Go Back   Team-BHP > Under the Hood > In-Car Entertainment > DIY - Do it yourself
DIY - Do it yourself Installs, tweaks and experiments. Discuss how you can do it yourself.
Thread Tools
Old 13th March 2007, 21:31   #61 (permalink)
sys_whiz's Avatar
Originally Posted by anToNIcHeN View Post
How using the touch screen is gonna be inconvinient? Could you explain?.... I think using the touch screen is going to be more advantageous !....
My apologies, I could not explain it clearly. What I meant to say that, using the touch screen feature from a drop down screen will be in-convinces. Infact the primary input of my Carputer will be touch screen only from an in-dash monitor.
Note from Support Staff: Please don't use HTML tags.
sys_whiz is offline   Reply With Quote
Old 13th March 2007, 22:52   #62 (permalink)
low_bass_makker's Avatar
Originally Posted by sys_whiz View Post
I am going to do a mod to the dash like bellow
Gurus, pls suggest if the way I am going to mod the dash is perfect or has some issues. I asked the Maruti workshop techcian about this and he told there won't be any issue.
Naveenji, I am not going to use the drop down screen. It will be little bit in-convience to use te touch screen.
the RUX the controller of the PXA is a flush mounting device I would suggest to get it installed it in some other place dont remove the HVAC controls as it will be a bit difficult to fix them some place else....
the RUX would not be needed every time as it will doing a processing only so it might be mounted some place else also...so please give it a though before going for it.....
__________________
“First they ignore you. Then they laugh at you. Then they fight you. Then you win
Old 13th March 2007, 23:07   #63 (permalink)
satish_appasani's Avatar
Sys, Are you planning to install any USB ports in the dash?
satish_appasani is offline   Reply With Quote
Old 14th March 2007, 02:25   #64 (permalink)
sys_whiz's Avatar
Thank You LBM for the info. I was under impression that this device will take a full 1 din slot. I will plan in some other place. Some more planning...
This is the benifit of asking questions to Gurus . Hats up LBM.
Yes Satish....I am planning to put USB ports in dash. Two high BW USBs directly from high speed port of Port Replicator and two low BW ports from the USB hub (used to connect the VGA Monitor Touch Screen USB port).
One High Speed port will be dedicated to GPS receiver and one can be used to connect any storage device like USB HDD, Memory Stick or any Video Capture device.
One Low speed port will be dedicated for OBD Scan Device and another can be used for any other device.
Old 28th March 2007, 09:50   #65 (permalink)
sys_whiz's Avatar
Default JBLfyed my Baleno.
After a long time I am back in HYD and Yesterday I did JBLfyed my Baleno. Wow what a great sound . I never thought the music in a car can be so sweet. Thank you Gurus for all the advice and giving direction to buy good stuffs. The config of the 1st phase of my install is as :
1. Front Comp : GTO 607C with GTO 17T Tweeter
2. Rear Oval : GTO 937
3. Amp : CS 60.4
4. Wiring Kit : Audision
5. RCA Kit : Monster
6. Y-Cable : Monster
The Next phase of my install will be to install a 301.1 Monoblock and GTO 1204BR Sub Box, this box impressed me. I was planning to go for the 12" tube(1204T), but after listening both, I felt 1204 BR is better than 1204T. The Bass is tight and punchy with the Box and the tube was more boomy, which I did not like. This is my personal experience.
Now coming to the main and Important part. I never knew being a BHPian has a big reputation and BHPian are treated differently than other customers. While discussing and finalizing the products with "SPROCKET" (Here I JBLfyed my Baleno), Aamirpet, I just told them that I am a member of Team-BHP and I know SAM. From that time I was being treated different. Without even asking them they gave me a straight 12% discount on JBL products. Thank You Gurus and special thanks to SAM Bhaiya. The Installer "Hameed" was a techy guy too. Everyone there were saying that they love to work with the customer who have good technical knowledge on Sound System(Though I am just learning from the Gurus here ). Being Hameed a good knowledgable and experienced installer, he was asking me to guide him in every step of the install starting from mounting the speakers, tweeters to Laying cables, tuinning the amp(He was thinking, being a BHPian I am too techy than him...Ha Ha Ha Ha)
I forgot to carry my camera to click the install Pics, but I captured some pics in Mobile cam of my Brother-in-law. I will upload those shortly(He does not have a Data Cable to download the pics and will buy one today)
Finally I am very happy and satisfied with my install, my JBLfyed Baleno Ha Ha Ha....
