| DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself. |
| | Thread Tools |
| | #211 (permalink) |
| BHPian | great work there especially with the Plexiglass. whats the configuration? whats the height of the box? whats the item fixed on the pillar? i think you can do with one fan for cooling. i am not using any on my amd board as yet and its still not burnt out.would recommend using a filter (very fine sponge installed in such a way it can be replaced or cleaned and put back)in the pusher fan as dust can cause serious problems with fans running.
__________________ Baleno1.6,Carputer:AMD Athlon 3000+,2gbram,80gb HD,centerfuse FE,satguide gps. |
| | #212 (permalink) |
| BHPian Join Date: Oct 2007 Location: ludhiana
| well thaks.. the height is around 3"... it is wifi receiver .. well i used 2 fans on opposite sides( one facing to wards the brake pedal etc and other to the back seat.. ) as the front fan will pull cool air inside from the front when a/c selecet on airflow for legs and face. and the other fan pulls out hot air from the box. well sometimes the temp goes upto 60 degeree for the CPU so i decided to use this. the configration is same wht i used in my earlier setup. i just changed the setup and everything is the same. for filters i have used a cloth on the fans to avoid dust goin inside. and more over i can pull it out under my seat anytime and blow air in it. |
| | #213 (permalink) | |
| Quote:
well the last pics shows the WIFI receiver .. i use this because i have wifi at my work and home and have networed it together. and easy to use internet to update things on carputer. | |
| | #214 (permalink) | |
| BHPian Join Date: Aug 2006 Location: New Delhi
| Quote:
That's a great solution!
__________________ People who talk in metaphors ought to shampoo my crotch. -Jack Nicholson As Good as It Gets (1997) | |
| | #216 (permalink) | |
| Quote:
turst me guys when you put your 3.5" hdd this way it wont skip .. so no need to buy 2.5" laptop hdd and buy a converter for it . will post the pictures tonite or tommarow while the box placed under the seat. | |
| | #217 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| Neat job, @monty9991, looks really professional. ![]() How did you make the various cuts, slots and openings in the acrylic sheet without the sheet cracking up? Most times when I have tried drilling holes, I get a cracked sheet :-( Which WiFi receiver card have you used? Looks like a USB type. How much did it cost?
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #219 (permalink) |
| BHPian | i think that connector is to give quick disconnect facility. i was using it in my woofer box but with time had intermittent connection problems. i would advise buying the automobile type three or four pin one since it has a lock built in, helps prevent loose connection due to vibration.
| | #220 (permalink) | |
| Quote:
i am using LINKSYS USB WIFI card. dont rem about the cost qas i bought this 1.5yr ago when i was in toronto for studies. this socket is for power.. i used this with PSU . one for +ve , 2nd for -ve and 3rd for ingnition. with this it is easy to pull out the box under the seat anytime.. i dont have anything fixed.. i have used another 9pin connector ( SERIAL PORT) both male and female for pulg in and out for the extenions of RESET SWITCH, HDD LED, POWER LED. | |
| Thread Tools | |
Similar Threads | ||||
| Planning to Buy a New Car | Irwin | Hatchbacks | 23 | 1st April 2008 17:36 |
| Auto Research | Maverick1977 | The Indian Car Scene!! | 5 | 14th December 2007 07:51 |
| Delhi ... yet again - Diesel Car ban in planning | anmolbedi | The Indian Car Scene!! | 34 | 23rd November 2007 09:57 |
| planning to build car sub amp, help needed | clipto333 | DIY - Do it yourself | 204 | 17th August 2007 16:25 |
| Research led me to my long lost brothers. | chittybang | Introduce yourself | 7 | 9th July 2007 14:24 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
