JBL MonoBloc.
3. The audio is directly connected to the AUX of my pioneer 7950 HU. Under the cabinet is the place where my Focal SW are installed.
4. The DC-DC card is installed within the cabinet itself and as you see 3 wires are coming out of the cabinet, one connects directly to the main power line drawn from the battery and the other two are the ground and the remote cable(Connected to Remote cable coming from HU)
diezel is offline   Reply With Quote
Old 1st April 2008, 14:34   #197 (permalink)
hey gigy,
do you really have the Satguide GPS Software running on ur CarPC or ur a using a PND?
Old 1st April 2008, 18:24   #198 (permalink)
gigy's Avatar
satguide database was used with destinator for pc. it was running ok except for the sound, was not getting audio alerts, so changed over to centerfuse. besides center fuse is more convenient to run navigation and music together.
__________________
Suzuki Baleno
gigy is online now   Reply With Quote
Old 1st April 2008, 18:44   #199 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Originally Posted by gotzuk View Post
came across this range of HCL entry level laptops.
and the specs read as follows ... MiLeap Y ...
There is a younger brother of this one - costs app. 17K. Doesn't have touchscreen and the screen does not swivel - otherwise almost identical! The guy at the shop could not explain why the swivel and touch should cost another 12K! :-(
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
DerAlte is online now   Reply With Quote
Old 2nd April 2008, 11:54   #200 (permalink)
A Swivel is more of a mechanical upgrade so the cost may not be justified, but with a touchscreen it very well is justified. See most touchscreens are generally, 8-wire capacitative screens, which permit clicks, drags, and other commonly used left mouse button functions. They are more resistive to dust and heat related issues. A normal touchscreen external kit for a 17" monitor, which can be installed by removing the bezel of your monitor, comes for around 12K. Add to the cost of the monitor and you know where the prices are going...
So I guess, its more of a user's choice whether he/she thinks that it is worth it.
Old 2nd April 2008, 14:23   #201 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Originally Posted by diezel View Post
...A normal touchscreen external kit for a 17" monitor, which can be installed by removing the bezel of your monitor, comes for around 12K. Add to the cost of the monitor and you know where the prices are going...
True, but - an external 7" touchscreen LCD monitor, like this model has, costs 12K, I think (iRide)! A 7" touchscreen part actually costs $30, including the USB interface. There is a 'how to' video on YouTube for mod'ing an ASUS EeePC (costs 17K at Croma).
A true tablet PC with 12" screen (Toshiba, Compaq, HP) actually costs a lot more than the HCL one, though.
__________________
Old 2nd April 2008, 17:42   #202 (permalink)
I agree... but as I said, its all about what one wants. Some might be content with a Laptop as a CarPC solution and some like me want a full fledged ATX PC in my car, unlike the ITX based PC.
Old 5th April 2008, 22:34   #203 (permalink)
monty9991's Avatar
ok guys.. i pulled out my whole setup. currently i hooked-up my screen and HU.. i will make a box of acrilic sheet. will do that this next week end.
monty9991 is offline   Reply With Quote
Old 6th April 2008, 00:14   #204 (permalink)
monty9991's Avatar
as i was edditng what i said above accidently i hit enter and it got posted.
well anywayz.. my earlier setup wasent reliable. the screen use to move side to side and down ward. so i dint like.
i will make a new box of plexi sheet and will place it under the seat.
and more over i'd likw to have suggestion from every one in order to make my setup perfect.
Old 12th April 2008, 22:19   #205 (permalink)
HEY GUYS !! GR8 STUFF ! AWESOME CONGRATS MAN !!
i wanna do this too but i have a Q..
can i place my old sempron pc instead of a HU and play via that since i have a huge 1TB HDD with my a/v files....with the rest of the setup...amps/spks/subs
VOiLA is offline   Reply With Quote
Old 14th April 2008, 21:58   #206 (permalink)
monty9991's Avatar
yes sure you can do this. and if you want to use 5.1 or 7.1 sound card and directly hook it up to your amp that will be like "sone par suhaga" . lol..
best of luck on your setup.
Old 17th April 2008, 15:17   #207 (permalink)
monty9991's Avatar
i have my 2 more friends installing carputer in swift and Lancer. currently we had screens put up in the the consols. pics will be posted soon.
Old 30th April 2008, 16:42   #208 (permalink)
monty9991's Avatar
hi.. here are the pics of pc in an alto.. i palced this box under the seat..
later i will fix a dvd rom on this box.
Old 30th April 2008, 17:05   #209 (permalink)
spadival's Avatar
monty, ur centre console install seems to be lot better now, Good job !!
Whats the last pic with the suction cap on the windshield? its a bit dark
spadival is offline   Reply With Quote
Old 30th April 2008, 20:03   #210 (permalink)
WOW cool work Monty. Case made with plexiglass is awsome. What are the dimensions? Was it difficult to keep it under seat?
Would be cool if you can post of pics of box it has been fit in car.
And cool idea of fitting WiFi adapter.. "war driving" will be fun
Thread Tools
Planning to Buy a New Car Irwin Hatchbacks 23 1st April 2008 17:36
Auto Research Maverick1977 The Indian Car Scene!! 5 14th December 2007 07:51
Delhi ... yet again - Diesel Car ban in planning anmolbedi The Indian Car Scene!! 34 23rd November 2007 09:57
planning to build car sub amp, help needed clipto333 DIY - Do it yourself 204 17th August 2007 16:25
Research led me to my long lost brothers. chittybang Introduce yourself 7 9th July 2007 14:24
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