Thanks once again to the BHPians and SAM Bhaiya.
By the way I have added some more parts to my Car PC install, remaining I will buy from iRide in my coming visit to Mumbai. One of my friend is coming from US on 14th Apr. I asked him to Bring PXA-701 for me. I beleive I can start my PC install 2nd week of April. Let's see.
Thank You
--Ranjit
PS: SAM Bhaiya, I could not get some JBL Stickers from "SPROCKET" to put in my Car. Can you pls help.
Old 28th March 2007, 10:04   #66 (permalink)
Team-BHP Moderator
navin's Avatar
1. Front Comp : GTO 607C with GTO 17T Tweeter.
just to clarify you bought an extra set of tweeters? the 607 component set includes a pair of tweeters.
__________________
Scixelsyd Etinu
Old 28th March 2007, 10:24   #67 (permalink)
sys_whiz's Avatar
No Naveenji, the comp set includes this tweeter. I have not bought extra tweeters. Sorry for the confusion.
Old 28th March 2007, 10:25   #68 (permalink)
gunbir's Avatar
Infractions: 0/1 (5)
Re the RUX, you could do what a lot of people do; initially keep the RUX connected through a loose cable, setup your system and then remove the RUX. The H701 will continue to run as setup. This is great if you dont have the real estate to mount the RUX, plus people wont be able to screw up your settings.
__________________
Its better to be pissed off than be pissed on
gunbir is online now   Reply With Quote
Old 28th March 2007, 10:33   #69 (permalink)
sys_whiz's Avatar
That's good idea Gunbir. I never know If we remove the RUX, the system will work. Thank You for the info.
Old 28th March 2007, 10:36   #70 (permalink)
I Agree with Gunbir Phaji....the rux controller can be removed after doing the adjustment...but removing and putting again will be a difficult job as the connecter of the rux is very delicate and need attention while handlling...
__________________
Old 28th March 2007, 10:48   #71 (permalink)
Team-BHP Moderator
navin's Avatar
Re the RUX, you could do what a lot of people do; initially keep the RUX connected through a loose cable, setup your system and then remove the RUX..
Perfect...or hide the RUX.
There are plently of places to hide stuff. Many years ago a friend invited me to hear a rather expensive system installed in a contessa. I'ml talking Kimber cable and Tara labs wire etc in the early 90s. I kept wondeirng why with a great HU, great amps, great speakers (lets not go into the brands here) and a good install the system sounded uninspiring (clean and detailed but the soul was missing). Then the owner flipped down the dash, an area above the glove box and in that area he had installed a DSP and a 2 x stereo 12 band EQs!
__________________
Scixelsyd Etinu
Old 28th March 2007, 11:38   #72 (permalink)
Sys, Congrats on the audio setup. Your speakers and amp are similar to what i have in my car. Where did you get the Audison cables? At Sprocket?
So finally Sprocket is considering discounts for tbhp members. When i dealt with them 4% was very difficult to get.
Let us plan to meet some time and check your car.
Old 28th March 2007, 11:49   #73 (permalink)
sys_whiz's Avatar
Thank You Satish...Yes I got Audison cables and Monster RCAs from Sporocket.
Yeh....I got more discount....Sam Bhaiya Tahnk you.
Sure we will meet sometime may be tomorrow?
Old 28th March 2007, 12:21   #74 (permalink)
hmm....mini meet is on the agenda....
Congrats sys....on the new setup...dont forget to post some pics of your system progress...
__________________
Old 28th March 2007, 12:26   #75 (permalink)
Our work places are very close by and so we can take half hour or so to quickly check the setup.
Thread Tools
Planning to Buy a New Car Irwin Hatchbacks 23 1st April 2008 17:36
Auto Research Maverick1977 The Indian Car Scene!! 5 14th December 2007 07:51
Delhi ... yet again - Diesel Car ban in planning anmolbedi The Indian Car Scene!! 34 23rd November 2007 09:57
planning to build car sub amp, help needed clipto333 DIY - Do it yourself 204 17th August 2007 16:25
Research led me to my long lost brothers. chittybang Introduce yourself 7 9th July 2007 14:24
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
